[SCM] PostGIS branch master updated. 3.4.0rc1-898-ga4909b145
Tue Jan 23 13:57:25 PST 2024
the project "PostGIS".
       via  a4909b145317932b05e7ebb9f55df127de965982 (commit)
      from  81381c6e5d313d6888bd3a880ddaef99783a0062 (commit)
revisions in full, below.
commit a4909b145317932b05e7ebb9f55df127de965982
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jan 23 13:57:05 2024 -0800
    Do full ring check always in line/poly maxdist mode, references #5639
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index b22b2cca1..733170450 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -742,7 +742,7 @@ lw_dist2d_line_poly(LWLINE *line, LWPOLY *poly, DISTPTS *dl)
 	const POINT2D *pt = getPoint2d_cp(pa, 0);
 	/* Line has a pount outside poly. Check distance to outer ring only. */
-	if (ptarray_contains_point(poly->rings[0], pt) == LW_OUTSIDE)
+	if (ptarray_contains_point(poly->rings[0], pt) == LW_OUTSIDE || dl->mode == DIST_MAX)
 		return lw_dist2d_ptarray_ptarray(pa, poly->rings[0], dl);
 	for (uint32_t i = 1; i < poly->nrings; i++)
Summary of changes:
 liblwgeom/measures.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
