[SCM] PostGIS branch master updated. 3.4.0rc1-1012-gd61d5114e
Wed Mar 13 02:46:17 PDT 2024
the project "PostGIS".
       via  d61d5114e7d031c622303669bb42378b44466e10 (commit)
      from  fc677a0c7e0fe38535f2b3f44967c021ed51e717 (commit)
revisions in full, below.
commit d61d5114e7d031c622303669bb42378b44466e10
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Mar 1 22:51:00 2024 +0100
    Use a macro to return error from topology backend
diff --git a/liblwgeom/topo/liblwgeom_topo_internal.h b/liblwgeom/topo/liblwgeom_topo_internal.h
index 04d55175c..39dec255f 100644
--- a/liblwgeom/topo/liblwgeom_topo_internal.h
+++ b/liblwgeom/topo/liblwgeom_topo_internal.h
@@ -48,6 +48,21 @@
+ * Use in backend implementation to print error from backend
+#define PGTOPO_BE_ERROR() lwerror(\
+	"[%s:%s:%d] Backend error: %s", \
+	__FILE__, __func__, __LINE__, \
+	lwt_be_lastErrorMessage(topo->be_iface))
+#define PGTOPO_BE_ERRORF(msg, ...) lwerror(\
+	"[%s:%s:%d] Backend error (" msg "): %s", \
+	lwt_be_lastErrorMessage(topo->be_iface), \
+	__VA_ARGS__ )
 struct LWT_BE_IFACE_T
   const LWT_BE_DATA *data;
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index b84f7ed63..451701903 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -383,7 +383,7 @@ lwt_be_ExistsCoincidentNode(LWT_TOPOLOGY* topo, LWPOINT* pt)
 	lwt_be_getNodeWithinDistance2D(topo, pt, 0, &exists, 0, -1);
 	if (exists == UINT64_MAX)
-		lwerror("Backend error: %s", lwt_be_lastErrorMessage(topo->be_iface));
+		PGTOPO_BE_ERROR();
 		return 0;
   return exists;
@@ -396,7 +396,7 @@ lwt_be_ExistsEdgeIntersectingPoint(LWT_TOPOLOGY* topo, LWPOINT* pt)
 	lwt_be_getEdgeWithinDistance2D(topo, pt, 0, &exists, 0, -1);
 		return 0;
   return exists;
@@ -554,7 +554,7 @@ _lwt_AddIsoNode( LWT_TOPOLOGY* topo, LWT_ELEMID face,
     foundInFace = lwt_GetFaceContainingPoint(topo, pt); /*x*/
     if ( foundInFace == -1 ) {
+      PGTOPO_BE_ERRORF("lwt_GetFaceContainingPoint(%" LWTFMT_ELEMID ") returned -1", pt);
       return -1;
     if ( foundInFace == -1 ) foundInFace = 0;
@@ -579,7 +579,7 @@ _lwt_AddIsoNode( LWT_TOPOLOGY* topo, LWT_ELEMID face,
   node.geom = pt;
   if ( ! lwt_be_insertNodes(topo, &node, 1) )
     return -1;
@@ -628,7 +628,7 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
   LWDEBUGF(1, "lwt_be_getNodeWithinBox2D returned %d nodes", num_nodes);
   if (num_nodes == UINT64_MAX)
 	  return -1;
   for ( i=0; i<num_nodes; ++i )
@@ -658,7 +658,7 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
   if (num_edges == UINT64_MAX)
 	  GEOSGeom_destroy(edgegg);
 	  return -1;
   for ( i=0; i<num_edges; ++i )
@@ -822,7 +822,7 @@ lwt_AddIsoEdge( LWT_TOPOLOGY* topo, LWT_ELEMID startNode,
                                              LWT_COL_NODE_ALL );
     return -1;
   else if ( num_nodes < 2 )
@@ -896,7 +896,7 @@ lwt_AddIsoEdge( LWT_TOPOLOGY* topo, LWT_ELEMID startNode,
   newedge.edge_id = lwt_be_getNextEdgeId( topo );
   if ( newedge.edge_id == -1 ) {
     return -1;
@@ -912,7 +912,7 @@ lwt_AddIsoEdge( LWT_TOPOLOGY* topo, LWT_ELEMID startNode,
   int ret = lwt_be_insertEdges(topo, &newedge, 1);
   if ( ret == -1 ) {
     return -1;
   } else if ( ret == 0 ) {
     lwerror("Insertion of split edge failed (no reason)");
@@ -932,7 +932,7 @@ lwt_AddIsoEdge( LWT_TOPOLOGY* topo, LWT_ELEMID startNode,
   ret = lwt_be_updateNodesById(topo, updated_nodes, 2,
                                LWT_COL_NODE_CONTAINING_FACE);
   if ( ret == -1 ) {
     return -1;
@@ -956,7 +956,7 @@ _lwt_EdgeSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge, LWPOINT* pt, int skipISOChe
