[PostGIS] #5693: Database server kill thread
PostGIS trac at osgeo.org
Fri Mar 8 11:49:31 PST 2024
 Reporter:  dap42    |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.4.3
Component:  postgis  |    Version:  3.4.x
 Keywords:           |
 If I run the query
 select st_setUpperLeft(rast,st_upperLeftx( r.rast), st_upperLefty(r.rast))
 from windproc , (select rast from rtab limit 1) r;
 in psql -d windproc
 PSQL drops the connection
 Looking at the postgresql log, gives  ie the database thread dies.  No
 user call should be able to kill a database.
 select st_upperLeftx(rast), st_upperLefty(rast) from rtab;
 Works as expected
 As does
 select st_setUpperLeft(cr.rast,st_upperLeftx( r.rast),
 st_upperLefty(r.rast)) from colour_ras cr, (select rast from rtab limit 1)
 r;
 windproc=# \d windproc;
                                         Table "public.windproc"
     Column    |           Type           | Collation | Nullable |
 Default
  id           | integer                  |           | not null |
 nextval('windproc_id_seq'::regclass)
  lat          | real                     |           |          |
  lon          | real                     |           |          |
  uwnd         | real                     |           |          |
  vwnd         | real                     |           |          |
  angle        | real                     |           |          |
  speed        | real                     |           |          |
  reading_time | timestamp with time zone |           |          |
  geom         | geometry(Point,4326)     |           |          |
  new_lon      | real                     |           |          |
  new_lat      | real                     |           |          |
 Indexes:
     "windproc_pkey" PRIMARY KEY, btree (id)
     "idx_reading_time" btree (timezone('UTC'::text, reading_time))
     "windproc_id_idx" btree (id)
 Windproc is
 2024-03-08 13:46:21.877 GMT [2420] LOG:  checkpoint complete: wrote 3
 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.020 s,
 sync=0.007 s, total=0.078 s; sync files=2, longest=0.004 s, average=0.004
 s; distance=0 kB, estimate=0 kB; lsn=2/474B8D58, redo lsn=2/474B8D20
 2024-03-08 19:16:27.674 GMT [2420] LOG:  checkpoint starting: time
 2024-03-08 19:16:28.983 GMT [15501] dp42 at windproc LOG:  could not send
 data to client: Broken pipe
 2024-03-08 19:16:28.983 GMT [15501] dp42 at windproc STATEMENT:  select
 st_setUpperLeft(rast,st_upperLeftx( r.rast), st_upperLefty(r.rast)) from
 2024-03-08 19:16:28.983 GMT [15501] dp42 at windproc FATAL:  connection to
 client lost
 2024-03-08 19:16:31.817 GMT [2420] LOG:  checkpoint complete: wrote 41
 buffers (0.3%); 0 WAL file(s) added, 0 removed, 0 recycled; write=4.043 s,
 sync=0.026 s, total=4.146 s; sync files=34, longest=0.010 s, average=0.001
 s; distance=181 kB, estimate=181 kB; lsn=2/474E6450, redo lsn=2/474E6418
 postgres version PostgreSQL 16.2 (Ubuntu 16.2-1.pgdg23.10+1) on x86_64-pc-
 linux-gnu, compiled by gcc (Ubuntu 13.2.0-4ubuntu3) 13.2.0, 64-bit
  POSTGIS="3.4.2 c19ce56" [EXTENSION] PGSQL="160" GEOS="3.12.0-CAPI-1.18.0"
 PROJ="9.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
 GDAL="GDAL 3.7.1, released 2023/07/06" LIBXML="2.9.14" LIBJSON="0.17"
 LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)" (core procs from "3.4.1
 ca035b9" need upgrade) RASTER (raster procs from "3.4.1 ca035b9" need
 upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5693>
