[SCM] PostGIS branch stable-3.4 updated. 3.4.1-35-ga5d3d35de
Tue Jan 23 13:59:11 PST 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  a5d3d35def81606e3866ba3eac51dad892520917 (commit)
      from  be9cd58ce5e695d8620f175b1dad0430081d67d6 (commit)
revisions in full, below.
commit a5d3d35def81606e3866ba3eac51dad892520917
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jan 23 13:59:06 2024 -0800
    Do full ring check always in line/poly maxdist mode, references #5639
diff --git a/NEWS b/NEWS
index 478ba0186..fa3fd1e3c 100644
--- a/NEWS
+++ b/NEWS
@@ -18,6 +18,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
  - #5648, postgis_raster upgrade fails on PG16 (Ronan Dunklau)
  - #5646, Crash on collections with empty members (Paul Ramsey)
  - #5580, Handle empty collection components in 3d distance (Paul Ramsey)
+ - #5639, ST_DFullyWithin line/poly error case (Paul Ramsey)
 * Bug Fixes and Enhancments *
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index b22b2cca1..733170450 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -742,7 +742,7 @@ lw_dist2d_line_poly(LWLINE *line, LWPOLY *poly, DISTPTS *dl)
 	const POINT2D *pt = getPoint2d_cp(pa, 0);
 	/* Line has a pount outside poly. Check distance to outer ring only. */
-	if (ptarray_contains_point(poly->rings[0], pt) == LW_OUTSIDE)
+	if (ptarray_contains_point(poly->rings[0], pt) == LW_OUTSIDE || dl->mode == DIST_MAX)
 		return lw_dist2d_ptarray_ptarray(pa, poly->rings[0], dl);
 	for (uint32_t i = 1; i < poly->nrings; i++)
Summary of changes:
 NEWS                 | 1 +
 liblwgeom/measures.c | 2 +-
 2 files changed, 2 insertions(+), 1 deletion(-)
hooks/post-receive
