[SCM] PostGIS branch master updated. 3.4.0rc1-998-gb7990ecf8
Fri Mar 8 13:14:09 PST 2024
the project "PostGIS".
       via  b7990ecf8b6981f4a20e7121d0e75222075df6e9 (commit)
      from  7bd482a696fd4ac419bf76f4483143112b0396d5 (commit)
revisions in full, below.
commit b7990ecf8b6981f4a20e7121d0e75222075df6e9
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Mar 8 13:13:38 2024 -0800
    Calculate sphere area using the spheroid code,
    but with a spherical initialization. Remove
    no longer used code. References #5671
diff --git a/liblwgeom/cunit/cu_geodetic.c b/liblwgeom/cunit/cu_geodetic.c
index 12506476d..5e89aef3b 100644
--- a/liblwgeom/cunit/cu_geodetic.c
+++ b/liblwgeom/cunit/cu_geodetic.c
@@ -1564,8 +1564,9 @@ static void test_lwgeom_area_sphere(void)
 	double area;
 	SPHEROID s;
-	/* Init to WGS84 */
-	spheroid_init(&s, WGS84_MAJOR_AXIS, WGS84_MINOR_AXIS);
+	/* Init to Sphere */
+	spheroid_init(&s, WGS84_RADIUS, WGS84_RADIUS);
+	s.a = s.b = s.radius;
 	/* Simple case */
 	lwg = lwgeom_from_wkt("POLYGON((1 1, 1 2, 2 2, 2 1, 1 1))", LW_PARSER_CHECK_NONE);
@@ -1577,17 +1578,17 @@ static void test_lwgeom_area_sphere(void)
 	/* Robustness tests, from ticket #3393 */
 	lwg = lwgeom_from_wkt("POLYGON((0 78.703946026663,0 0,179.999997913235 0,179.999997913235 -33.0888306884702,0 78.703946026663))", LW_PARSER_CHECK_NONE);
 	area = lwgeom_area_sphere(lwg, &s);
-	CU_ASSERT_DOUBLE_EQUAL(area, 127516467322130, 1.0);
+	CU_ASSERT_DOUBLE_EQUAL(area, 127516466960671, 1.0);
 	lwgeom_free(lwg);
 	lwg = lwgeom_from_wkt("POLYGON((0 78.703946026662,0 0,179.999997913235 0,179.999997913235 -33.0888306884702,0 78.703946026662))", LW_PARSER_CHECK_NONE);
 	lwgeom_free(lwg);
 	lwg = lwgeom_from_wkt("POLYGON((0 78.703946026664,0 0,179.999997913235 0,179.999997913235 -33.0888306884702,0 78.703946026664))", LW_PARSER_CHECK_NONE);
 	lwgeom_free(lwg);
 	/* end #3393 */
diff --git a/liblwgeom/lwgeodetic.c b/liblwgeom/lwgeodetic.c
index 982e4e4af..689d4c070 100644
--- a/liblwgeom/lwgeodetic.c
+++ b/liblwgeom/lwgeodetic.c
@@ -1805,39 +1805,6 @@ lwgeom_segmentize_sphere(const LWGEOM *lwg_in, double max_seg_length)
-* Returns the area of the ring (ring must be closed) in square radians (surface of
-* the sphere is 4*PI).
-double
-ptarray_area_sphere(const POINTARRAY *pa)
-	uint32_t i;
-	const POINT2D *p;
-	GEOGRAPHIC_POINT a, b, c;
-	double area = 0.0;
-	/* Return zero on nonsensical inputs */
-	if ( ! pa || pa->npoints < 4 )
-		return 0.0;
-	p = getPoint2d_cp(pa, 0);
-	geographic_point_init(p->x, p->y, &a);
-	p = getPoint2d_cp(pa, 1);
-	geographic_point_init(p->x, p->y, &b);
-	for ( i = 2; i < pa->npoints-1; i++ )
-		p = getPoint2d_cp(pa, i);
-		geographic_point_init(p->x, p->y, &c);
-		area += sphere_signed_area(&a, &b, &c);
-		b = c;
-	return fabs(area);
 static double ptarray_distance_spheroid(const POINTARRAY *pa1, const POINTARRAY *pa2, const SPHEROID *s, double tolerance, int check_intersection)
 	GEOGRAPHIC_EDGE e1, e2;
@@ -2029,67 +1996,14 @@ static double ptarray_distance_spheroid(const POINTARRAY *pa1, const POINTARRAY
-* Calculate the area of an LWGEOM. Anything except POLYGON, MULTIPOLYGON
-* and GEOMETRYCOLLECTION return zero immediately. Multi's recurse, polygons
-* calculate external ring area and subtract internal ring area. A GBOX is
-* required to calculate an outside point.