     LWDEBUGF(1, "lwt_be_getEdgeById returned NULL and set i=%d", i);
     if (i == UINT64_MAX)
       return NULL;
     else if ( i == 0 )
@@ -1052,7 +1052,7 @@ lwt_ModEdgeSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
     _lwt_release_edges(oldedge, 1);
     lwcollection_free(split_col);
     return -1;
   if (node.node_id == -1) {
@@ -1069,7 +1069,7 @@ lwt_ModEdgeSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   if ( newedge1.edge_id == -1 ) {
     return -1;
   newedge1.start_node = node.node_id;
@@ -1091,7 +1091,7 @@ lwt_ModEdgeSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   if ( ret == -1 ) {
     return -1;
@@ -1118,7 +1118,7 @@ lwt_ModEdgeSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   if ( ret == -1 ) {
     return -1;
@@ -1145,7 +1145,7 @@ lwt_ModEdgeSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   if ( ret == -1 ) {
     return -1;
@@ -1160,7 +1160,7 @@ lwt_ModEdgeSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   if ( ret == -1 ) {
     return -1;
@@ -1169,7 +1169,7 @@ lwt_ModEdgeSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   if ( ! ret ) {
     return -1;
@@ -1209,7 +1209,7 @@ lwt_NewEdgesSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
     return -1;
@@ -1227,7 +1227,7 @@ lwt_NewEdgesSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   if ( ret == -1 ) {
     return -1;
@@ -1236,14 +1236,14 @@ lwt_NewEdgesSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   if ( newedges[0].edge_id == -1 ) {
     return -1;
   newedges[1].edge_id = lwt_be_getNextEdgeId(topo);
   if ( newedges[1].edge_id == -1 ) {
     return -1;
@@ -1293,7 +1293,7 @@ lwt_NewEdgesSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   ret = lwt_be_insertEdges(topo, newedges, 2);
   if ( ret == -1 ) {
     return -1;
@@ -1314,7 +1314,7 @@ lwt_NewEdgesSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   if ( ret == -1 ) {
     return -1;
@@ -1328,7 +1328,7 @@ lwt_NewEdgesSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   if ( ret == -1 ) {
     return -1;
@@ -1342,7 +1342,7 @@ lwt_NewEdgesSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   if ( ret == -1 ) {
     return -1;
@@ -1356,7 +1356,7 @@ lwt_NewEdgesSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   if ( ret == -1 ) {
     lwcollection_release(split_col);
     return -1;
@@ -1365,7 +1365,7 @@ lwt_NewEdgesSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
   if ( ! ret ) {
     return -1;
@@ -1527,7 +1527,7 @@ _lwt_FindAdjacentEdges( LWT_TOPOLOGY* topo, LWT_ELEMID node, edgeend *data,
   edges = lwt_be_getEdgeByNode( topo, &node, &numedges, LWT_COL_EDGE_ALL );
   if (numedges == UINT64_MAX)
 	  return 0;
@@ -1776,7 +1776,7 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
   lwfree( edge_ids );
     return NULL;
   else if ( i != numedges )
@@ -1879,9 +1879,8 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
 	signed_edge_ids = lwt_be_getRingEdges(topo, sedge, &num_signed_edge_ids, 0);
 	if (!signed_edge_ids)
-		lwerror("Backend error (no ring edges for edge %" LWTFMT_ELEMID "): %s",
-			sedge,
-			lwt_be_lastErrorMessage(topo->be_iface));
+		//PGTOPO_BE_ERRORF("no ring edges for edge %" LWTFMT_ELEMID, sedge);
 		return -2;
   LWDEBUGF(1, "getRingEdges returned %d edges", num_signed_edge_ids);
@@ -1956,7 +1955,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
         lwfree( signed_edge_ids );
         lwpoly_free(shell); /* NOTE: owns shellbox above */
         return -2;
       if ( ret != 1 )
@@ -1984,7 +1983,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
       lwpoly_free(shell); /* NOTE: owns shellbox */
