[SCM] PostGIS branch master updated. 3.4.0rc1-1013-g1284f168d
Wed Mar 13 05:02:17 PDT 2024
the project "PostGIS".
       via  1284f168d7159c8585b46f9bdfd54c63927f8c9e (commit)
      from  d61d5114e7d031c622303669bb42378b44466e10 (commit)
revisions in full, below.
commit 1284f168d7159c8585b46f9bdfd54c63927f8c9e
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Mar 13 12:19:47 2024 +0100
    Add TopoGeo_LoadGeometry function
    Includes regress test and documentation
    Closes #5667
diff --git a/NEWS b/NEWS
index a828e3583..878fc9099 100644
--- a/NEWS
+++ b/NEWS
@@ -35,6 +35,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
 * New Features *
+  - #5667, TopoGeo_LoadGeometry (Sandro Santilli)
   - #5055, add explicit <> geometry operator to prevent non-unique
            error with <> and != (Paul Ramsey)
   - Add ST_HasZ/ST_HasM (Loïc Bartoletti)
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index bed44ad10..fd9012059 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -1388,7 +1388,12 @@ SELECT topology.AddTopoGeometryColumn('ri_topo', 'ri', 'roads', 'topo', 'LINE');
 			<!-- Optionally add a "See Also" section -->
 			<refsection>
 				<title>See Also</title>
-				<para><xref linkend="AddTopoGeometryColumn"/>, <xref linkend="CreateTopology"/>, <xref linkend="DropTopology"/></para>
+				<para>
+<xref linkend="TopoGeo_LoadGeometry"/>,
+<xref linkend="AddTopoGeometryColumn"/>,
+<xref linkend="CreateTopology"/>,
+<xref linkend="DropTopology"/>
+                </para>
 			</refsection>
 		</refentry>
@@ -1432,6 +1437,7 @@ An existing edge may be split by the snapped point.
 				<para>
 <xref linkend="TopoGeo_AddLineString"/>,
 <xref linkend="TopoGeo_AddPolygon"/>,
 <xref linkend="AddNode"/>,
 </para>
@@ -1481,6 +1487,7 @@ up to caller, see <xref linkend="Topology_StatsManagement"/>.
 				<para>
 <xref linkend="TopoGeo_AddPoint"/>,
 <xref linkend="AddEdge"/>,
 				</para>
@@ -1530,12 +1537,62 @@ up to caller, see <xref linkend="Topology_StatsManagement"/>.
 				<para>
 <xref linkend="AddFace"/>,
 				</para>
 			</refsection>
 		</refentry>
+		<refentry xml:id="TopoGeo_LoadGeometry">
+			<refnamediv>
+				<refname>TopoGeo_LoadGeometry</refname>
+				<refpurpose>Load a geometry into an existing topology, snapping and splitting as needed.</refpurpose>
+			</refnamediv>
+			<refsynopsisdiv>
+				<funcsynopsis>
+					<funcprototype>
+						<funcdef>void <function>TopoGeo_LoadGeometry</function></funcdef>
+						<paramdef><type>varchar </type> <parameter>atopology</parameter></paramdef>
+						<paramdef><type>geometry </type> <parameter>ageom</parameter></paramdef>
+						<paramdef choice="opt"><type>float8 </type> <parameter>tolerance</parameter></paramdef>
+					</funcprototype>
+				</funcsynopsis>
+			</refsynopsisdiv>
+			<refsection>
+                <title>Description</title>
+                <para>
+Loads a geometry into an existing topology.
+The given geometry will snap to existing nodes or edges within given tolerance.
+Existing edges and faces may be split as a consequence of the load.
+                </para>
+                <note><para>
+Updating statistics about topologies being loaded via this function is
+up to caller, see <xref linkend="Topology_StatsManagement"/>.
+                </para></note>
+                <!-- use this format if new function -->
+                <para role="availability" conformance="3.5.0">Availability: 3.5.0</para>
+			</refsection>
+			<!-- Optionally add a "See Also" section -->
+			<refsection>
+				<title>See Also</title>
+				<para>
+<xref linkend="TopoGeo_AddPoint"/>,
+<xref linkend="TopoGeo_AddLineString"/>,
+<xref linkend="TopoGeo_AddPolygon"/>,
+				</para>
+			</refsection>
+		</refentry>
 	</section>
diff --git a/liblwgeom/topo/liblwgeom_topo.h b/liblwgeom/topo/liblwgeom_topo.h
index 276d9d7cf..f4ed175b5 100644
--- a/liblwgeom/topo/liblwgeom_topo.h
+++ b/liblwgeom/topo/liblwgeom_topo.h
@@ -1143,6 +1143,19 @@ int lwt_Polygonize(LWT_TOPOLOGY* topo);
 LWT_ELEMID* lwt_AddPolygon(LWT_TOPOLOGY* topo, LWPOLY* poly, double tol,
                         int* nfaces);
+ * Load a geometry into the topology
+ * The given geometry will snap to existing nodes or edges within given
+ * tolerance. Existing edges or faces may be split by the geometry.