+* Delegate to the spheroid function with a spherically
+* parameterized spheroid.
 double lwgeom_area_sphere(const LWGEOM *lwgeom, const SPHEROID *spheroid)
-	int type;
-	double radius2 = spheroid->radius * spheroid->radius;
-	assert(lwgeom);
-	/* No area in nothing */
-	if ( lwgeom_is_empty(lwgeom) )
-		return 0.0;
-	/* Read the geometry type number */
-	type = lwgeom->type;
-	/* Anything but polygons and collections returns zero */
-	if ( ! ( type == POLYGONTYPE || type == MULTIPOLYGONTYPE || type == COLLECTIONTYPE ) )
-		return 0.0;
-	/* Actually calculate area */
-	if ( type == POLYGONTYPE )
-		LWPOLY *poly = (LWPOLY*)lwgeom;
-		uint32_t i;
-		/* Just in case there's no rings */
-		if ( poly->nrings < 1 )
-			return 0.0;
-		/* First, the area of the outer ring */
-		area += radius2 * ptarray_area_sphere(poly->rings[0]);
-		/* Subtract areas of inner rings */
-		for ( i = 1; i < poly->nrings; i++ )
-			area -= radius2 * ptarray_area_sphere(poly->rings[i]);
-		return area;
-	/* Recurse into sub-geometries to get area */
-	if ( type == MULTIPOLYGONTYPE || type == COLLECTIONTYPE )
-		LWCOLLECTION *col = (LWCOLLECTION*)lwgeom;
-		uint32_t i;
-		for ( i = 0; i < col->ngeoms; i++ )
-			area += lwgeom_area_sphere(col->geoms[i], spheroid);
-		return area;
-	/* Shouldn't get here. */
-	return 0.0;
+	SPHEROID s;
+	return lwgeom_area_spheroid(lwgeom, &s);
diff --git a/liblwgeom/lwgeodetic.h b/liblwgeom/lwgeodetic.h
index 6364db210..39053ef5f 100644
--- a/liblwgeom/lwgeodetic.h
+++ b/liblwgeom/lwgeodetic.h
@@ -128,7 +128,6 @@ int lwline_covers_lwpoint(const LWLINE* lwline, const LWPOINT* lwpoint);
 int lwpoly_intersects_line(const LWPOLY* lwpoly, const POINTARRAY* line);
 int lwpoly_pt_outside(const LWPOLY *poly, POINT2D *pt_outside);
 int ptarray_point_in_ring(const POINTARRAY *pa, const POINT2D *pt_outside, const POINT2D *pt_to_test);
-double ptarray_area_sphere(const POINTARRAY *pa);
 double latitude_degrees_normalize(double lat);
 double longitude_degrees_normalize(double lon);
 double ptarray_length_spheroid(const POINTARRAY *pa, const SPHEROID *s);
diff --git a/postgis/geography_measurement.c b/postgis/geography_measurement.c
index dc8bde060..2181d3c3c 100644
--- a/postgis/geography_measurement.c
+++ b/postgis/geography_measurement.c
@@ -539,10 +539,7 @@ Datum geography_area(PG_FUNCTION_ARGS)
 	/* Calculate the area */
-	if ( use_spheroid )
-		area = lwgeom_area_spheroid(lwgeom, &s);
-	else
-		area = lwgeom_area_sphere(lwgeom, &s);
+	area = lwgeom_area_spheroid(lwgeom, &s);
 	/* Clean up */
 	lwgeom_free(lwgeom);
Summary of changes:
 liblwgeom/cunit/cu_geodetic.c   | 11 ++---
 liblwgeom/lwgeodetic.c          | 96 +++--------------------------------------
 liblwgeom/lwgeodetic.h          |  1 -
 postgis/geography_measurement.c |  5 +--
 4 files changed, 12 insertions(+), 101 deletions(-)
hooks/post-receive
