[SCM] PostGIS branch master updated. 3.4.0rc1-900-g2962a3650
Thu Jan 25 11:45:13 PST 2024
the project "PostGIS".
       via  2962a3650d2a268fbfc7645d615be64804a9a127 (commit)
      from  f5d6c10b7de4cc6cac4e809d495aa4ad25ca4743 (commit)
revisions in full, below.
commit 2962a3650d2a268fbfc7645d615be64804a9a127
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jan 25 11:45:06 2024 -0800
    ST_AsGeoJSON, produce correct output in null geometry case, closes #5597
diff --git a/postgis/lwgeom_out_geojson.c b/postgis/lwgeom_out_geojson.c
index 3d6beaf3f..530ca6559 100644
--- a/postgis/lwgeom_out_geojson.c
+++ b/postgis/lwgeom_out_geojson.c
@@ -203,7 +203,7 @@ composite_to_geojson(FunctionCallInfo fcinfo,
 			else
-				appendStringInfoString(result, "{\"type\": null}");
+				appendStringInfoString(result, "null");
 		else if (is_id_column)
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index dd94af1b5..4b69ec20c 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1537,3 +1537,5 @@ FROM (VALUES
 ,(6, 'LINESTRING(0 0, 10 0)', 'LINESTRING(0 2, 10 4)', 3)
 ,(7, 'LINESTRING(0 0, 10 0)', 'LINESTRING(0 2, 10 4)', 4)
 ) AS t(id, a, b, r);
+SELECT '#5597', ST_AsGeoJSON(r.*) from (values (null::geometry)) as r(geom);
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 41d2f1e91..234d147ef 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -477,3 +477,4 @@ ERROR:  Geometry contains invalid coordinates
 #5639|fullywithin5|f
 #5639|fullywithin6|f
 #5639|fullywithin7|t
+#5597|{"type": "Feature", "geometry": null, "properties": {}}
Summary of changes:
 postgis/lwgeom_out_geojson.c  | 2 +-
 regress/core/tickets.sql      | 2 ++
 regress/core/tickets_expected | 1 +
 3 files changed, 4 insertions(+), 1 deletion(-)
hooks/post-receive
