[SCM] PostGIS branch master updated. 3.4.0rc1-977-g8bfdce1c8
Wed Mar 6 00:00:53 PST 2024
the project "PostGIS".
       via  8bfdce1c8577ccec4fe870c9a35c196b7dffe24c (commit)
       via  444fe40b54acd43b45a59c4db9a85c0e673498a5 (commit)
       via  a527255c91830c0ed1080d999c2a3d1728007e2c (commit)
      from  376d4ec7caf5b3772a8615f7b44b880bf4942ef8 (commit)
revisions in full, below.
commit 8bfdce1c8577ccec4fe870c9a35c196b7dffe24c
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Mar 5 17:01:28 2024 +0100
    Fix ST_Node with 1-vertex linestring
    References #5685 in master branch
    Includes unit test
diff --git a/liblwgeom/cunit/cu_node.c b/liblwgeom/cunit/cu_node.c
index 3497476c2..9308341ba 100644
--- a/liblwgeom/cunit/cu_node.c
+++ b/liblwgeom/cunit/cu_node.c
@@ -61,6 +61,15 @@ static void test_lwgeom_node(void)
 "MULTILINESTRING((0 0,2.5 2.5),(0 5,2.5 2.5),(2.5 2.5,5 5,10 0),(10 0,11 0,12 0,20 0),(20 0,22 0),(2.5 2.5,5 0))",
 		tmp);
 	lwfree(tmp); lwgeom_free(out); lwgeom_free(in);
+	/* See https://trac.osgeo.org/postgis/ticket/5685 */
+	wkt = "LINESTRING(0 0,0 0)";
+	in = lwgeom_from_wkt(wkt, LW_PARSER_CHECK_NONE);
+	out = lwgeom_node(in);
+	/* printf("%s\n", lwgeom_to_ewkt(out)); */
+	CU_ASSERT_FATAL(out != NULL);
+	ASSERT_LWGEOM_EQUAL(in, out);
+	lwgeom_free(out); lwgeom_free(in);
 static int
diff --git a/liblwgeom/lwgeom_geos_node.c b/liblwgeom/lwgeom_geos_node.c
index 5c8fd7abb..5c67b7d09 100644
--- a/liblwgeom/lwgeom_geos_node.c
+++ b/liblwgeom/lwgeom_geos_node.c
@@ -166,22 +166,52 @@ lwgeom_node(const LWGEOM* lwgeom_in)
 	LWDEBUGGEOS(1, gn, "Noded");
-	gm = GEOSLineMerge(gn);
-	GEOSGeom_destroy(gn);
-	if ( ! gm ) {
-		lwgeom_free(ep);
-		lwerror("GEOSLineMerge: %s", lwgeom_geos_errmsg);
-		return NULL;
-	LWDEBUGGEOS(1, gm, "LineMerged");
+	nl = GEOSGetNumGeometries(gn);
+	if ( nl > 1 )
+		gm = GEOSLineMerge(gn);
+		GEOSGeom_destroy(gn);
+		if ( ! gm ) {
+			lwgeom_free(ep);
+			lwerror("GEOSLineMerge: %s", lwgeom_geos_errmsg);
+			return NULL;
+		LWDEBUGGEOS(1, gm, "LineMerged");
+		gn = gm;
-	lines = GEOS2LWGEOM(gm, FLAGS_GET_Z(lwgeom_in->flags));
-	GEOSGeom_destroy(gm);
-	if ( ! lines ) {
-		lwgeom_free(ep);
-		lwerror("Error during GEOS2LWGEOM");
-		return NULL;
+		lines = GEOS2LWGEOM(gn, FLAGS_GET_Z(lwgeom_in->flags));
+		if ( ! lines ) {
+			lwgeom_free(ep);
+			lwerror("Error during GEOS2LWGEOM");
+			return NULL;
+	else if ( nl == 1 )
+		const GEOSGeometry *gc = GEOSGetGeometryN(gn, 0);
+		lines = GEOS2LWGEOM(gc, FLAGS_GET_Z(lwgeom_in->flags));
+		if ( ! lines ) {
+			lwgeom_free(ep);
+			return NULL;
+	else
+		/* No geometries, don't bother with re-adding endpoints */
+		if ( ! lines ) {
+			lwgeom_free(ep);
+			return NULL;
+		lwgeom_set_srid(lines, lwgeom_in->srid);
+		return (LWGEOM*)lines;
 	 * Reintroduce endpoints from input, using split-line-by-point.
commit 444fe40b54acd43b45a59c4db9a85c0e673498a5
Date:   Tue Mar 5 16:46:34 2024 +0100
    Debug GEOS geometries in lwgeom_noded
    References #5685
index 8e5e8c3bc..5c8fd7abb 100644
@@ -18,10 +18,14 @@
- * Copyright (C) 2011 Sandro Santilli <strk at kbt.io>
+ * Copyright (C) 2011-2024 Sandro Santilli <strk at kbt.io>
+#include "../postgis_config.h"
+/*#define POSTGIS_DEBUG_LEVEL 1*/
+#include "lwgeom_log.h"
 #include "lwgeom_geos.h"
 #include "liblwgeom_internal.h"
@@ -160,6 +164,7 @@ lwgeom_node(const LWGEOM* lwgeom_in)
 		lwerror("GEOSNode: %s", lwgeom_geos_errmsg);
 		return NULL;
+	LWDEBUGGEOS(1, gn, "Noded");
@@ -168,6 +173,7 @@ lwgeom_node(const LWGEOM* lwgeom_in)
 		return NULL;
commit a527255c91830c0ed1080d999c2a3d1728007e2c
Date:   Tue Mar 5 16:46:13 2024 +0100
    Add LWDEBUGGEOS macro for debugging geos geometries
diff --git a/liblwgeom/lwgeom_geos.h b/liblwgeom/lwgeom_geos.h
index e1b278e0c..90a1562fb 100644
--- a/liblwgeom/lwgeom_geos.h
+++ b/liblwgeom/lwgeom_geos.h
@@ -46,3 +46,30 @@ POINTARRAY* ptarray_from_GEOSCoordSeq(const GEOSCoordSequence* cs, uint8_t want3
 extern char lwgeom_geos_errmsg[];
 extern void lwgeom_geos_error(const char* fmt, ...);
+ * Debug macros
+#if POSTGIS_DEBUG_LEVEL > 0
+/* Display a notice and a WKT representation of a geometry
+ * at the given debug level */
+#define LWDEBUGGEOS(level, geom, msg) \
+  if (POSTGIS_DEBUG_LEVEL >= level) \
+  do { \
+		GEOSWKTWriter *wktwriter = GEOSWKTWriter_create(); \
+		char *wkt = GEOSWKTWriter_write(wktwriter, (geom)); \
+		LWDEBUGF(1, msg " (GEOS): %s", wkt); \
+		GEOSFree(wkt); \
+		GEOSWKTWriter_destroy(wktwriter); \
+  } while (0);
+#else /* POSTGIS_DEBUG_LEVEL <= 0 */
+/* Empty prototype that can be optimised away by the compiler
+ * for non-debug builds */
+        ((void) 0)
+#endif /*POSTGIS_DEBUG_LEVEL <= 0 */
Summary of changes:
 liblwgeom/cunit/cu_node.c    |  9 +++++++
 liblwgeom/lwgeom_geos.h      | 27 +++++++++++++++++++
 liblwgeom/lwgeom_geos_node.c | 64 ++++++++++++++++++++++++++++++++++----------
 3 files changed, 86 insertions(+), 14 deletions(-)
hooks/post-receive
