[SCM] PostGIS branch master updated. 3.4.0rc1-899-gf5d6c10b7
Thu Jan 25 08:08:43 PST 2024
the project "PostGIS".
       via  f5d6c10b7de4cc6cac4e809d495aa4ad25ca4743 (commit)
      from  a4909b145317932b05e7ebb9f55df127de965982 (commit)
revisions in full, below.
commit f5d6c10b7de4cc6cac4e809d495aa4ad25ca4743
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jan 25 08:07:11 2024 -0800
    Change behaviour of ST_DFullyWithin(A, B, R)
    to be equivalent to ST_Contains(ST_Buffer(A, R), B).
    This should more correctly match the behaviour users
    expect and more logically extends on the behaviour
    of ST_DWithin(A, B, R). Closes #5659.
diff --git a/NEWS b/NEWS
index 9679ccf22..4ab25172d 100644
--- a/NEWS
+++ b/NEWS
@@ -27,6 +27,8 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
            (Jan Tojnar)
   - #5496, ST_Clip all variants replaced, will require
            rebuilding of materialized views that use them (Regina Obe)
+  - #5659, ST_DFullyWithin behaviour has changed to
+           be ST_Contains(ST_Buffer(A, R), B) (Paul Ramsey)
 * New Features *
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index b1570598d..fb42bf111 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -2102,7 +2102,7 @@ ST_DWithin(
     <refnamediv>
     <refname>ST_DFullyWithin</refname>
-    <refpurpose>Tests if two geometries are entirely within a given distance</refpurpose>
+    <refpurpose>Tests if a geometry is entirely inside a distance of another</refpurpose>
     </refnamediv>
     <refsynopsisdiv>
@@ -2125,26 +2125,33 @@ ST_DWithin(
     <refsection>
     <title>Description</title>
-    <para>Returns true if the geometries are entirely within the specified distance
-    of one another. The distance is specified in units defined by the
-    spatial reference system of the geometries.  For this function to make
-    sense, the source geometries must both be of the same coordinate projection,
-    having the same SRID.</para>
+    <para>Returns true if <code>g2</code> is entirely within
+    <code>distance</code> of <code>g1</code>. Visually, the
+    condition is true if <code>g2</code> is contained within
+    a <code>distance</code> buffer of <code>g1</code>.
+    The distance is specified in units defined by the
+    spatial reference system of the geometries.</para>
     <note><para>&index_aware;</para></note>
     <para role="availability" conformance="1.5.0">Availability: 1.5.0</para>
+    <para role="changed" conformance="3.5.0">Changed: 3.5.0 : the logic behind the function now uses a test of containment within a buffer, rather than the ST_MaxDistance algorithm. Results will differ from prior versions, but should be closer to user expectations.</para>
     </refsection>
     <refsection>
     <title>Examples</title>
-    <programlisting>postgis=# SELECT ST_DFullyWithin(geom_a, geom_b, 10) as DFullyWithin10, ST_DWithin(geom_a, geom_b, 10) as DWithin10, ST_DFullyWithin(geom_a, geom_b, 20) as DFullyWithin20 from
-    (select ST_GeomFromText('POINT(1 1)') as geom_a,ST_GeomFromText('LINESTRING(1 5, 2 7, 1 9, 14 12)') as geom_b) t1;
+    <programlisting>SELECT
+    ST_DFullyWithin(geom_a, geom_b, 10) AS DFullyWithin10,
+    ST_DWithin(geom_a, geom_b, 10) AS DWithin10,
+    ST_DFullyWithin(geom_a, geom_b, 20) AS DFullyWithin20
+FROM (VALUES
+    ('POINT(1 1)', 'LINESTRING(1 5, 2 7, 1 9, 14 12)')
+    ) AS v(geom_a, geom_b)