+ * @param topo the topology to operate on
+ * @param geom the geometry to add
+ * @param tol snap tolerance, the topology tolerance will be used if 0
+void lwt_LoadGeometry(LWT_TOPOLOGY* topo, LWGEOM* geom, double tol);
  * ISO signatures here
diff --git a/liblwgeom/topo/liblwgeom_topo_internal.h b/liblwgeom/topo/liblwgeom_topo_internal.h
index 39dec255f..bec421c26 100644
--- a/liblwgeom/topo/liblwgeom_topo_internal.h
+++ b/liblwgeom/topo/liblwgeom_topo_internal.h
@@ -76,7 +76,7 @@ LWT_BE_TOPOLOGY * lwt_be_loadTopologyByName(LWT_BE_IFACE *be, const char *name);
 int lwt_be_freeTopology(LWT_TOPOLOGY *topo);
 LWT_ISO_NODE *lwt_be_getNodeWithinDistance2D(LWT_TOPOLOGY *topo,
-					     LWPOINT *pt,
+					     const LWPOINT *pt,
 					     double dist,
 					     uint64_t *numelems,
 					     int fields,
@@ -92,10 +92,10 @@ void _lwt_release_edges(LWT_ISO_EDGE *edges, int num_edges);
 int lwt_be_updateEdgesById(LWT_TOPOLOGY* topo, const LWT_ISO_EDGE* edges, int numedges, int upd_fields);
 int lwt_be_insertFaces(LWT_TOPOLOGY *topo, LWT_ISO_FACE *face, uint64_t numelems);
-int lwt_be_ExistsCoincidentNode(LWT_TOPOLOGY* topo, LWPOINT* pt);
+int lwt_be_ExistsCoincidentNode(LWT_TOPOLOGY* topo, const LWPOINT* pt);
 int lwt_be_insertNodes(LWT_TOPOLOGY *topo, LWT_ISO_NODE *node, uint64_t numelems);
-int lwt_be_ExistsEdgeIntersectingPoint(LWT_TOPOLOGY* topo, LWPOINT* pt);
+int lwt_be_ExistsEdgeIntersectingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt);
 LWT_ELEMID lwt_be_getNextEdgeId(LWT_TOPOLOGY* topo);
 LWT_ISO_EDGE *lwt_be_getEdgeById(LWT_TOPOLOGY *topo, const LWT_ELEMID *ids, uint64_t *numelems, int fields);
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 451701903..70e72c095 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -155,7 +155,7 @@ lwt_be_getNodeById(LWT_TOPOLOGY *topo, const LWT_ELEMID *ids, uint64_t *numelems
 LWT_ISO_NODE *
-			       LWPOINT *pt,
 			       double dist,
 			       uint64_t *numelems,
 			       int fields,
@@ -377,7 +377,7 @@ lwt_be_getRingEdges(LWT_TOPOLOGY *topo, LWT_ELEMID edge, uint64_t *numedges, uin
 int
-lwt_be_ExistsCoincidentNode(LWT_TOPOLOGY* topo, LWPOINT* pt)
+lwt_be_ExistsCoincidentNode(LWT_TOPOLOGY* topo, const LWPOINT* pt)
 	uint64_t exists = 0;
 	lwt_be_getNodeWithinDistance2D(topo, pt, 0, &exists, 0, -1);
@@ -390,7 +390,7 @@ lwt_be_ExistsCoincidentNode(LWT_TOPOLOGY* topo, LWPOINT* pt)
 int
-lwt_be_ExistsEdgeIntersectingPoint(LWT_TOPOLOGY* topo, LWPOINT* pt)
+lwt_be_ExistsEdgeIntersectingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
 	lwt_be_getEdgeWithinDistance2D(topo, pt, 0, &exists, 0, -1);
@@ -5987,10 +5987,45 @@ lwt_AddLineNoFace(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges)
 	return _lwt_AddLine(topo, line, tol, nedges, 0);
+static void
+lwt_LoadPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol)
+  _lwt_AddPoint(topo, point, tol, 1, NULL);
+static void
+lwt_LoadLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol)
+  LWT_ELEMID* ids;
+  int nedges;
+  /* TODO: avoid allocating edge ids */
+  ids = lwt_AddLine(topo, line, tol, &nedges);
+  if ( nedges > 0 ) lwfree(ids);
+static void
+lwt_LoadPolygon(LWT_TOPOLOGY* topo, const LWPOLY* poly, double tol)
+  uint32_t i;
+  /* Add each ring as an edge */
+  for ( i=0; i<poly->nrings; ++i )
+    LWLINE *line;
+    POINTARRAY *pa;
+    /* TODO: avoid the clone here */
+    pa = ptarray_clone(poly->rings[i]);
+    line = lwline_construct(topo->srid, NULL, pa);
+    lwt_LoadLine(topo, line, tol);
+    lwline_free(line);
 LWT_ELEMID*
 lwt_AddPolygon(LWT_TOPOLOGY* topo, LWPOLY* poly, double tol, int* nfaces)