       return -2;
     if ( nfaces != 1 )
@@ -2007,7 +2006,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
     return -2;
   if ( ret != 1 )
@@ -2048,7 +2047,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
   if (numfaceedges == UINT64_MAX)
 	  lwfree(signed_edge_ids);
 	  return -2;
   LWDEBUGF(1, "_lwt_AddFaceSplit: lwt_be_getEdgeByFace(%d) returned %d edges", face, numfaceedges);
@@ -2161,7 +2160,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
       if ( ret == -1 )
         return -2;
       if ( ret != forward_edges_count )
@@ -2182,7 +2181,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
       if ( ret == -1 )
         return -2;
       if ( ret != backward_edges_count )
@@ -2209,7 +2208,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
   if (numisonodes == UINT64_MAX)
 	  return -2;
   if ( numisonodes ) {
@@ -2254,7 +2253,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
       if ( ret == -1 ) {
         return -2;
@@ -2375,7 +2374,7 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
   endpoints = lwt_be_getNodeById( topo, node_ids, &num_nodes, LWT_COL_NODE_ALL );
 	  return -1;
@@ -2463,7 +2462,7 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
     return -1;
@@ -2570,7 +2569,7 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
   if ( ret == -1 ) {
     return -1;
@@ -2603,7 +2602,7 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
         &updedge, updfields,
         NULL, 0);
     if ( ret == -1 ) {
       return -1;
@@ -2632,7 +2631,7 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
         NULL, 0);
     if ( ret == -1 ) {
       return -1;
@@ -2652,7 +2651,7 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
         &updnode, LWT_COL_NODE_CONTAINING_FACE,
         NULL, 0);
     if ( ret == -1 ) {
       return -1;
@@ -2664,7 +2663,7 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
         NULL, 0);
     if ( ret == -1 ) {
       return -1;
@@ -2724,7 +2723,7 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
     ret = lwt_be_updateTopoGeomFaceSplit(topo, newedge.face_left,
                                          newface, newface1);
     if ( ret == 0 ) {
       return -1;
@@ -2733,7 +2732,7 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
       /* drop old face from the face table */
       ret = lwt_be_deleteFacesById(topo, &(newedge.face_left), 1);
       if ( ret == -1 ) {
         return -1;
@@ -2834,7 +2833,7 @@ lwt_GetFaceGeometry(LWT_TOPOLOGY* topo, LWT_ELEMID faceid)
   edges = lwt_be_getEdgeByFace( topo, &faceid, &numfaceedges, fields, NULL );
 	  return NULL;
   LWDEBUGF(1, "lwt_GetFaceGeometry: lwt_be_getEdgeByFace returned %d edges", numfaceedges);
@@ -2845,7 +2844,7 @@ lwt_GetFaceGeometry(LWT_TOPOLOGY* topo, LWT_ELEMID faceid)
     face = lwt_be_getFaceById(topo, &faceid, &i, LWT_COL_FACE_FACE_ID);
 	    return NULL;
     if ( i == 0 ) {
@@ -3081,7 +3080,7 @@ lwt_GetFaceEdges(LWT_TOPOLOGY* topo, LWT_ELEMID face_id, LWT_ELEMID **out )
   edges = lwt_be_getEdgeByFace( topo, &face_id, &numfaceedges, fields, NULL );
 	  return -1;
   if ( ! numfaceedges ) return 0; /* no edges in output */
@@ -3248,7 +3247,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
       return -1;
     else if ( i == 0 )
@@ -3366,7 +3365,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
   if (numnodes == UINT64_MAX)
 	  return -1;
   // 3. if any node beside endnodes are found:
@@ -3424,7 +3423,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
   if (res == -1)
     return -1;
   if (!res)
@@ -3528,7 +3527,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