- DFullyWithin10 | DWithin10 | DFullyWithin20 |
- f             | t        | t             |  </programlisting>
+ dfullywithin10 | dwithin10 | dfullywithin20
+ f              | t         | t
+</programlisting>
     </refsection>
     <refsection>
diff --git a/postgis/gserialized_supportfn.c b/postgis/gserialized_supportfn.c
index 58f65dbd9..bd4a9f56a 100644
--- a/postgis/gserialized_supportfn.c
+++ b/postgis/gserialized_supportfn.c
@@ -85,7 +85,7 @@ static const int16 GeometryStrategies[] = {
 	[ST_OVERLAPS_IDX]               = RTOverlapStrategyNumber,
 	[ST_COVERS_IDX]                 = RTContainsStrategyNumber,
 	[ST_CROSSES_IDX]                = RTOverlapStrategyNumber,
-	[ST_DFULLYWITHIN_IDX]           = RTOverlapStrategyNumber,
+	[ST_DFULLYWITHIN_IDX]           = RTContainsStrategyNumber,
 	[ST_3DDWITHIN_IDX]              = RTOverlapStrategyNumber,
 	[ST_3DDFULLYWITHIN_IDX]         = RTOverlapStrategyNumber,
 	[ST_LINECROSSINGDIRECTION_IDX]  = RTOverlapStrategyNumber,
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 0be7433ca..e9e8bf96d 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -67,7 +67,6 @@ Datum LWGEOM_closestpoint(PG_FUNCTION_ARGS);
 Datum LWGEOM_shortestline2d(PG_FUNCTION_ARGS);
 Datum LWGEOM_longestline2d(PG_FUNCTION_ARGS);
 Datum LWGEOM_dwithin(PG_FUNCTION_ARGS);
-Datum LWGEOM_dfullywithin(PG_FUNCTION_ARGS);
 Datum LWGEOM_maxdistance3d(PG_FUNCTION_ARGS);
 Datum LWGEOM_mindistance3d(PG_FUNCTION_ARGS);
@@ -760,41 +759,6 @@ Datum LWGEOM_dwithin(PG_FUNCTION_ARGS)
 	PG_RETURN_BOOL(tolerance >= mindist);
-Returns boolean describing if
-maximum 2d distance between objects in
-geom1 and geom2 is shorter than tolerance
-PG_FUNCTION_INFO_V1(LWGEOM_dfullywithin);
-	double maxdist;
-	GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(0);
-	GSERIALIZED *geom2 = PG_GETARG_GSERIALIZED_P(1);
-	double tolerance = PG_GETARG_FLOAT8(2);
-	LWGEOM *lwgeom1 = lwgeom_from_gserialized(geom1);
-	LWGEOM *lwgeom2 = lwgeom_from_gserialized(geom2);
-	if (tolerance < 0)
-		elog(ERROR, "Tolerance cannot be less than zero\n");
-		PG_RETURN_NULL();
-	gserialized_error_if_srid_mismatch(geom1, geom2, __func__);
-	maxdist = lwgeom_maxdistance2d_tolerance(lwgeom1, lwgeom2, tolerance);
-	PG_FREE_IF_COPY(geom1, 0);
-	PG_FREE_IF_COPY(geom2, 1);
-	/*If function is feed with empty geometries we should return false*/
-	if (maxdist > -1)
-		PG_RETURN_BOOL(tolerance >= maxdist);
-	PG_RETURN_BOOL(LW_FALSE);
  Maximum 2d distance between objects in geom1 and geom2.
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 16ae6dd3d..bd49bafca 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -3519,4 +3519,53 @@ Datum ST_OrientedEnvelope(PG_FUNCTION_ARGS)
+* Returns boolean true if the second argument
+* is fully contained in a buffer of the first
+* argument.
+Datum LWGEOM_dfullywithin(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(LWGEOM_dfullywithin);
+	GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(0);
+	GSERIALIZED *geom2 = PG_GETARG_GSERIALIZED_P(1);
+	double radius = PG_GETARG_FLOAT8(2);
+	GEOSGeometry *buffer1 = NULL;
+	GEOSGeometry *geos1 = NULL, *geos2 = NULL;
+	char contained;
+	if (radius < 0.0)
+		elog(ERROR, "Tolerance cannot be less than zero\n");
+		PG_RETURN_NULL();
+	if (gserialized_is_empty(geom1) || gserialized_is_empty(geom2))
+		PG_RETURN_BOOL(false);
+	initGEOS(lwpgnotice, lwgeom_geos_error);
