[PostGIS] #5674: ST_CoveredBy(geography, geography) not working for covered polygon with hole
PostGIS trac at osgeo.org
Wed Mar 13 15:47:21 PDT 2024
hole
  Reporter:  dbiernacka  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 3.2.8
 Component:  postgis     |    Version:  3.4.x
Resolution:              |   Keywords:
Comment (by robe):
 I'm not seeing anything on that fiddle.
 I can reproduce on my system running (I get a false)
 POSTGIS="3.4.1 3.4.1" [EXTENSION] PGSQL="150" GEOS="3.12.1-CAPI-1.18.1"
 PROJ="8.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=C:\Users\paragon\AppData\Local/proj
 DATABASE_PATH=C:\Program
 Files\PostgreSQL\15\share\contrib\postgis-3.4\proj\proj.db"
 LIBXML="2.9.14" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0
 (Internal)" (core procs from "3.3.2 3.3.2" need upgrade)
 But on my dev systems I get true.
 Both my dev windows system running
 POSTGIS="3.5.0dev 3.4.0rc1-1002-g10e23c724" [EXTENSION] PGSQL="160"
 GEOS="3.12.2dev-CAPI-1.18.2" (compiled against GEOS 3.13.0) PROJ="8.2.1
 USER_WRITABLE_DIRECTORY=C:\Users\lr\AppData\Local/proj
 DATABASE_PATH=C:\ming64gcc81\projects\proj\rel-
 proj-8.2.1w64gcc81/share/proj/proj.db" LIBXML="2.9.14" LIBJSON="0.12"
 LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)" (core procs from "3.5.0dev
 3.4.0rc1-1009-g4b1f87175" need upgrade)
 and a linux dev system running:
 POSTGIS="3.5.0dev 3.4.0rc1-972-ga832b8598" [EXTENSION] PGSQL="160"
 GEOS="3.13.0dev-CAPI-1.18.0" PROJ="9.3.1 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/share/proj/proj.db" GDAL="GDAL 3.8.1, released
 2023/11/28" LIBXML="2.9.14" LIBJSON="0.17" LIBPROTOBUF="1.4.1"
 3.4.0rc1-1013-g1284f168d" need upgrade) RASTER (raster lib from "3.5.0dev
 3.4.0rc1-1013-g1284f168d" need upgrade) (raster procs from "3.5.0dev
 So I'm guessing this issue was probably fixed recently.  Your 3.2.3 is not
 latest stable for 3.2, Latest 3.2 is 3.2.7
 Going to close this out as soon as I find the patch that fixed it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5674#comment:4>