         while ( facestoupdate-- ) lwfree(faces[facestoupdate].mbr);
 		    if (updatedFaces == UINT64_MAX)
 		    else
 			    lwerror("Unexpected error: %d faces updated when expecting 1", updatedFaces);
 		    return -1;
@@ -3557,7 +3556,7 @@ _lwt_GetIsoNode(LWT_TOPOLOGY* topo, LWT_ELEMID nid)
   node = lwt_be_getNodeById( topo, &nid, &n, LWT_COL_NODE_CONTAINING_FACE );
   if (n == UINT64_MAX)
 	  return 0;
   if ( n < 1 ) {
@@ -3602,7 +3601,7 @@ lwt_MoveIsoNode(LWT_TOPOLOGY* topo, LWT_ELEMID nid, LWPOINT *pt)
    * See https://trac.osgeo.org/postgis/ticket/3232 */
   newPointFace = lwt_GetFaceContainingPoint(topo, pt);
   if ( newPointFace == -1 ) {
     return -1;
   if ( node->containing_face != newPointFace )
@@ -3618,7 +3617,7 @@ lwt_MoveIsoNode(LWT_TOPOLOGY* topo, LWT_ELEMID nid, LWPOINT *pt)
                                LWT_COL_NODE_GEOM);
   if ( ret == -1 ) {
     lwfree(node);
     return -1;
@@ -3639,7 +3638,7 @@ lwt_RemoveIsoNode(LWT_TOPOLOGY* topo, LWT_ELEMID nid)
   if ( n == -1 )
     lwfree(node);
     return -1;
   if ( n != 1 )
@@ -3677,7 +3676,7 @@ lwt_RemIsoEdge(LWT_TOPOLOGY* topo, LWT_ELEMID id)
                                             LWT_COL_EDGE_FACE_RIGHT );
   if ( ! edge )
     return -1;
   if ( ! n )
@@ -3709,7 +3708,7 @@ lwt_RemIsoEdge(LWT_TOPOLOGY* topo, LWT_ELEMID id)
   edge = lwt_be_getEdgeByNode( topo, nid, &n, LWT_COL_EDGE_EDGE_ID );
   if ((n == UINT64_MAX) || (edge == NULL))
 	  return -1;
   for (i = 0; i < n; ++i)
@@ -3727,7 +3726,7 @@ lwt_RemIsoEdge(LWT_TOPOLOGY* topo, LWT_ELEMID id)
   n = lwt_be_deleteEdges( topo, &deledge, LWT_COL_EDGE_EDGE_ID );
     return -1;
   if ( n != 1 )
@@ -3748,7 +3747,7 @@ lwt_RemIsoEdge(LWT_TOPOLOGY* topo, LWT_ELEMID id)
     return -1;
@@ -3858,7 +3857,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
 			return -1;
 		else if (i == 0)
@@ -3900,7 +3899,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
   upd_edge = lwt_be_getEdgeByNode( topo, &(node_ids[0]), &nedges, fields );
   if (nedges == UINT64_MAX)
 	  return -1;
   nedge_left = nedge_right = 0;
@@ -3952,7 +3951,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
       _lwt_release_edges(edge, 1);
       lwfree(upd_edge);
       return -1;
@@ -3965,7 +3964,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
       lwfree(upd_edge);
       return -1;
@@ -4003,7 +4002,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
       faces = lwt_be_getFaceById(topo, face_ids, &nfaces, fields);
       if (nfaces == UINT64_MAX)
 	      return -1;
       GBOX *box1=NULL;
@@ -4074,7 +4073,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
 	if (result == -1)
 		return -1;
 	if (result != 1)
@@ -4093,7 +4092,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
 	if (result == -1)
 		return -1;
 	if (result != 1)
@@ -4114,13 +4113,13 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
       if ( -1 == _lwt_UpdateEdgeFaceRef(topo, edge->face_left, floodface) )
         return -1;
       if ( -1 == _lwt_UpdateNodeFaceRef(topo, edge->face_left, floodface) )
         return -1;
@@ -4130,13 +4129,13 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
       if ( -1 == _lwt_UpdateEdgeFaceRef(topo, edge->face_right, floodface) )
         return -1;
       if ( -1 == _lwt_UpdateNodeFaceRef(topo, edge->face_right, floodface) )
         return -1;
@@ -4157,7 +4156,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
   if (result == -1)
 	  return -1;
@@ -4182,7 +4181,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
 	  if (result == -1)
 		  return -1;