+	gserialized_error_if_srid_mismatch(geom1, geom2, __func__);
+	geos1 = POSTGIS2GEOS(geom1);
+	geos2 = POSTGIS2GEOS(geom2);
+	if (!(geos1 && geos2))
+		HANDLE_GEOS_ERROR("Geometry could not be converted to GEOS");
+	buffer1 = GEOSBuffer(geos1, radius, 16);
+	GEOSGeom_destroy(geos1);
+	if (!(buffer1))
+		HANDLE_GEOS_ERROR("Buffer operation failed");
+	contained = GEOSContains(buffer1, geos2);
+	GEOSGeom_destroy(buffer1);
+	GEOSGeom_destroy(geos2);
+	if (contained == 2) HANDLE_GEOS_ERROR("GEOSContains");
+	PG_FREE_IF_COPY(geom1, 0);
+	PG_FREE_IF_COPY(geom2, 1);
+	PG_RETURN_BOOL(contained == 1);
diff --git a/raster/test/regress/rt_geos_relationships_expected b/raster/test/regress/rt_geos_relationships_expected
index 8d1a83f9d..2d1ae6b92 100644
--- a/raster/test/regress/rt_geos_relationships_expected
+++ b/raster/test/regress/rt_geos_relationships_expected
@@ -1,4 +1,4 @@
-1.1|0|0|t|f|t|t|f|f|f|t|t|t|t|t|t|f|f|f|f|t
+1.1|0|0|t|f|t|t|f|f|f|t|t|t|t|t|t|t|f|f|f|t
 1.1|0|1|f|f|f|f|f|t|f|f|t|t|t|t|t|f|f|f|f|t
 1.1|0|2|f|f|f|f|f|t|f|f|t|t|t|t|t|f|f|f|f|t
 1.1|0|3|f|f|f|f|t|f|f|f|f|f|f|f|t|f|f|f|f|f
@@ -7,8 +7,8 @@
 1.1|0|12|f|f|f|f|f|t|f|f|t|t|t|t|t|f|f|f|f|t
 1.1|0|13|f|f|f|f|f|t|f|f|t|f|f|f|f|f|f|f|f|f
 1.1|0|14|f|f|f|f|t|f|f|f|f|f|t|t|t|f|f|f|f|t
-1.1|0|15|t|t|f|t|f|f|f|f|t|t|t|t|t|f|f|f|f|t
-1.1|0|16|t|t|f|t|f|f|f|f|t|t|t|t|t|f|f|f|f|t
+1.1|0|15|t|t|f|t|f|f|f|f|t|t|t|t|t|t|f|f|f|t
+1.1|0|16|t|t|f|t|f|f|f|f|t|t|t|t|t|t|f|f|f|t
 1.1|0|20|f|f|t|f|f|f|f|t|t|t|t|t|t|f|f|f|f|t
 1.1|0|21|f|f|t|f|f|f|f|t|t|t|t|t|t|f|f|f|f|t
 1.1|0|22|f|f|t|f|f|f|f|t|t|t|t|t|t|f|f|f|f|t
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index be93a47cb..dd94af1b5 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1527,3 +1527,13 @@ FROM
 ST_GeomFromText('MULTIPOINT((-2 0), EMPTY)') AS a1,
 ST_GeomFromText('MULTIPOINT((1 0),(0 0))') AS a2;
+SELECT '#5639','fullywithin' || id, ST_DFullyWithin(a, b, r)
+FROM (VALUES
+ (1, 'POLYGON((0 0, 1 0, 1 1, 1 0, 0 0))', 'POINT(1 2)', 2)
+,(2, 'POLYGON((0 0, 1 0, 1 1, 1 0, 0 0))', 'POINT(1 2)', 0.5)
+,(3, 'POLYGON((0 0, 1 0, 1 1, 1 0, 0 0))', 'LINESTRING(1.5 0.5, 2.5 0.5)', 1)
+,(4, 'POLYGON((0 0, 1 0, 1 1, 1 0, 0 0))', 'LINESTRING(1.5 0.5, 2.5 0.5)', 2)
+,(5, 'LINESTRING(0 0, 10 0)', 'LINESTRING(0 2, 10 4)', 1)
+,(6, 'LINESTRING(0 0, 10 0)', 'LINESTRING(0 2, 10 4)', 3)
+,(7, 'LINESTRING(0 0, 10 0)', 'LINESTRING(0 2, 10 4)', 4)
+) AS t(id, a, b, r);
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index b9f3cf854..41d2f1e91 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -470,3 +470,10 @@ ERROR:  Geometry contains invalid coordinates
 #5378|4269
 #5627|t
 #5604|2|POINT(0 0)|2|POINT(-2 0)
+#5639|fullywithin1|t
+#5639|fullywithin2|f
+#5639|fullywithin3|f
+#5639|fullywithin4|t
+#5639|fullywithin5|f
+#5639|fullywithin6|f
+#5639|fullywithin7|t
Summary of changes:
 NEWS                                               |  2 +
 doc/reference_relationship.xml                     | 33 +++++++++------
 postgis/gserialized_supportfn.c                    |  2 +-
 postgis/lwgeom_functions_basic.c                   | 36 ----------------
 postgis/lwgeom_geos.c                              | 49 ++++++++++++++++++++++
 raster/test/regress/rt_geos_relationships_expected |  6 +--
 regress/core/tickets.sql                           | 10 +++++
 regress/core/tickets_expected                      |  7 ++++
 8 files changed, 92 insertions(+), 53 deletions(-)
hooks/post-receive
