[PostGIS] #5658: postgis does not compile lats few days
PostGIS trac at osgeo.org
Tue Jan 23 08:02:44 PST 2024
 Reporter:  RekGRpth  |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS PostgreSQL
Component:  postgis   |    Version:  master
 Keywords:            |
 #9 323.2 ---- Making all in liblwgeom
 #9 323.2 make[1]: Entering directory
 '/var/lib/postgresql/src/postgis/liblwgeom'
 #9 323.2 /bin/sh ../libtool --mode=compile gcc -I./../deps/ryu/..
 -I/usr/include/webp -I/usr/include/libxml2 -I/usr/include/json-c
 -DNDEBUG -I. -I. -std=gnu99 -g -O2 -fno-math-errno -fno-signed-zeros
 -Wall -O2 -fPIC -DPIC -c -o stringbuffer.lo stringbuffer.c
 -Wall -O2 -fPIC -DPIC -c -o optionlist.lo optionlist.c
 -Wall -O2 -fPIC -DPIC -c -o stringlist.lo stringlist.c
 -Wall -O2 -fPIC -DPIC -c -o bytebuffer.lo bytebuffer.c
 #9 323.3 libtool: compile: gcc -I./../deps/ryu/.. -I/usr/include/webp
 -I/usr/include/libxml2 -I/usr/include/json-c -DNDEBUG -I. -I.
 -std=gnu99 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2 -fPIC
 -DPIC -c optionlist.c -fPIC -DPIC -o .libs/optionlist.o
 -DPIC -c stringbuffer.c -fPIC -DPIC -o .libs/stringbuffer.o
 -DPIC -c bytebuffer.c -fPIC -DPIC -o .libs/bytebuffer.o
 -DPIC -c stringlist.c -fPIC -DPIC -o .libs/stringlist.o
 #9 323.4 libtool: compile: gcc -I./../deps/ryu/.. -I/usr/include/webp
 -DPIC -c stringlist.c -o stringlist.o >/dev/null 2>&1
 -DPIC -c optionlist.c -o optionlist.o >/dev/null 2>&1
 #9 323.5 libtool: compile: gcc -I./../deps/ryu/.. -I/usr/include/webp
 -DPIC -c bytebuffer.c -o bytebuffer.o >/dev/null 2>&1
 -DPIC -c stringbuffer.c -o stringbuffer.o >/dev/null 2>&1
 #9 323.6 /bin/sh ../libtool --mode=compile gcc -I./../deps/ryu/..
 -Wall -O2 -fPIC -DPIC -c -o measures.lo measures.c
 -Wall -O2 -fPIC -DPIC -c -o measures3d.lo measures3d.c
 #9 323.6 libtool: compile: gcc -I./../deps/ryu/.. -I/usr/include/webp
 -DPIC -c measures.c -fPIC -DPIC -o .libs/measures.o
 -DPIC -c measures3d.c -fPIC -DPIC -o .libs/measures3d.o
 -Wall -O2 -fPIC -DPIC -c -o ptarray.lo ptarray.c
 #9 323.6 measures.c: In function 'lw_dist2d_line_poly':
 #9 323.6 measures.c:769:43: error: 'p' undeclared (first use in this
 function); did you mean 'pt'?
 #9 323.6 769 | return lw_dist2d_zero(dl, p, p);
 #9 323.6 | ^
 #9 323.6 | pt
 #9 323.6 measures.c:769:43: note: each undeclared identifier is
 reported only once for each function it appears in
 #9 323.7 measures.c:770:1: warning: control reaches end of non-void
 function [-Wreturn-type]
 #9 323.7 770 | }
 #9 323.7 | ^
 #9 323.7 libtool: compile: gcc -I./../deps/ryu/.. -I/usr/include/webp
 -DPIC -c ptarray.c -fPIC -DPIC -o .libs/ptarray.o
 #9 323.7 make[1]: *** [Makefile:222: measures.lo] Error 1
 #9 323.7 make[1]: *** Waiting for unfinished jobs....
 #9 324.4 libtool: compile: gcc -I./../deps/ryu/.. -I/usr/include/webp
 -DPIC -c measures3d.c -o measures3d.o >/dev/null 2>&1
 #9 324.6 libtool: compile: gcc -I./../deps/ryu/.. -I/usr/include/webp
 -DPIC -c ptarray.c -o ptarray.o >/dev/null 2>&1
 #9 325.5 make[1]: Leaving directory
 #9 325.5 make: *** [GNUmakefile:27: all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5658>