@@ -4200,7 +4199,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
     if (result == -1)
 	    return -1;
@@ -4257,7 +4256,7 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
   edges = lwt_be_getEdgeById(topo, ids, &nedges, LWT_COL_EDGE_ALL);
   if ((nedges == UINT64_MAX) || (edges == NULL))
     return -1;
   for ( i=0; i<nedges; ++i )
@@ -4335,7 +4334,7 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
     if (num_node_edges == UINT64_MAX)
 	    _lwt_release_edges(edges, nedges);
 	    return -1;
     for (i=0; i<num_node_edges; ++i)
@@ -4387,7 +4386,7 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
 	      return -1;
@@ -4525,7 +4524,7 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
       lwline_free(newedge.geom);
       return -1;
     else if (result != 1)
@@ -4547,7 +4546,7 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
 	    return -1;
     else if (result == 0)
@@ -4581,7 +4580,7 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
   if (result == -1)
     return -1;
@@ -4592,7 +4591,7 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
   if (result == -1)
     return -1;
@@ -4605,7 +4604,7 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
     if (result == -1)
       return -1;
@@ -4616,7 +4615,7 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
     if (result == -1)
       return -1;
@@ -4626,7 +4625,7 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
   if (result == -1)
     return -1;
   if ( ! modEdge ) {
@@ -4634,7 +4633,7 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
     if (result == -1)
       return -1;
@@ -4645,7 +4644,7 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
   i = lwt_be_deleteNodesById( topo, &commonnode, 1 );
   if (result == -1)
     return -1;
@@ -4696,7 +4695,7 @@ lwt_GetNodeByPoint(LWT_TOPOLOGY *topo, LWPOINT *pt, double tol)
   elem = lwt_be_getNodeWithinDistance2D(topo, pt, tol, &num, flds, 0);
   if (num == UINT64_MAX)
     return -1;
   else if ( num )
@@ -4731,7 +4730,7 @@ lwt_GetEdgeByPoint(LWT_TOPOLOGY *topo, LWPOINT *pt, double tol)
   elem = lwt_be_getEdgeWithinDistance2D(topo, pt, tol, &num, flds, 0);
     return -1;
   for (i=0; i<num;++i)
@@ -4784,7 +4783,7 @@ lwt_GetFaceByPoint(LWT_TOPOLOGY *topo, const LWPOINT *pt, double tol)
   id = lwt_GetFaceContainingPoint(topo, pt);
   if ( id == -1 ) {
     return -1;
@@ -4808,7 +4807,7 @@ lwt_GetFaceByPoint(LWT_TOPOLOGY *topo, const LWPOINT *pt, double tol)
   elem = lwt_be_getEdgeWithinDistance2D(topo, pt, tol?tol:1e-5, &num, flds, 0);
     return -1;
   for (i=0; i<num; ++i)
@@ -4970,7 +4969,7 @@ _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
 	nodes = lwt_be_getNodeWithinDistance2D(topo, point, tol, &num, flds, 0);
 		return -1;
   if ( num )
@@ -5032,7 +5031,7 @@ _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
   edges = lwt_be_getEdgeWithinDistance2D(topo, point, tol, &num, flds, 0);
     return -1;
   if ( num )
@@ -5283,7 +5282,7 @@ _lwt_GetEqualEdge( LWT_TOPOLOGY *topo, LWLINE *edge, int *forward )
   edges = lwt_be_getEdgeWithinBox2D( topo, qbox, &num, flds, 0 );
     return -1;
   if ( num )
@@ -5441,7 +5440,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
                                LWT_COL_NODE_NODE_ID|LWT_COL_NODE_GEOM );
     if (nn == UINT64_MAX)
       return -1;
     start_point = NULL; end_point = NULL;
@@ -5662,7 +5661,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
     lwgeom_free(noded);
     return NULL;
   LWDEBUGF(1, "Line has %d points, its bbox intersects %d edges bboxes",
@@ -5706,7 +5705,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
