[PostGIS] #5693: Database server kill thread
PostGIS trac at osgeo.org
Thu Mar 14 07:21:31 PDT 2024
  Reporter:  dap42    |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.4.3
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by robe):
 Looks like you are running out of data scripts.
 Can you run
 SELECT postgis_extensions_upgrade();
 To bring your scripts up to date.  I doubt that is the issue, but I have
 seen this kind of problem for example when someone is running a 3.2
 scripts against 3.3  libs.
 Also if you can provide a sample of data to replicate that would help.
 For what it's worth, I can't run your example because your rast's aren't
 full qualified so there is an ambiguous reference.
 I had to change to:
 select st_setUpperLeft(windproc.rast,st_upperLeftx( r.rast),
 st_upperLefty(r.rast)) from windproc , (select rast from rtab limit 1) r;
 But can't replicate your issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5693#comment:1>