     lwgeom_free(noded);
     return NULL;
   LWDEBUGF(1, "Line bbox intersects %d nodes bboxes", numnodes);
@@ -6038,7 +6037,7 @@ lwt_AddPolygon(LWT_TOPOLOGY* topo, LWPOLY* poly, double tol, int* nfaces)
   if (nfacesinbox == UINT64_MAX)
     lwfree(ids);
     return NULL;
@@ -6150,7 +6149,7 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
     /* cberror(topo->be_data, "Error from cb_getClosestEdge"); */
 	  return -1;
@@ -6259,7 +6258,7 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
       edges = lwt_be_getEdgeByNode( topo, &closestNode, &numedges, LWT_COL_EDGE_FACE_LEFT|LWT_COL_EDGE_FACE_RIGHT );
-        lwerror("Backend error from getEdgeByNode: %s", lwt_be_lastErrorMessage(topo->be_iface));
         _lwt_release_edges(closestEdge, 1);
         return -1;
diff --git a/liblwgeom/topo/lwgeom_topo_polygonizer.c b/liblwgeom/topo/lwgeom_topo_polygonizer.c
index 2b0959b82..75b9c4132 100644
--- a/liblwgeom/topo/lwgeom_topo_polygonizer.c
+++ b/liblwgeom/topo/lwgeom_topo_polygonizer.c
@@ -241,7 +241,7 @@ _lwt_FetchAllEdges(LWT_TOPOLOGY *topo, int *numedges)
   *numedges = nelems;
   if (nelems == UINT64_MAX)
 	  return NULL;
   return edge;
@@ -304,7 +304,7 @@ _lwt_UpdateEdgeRingSideFace(LWT_TOPOLOGY *topo, LWT_EDGERING *ring,
       lwfree( forward_edges );
       lwfree( backward_edges );
       return -1;
@@ -327,7 +327,7 @@ _lwt_UpdateEdgeRingSideFace(LWT_TOPOLOGY *topo, LWT_EDGERING *ring,
       return -1;
@@ -595,7 +595,7 @@ _lwt_RegisterFaceOnEdgeSide(LWT_TOPOLOGY *topo, LWT_ISO_EDGE *edge,
     newface.mbr = NULL;
     if ( ret == -1 )
       return -1;
     if ( ret != 1 )
@@ -786,7 +786,7 @@ _lwt_CheckFacesExist(LWT_TOPOLOGY *topo)
   faces = lwt_be_getFaceWithinBox2D( topo, &qbox, &nelems, fields, 1);
 	  return -1;
   if ( faces ) _lwt_release_faces(faces, nelems);
diff --git a/topology/test/regress/st_addedgemodface.sql b/topology/test/regress/st_addedgemodface.sql
index c39424f73..62fdc09d6 100644
--- a/topology/test/regress/st_addedgemodface.sql
+++ b/topology/test/regress/st_addedgemodface.sql
@@ -533,7 +533,13 @@ UPDATE city_data.edge_data
     abs_next_left_edge = 999999
   WHERE edge_id = 5; -- corrupt topology
 -- 2. Try to add an edge closing a ring involving edge 5
+DO $TEST$
+BEGIN
 SELECT ST_AddEdgeModFace('city_data', 5, 7, 'LINESTRING(36 38,41 40)');
+EXCEPTION WHEN OTHERS THEN
+  RAISE EXCEPTION '%', regexp_replace(SQLERRM, '[^]]*] ', '');
+END;
+$TEST$ LANGUAGE 'plpgsql';
 ROLLBACK; -- restores the topology
diff --git a/topology/test/regress/st_addedgemodface_expected b/topology/test/regress/st_addedgemodface_expected
index 8a5cd24b7..26e39df63 100644
--- a/topology/test/regress/st_addedgemodface_expected
+++ b/topology/test/regress/st_addedgemodface_expected
@@ -202,5 +202,5 @@ F32|POLYGON((36 33,36 38,57 38,57 33,36 33))
 F33|POLYGON((38 40,38 43,41 43,41 40,38 40))
 F34|POLYGON((35 25,35 45,63 45,63 25,35 25))
 F35|POLYGON((9 14,9 22,21 22,21 14,9 14))
-ERROR:  Backend error (no ring edges for edge 58): Corrupted topology: ring of edge 58 is topologically non-closed
+ERROR:  Backend error: Corrupted topology: ring of edge 58 is topologically non-closed
 Topology 'city_data' dropped
Summary of changes:
 liblwgeom/topo/liblwgeom_topo_internal.h         |  15 ++
 liblwgeom/topo/lwgeom_topo.c                     | 207 +++++++++++------------
 liblwgeom/topo/lwgeom_topo_polygonizer.c         |  10 +-
 topology/test/regress/st_addedgemodface.sql      |   6 +
 topology/test/regress/st_addedgemodface_expected |   2 +-
 5 files changed, 130 insertions(+), 110 deletions(-)
hooks/post-receive