-  uint32_t i;
   *nfaces = -1; /* error condition, by default */
   int num;
   LWT_ISO_FACE *faces;
@@ -6005,26 +6040,7 @@ lwt_AddPolygon(LWT_TOPOLOGY* topo, LWPOLY* poly, double tol, int* nfaces)
   if ( ! tol ) tol = _LWT_MINTOLERANCE( topo, (LWGEOM*)poly );
   LWDEBUGF(1, "Working tolerance:%.15g", tol);
-  /* Add each ring as an edge */
-  for ( i=0; i<poly->nrings; ++i )
-    LWLINE *line;
-    POINTARRAY *pa;
-    LWT_ELEMID *eids;
-    int nedges;
-    pa = ptarray_clone(poly->rings[i]);
-    line = lwline_construct(topo->srid, NULL, pa);
-    eids = lwt_AddLine( topo, line, tol, &nedges );
-    if ( nedges < 0 ) {
-      /* probably too late as lwt_AddLine invoked lwerror */
-      lwline_free(line);
-      lwerror("Error adding ring %d of polygon", i);
-      return NULL;
-    lwfree(eids);
+  lwt_LoadPolygon(topo, poly, tol);
   -- Find faces covered by input polygon
@@ -6465,3 +6481,49 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
   _lwt_release_edges(closestEdge, 1);
   return containingFace;
+void
+_lwt_LoadGeometryRecursive(LWT_TOPOLOGY* topo, LWGEOM* geom, double tol)
+  switch (geom->type)
+    case POINTTYPE:
+      lwt_LoadPoint(topo, lwgeom_as_lwpoint(geom), tol);
+      return;
+    case LINETYPE:
+      lwt_LoadLine(topo, lwgeom_as_lwline(geom), tol);
+      return;
+    case POLYGONTYPE:
+      lwt_LoadPolygon(topo, lwgeom_as_lwpoly(geom), tol);
+      return;
+    case MULTILINETYPE:
+    case MULTIPOLYGONTYPE:
+    case MULTIPOINTTYPE:
+    case COLLECTIONTYPE:
+      LWCOLLECTION *coll;
+      uint32_t i;
+      coll = (LWCOLLECTION *)geom;
+      for (i=0; i<coll->ngeoms; i++)
+        _lwt_LoadGeometryRecursive(topo, coll->geoms[i], tol);
+      return;
+		default:
+			lwerror("%s: Unsupported geometry type: %s", __func__,
+			        lwtype_name(geom->type));
+			return;
+void
+lwt_LoadGeometry(LWT_TOPOLOGY* topo, LWGEOM* geom, double tol)
+	_lwt_LoadGeometryRecursive(topo, geom, tol);
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 0a49edba4..192fd7f9a 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -5137,7 +5137,7 @@ Datum TopoGeo_AddLinestring(PG_FUNCTION_ARGS)
     POSTGIS_DEBUG(1, "Calling lwt_AddLine");
     elems = lwt_AddLine(topo, ln, tol, &nelems);
-    POSTGIS_DEBUG(1, "lwt_AddLine* returned");
+    POSTGIS_DEBUG(1, "lwt_AddLine returned");
     lwgeom_free(lwgeom);
     PG_FREE_IF_COPY(geom, 1);
     lwt_FreeTopology(topo);
@@ -5618,3 +5618,59 @@ Datum RegisterMissingFaces(PG_FUNCTION_ARGS)
   PG_RETURN_NULL();
+/*  TopoGeo_LoadGeometry(atopology, geom, tolerance) */
+Datum TopoGeo_LoadGeometry(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(TopoGeo_LoadGeometry);
+  text* toponame_text;
+  char* toponame;
+  double tol;
+  GSERIALIZED *geom;
+  LWGEOM *lwgeom;
+  LWT_TOPOLOGY *topo;
+  toponame_text = PG_GETARG_TEXT_P(0);
+  toponame = text_to_cstring(toponame_text);
+  PG_FREE_IF_COPY(toponame_text, 0);
+  geom = PG_GETARG_GSERIALIZED_P(1);
+  lwgeom = lwgeom_from_gserialized(geom);
+  tol = PG_GETARG_FLOAT8(2);
+  if ( tol < 0 )
+    PG_FREE_IF_COPY(geom, 1);
+    lwpgerror("Tolerance must be >=0");
+    PG_RETURN_NULL();
+  if ( SPI_OK_CONNECT != SPI_connect() )
+    lwpgerror("Could not connect to SPI");
+    PG_RETURN_NULL();
+  topo = lwt_LoadTopology(be_iface, toponame);
+  pfree(toponame);
+  if ( ! topo )
+    /* should never reach this point, as lwerror would raise an exception */
+    SPI_finish();
+    PG_RETURN_NULL();
+  POSTGIS_DEBUG(1, "Calling lwt_LoadGeometry");
+  lwt_LoadGeometry(topo, lwgeom, tol);
+  POSTGIS_DEBUG(1, "lwt_LoadGeometry returned");
+  lwgeom_free(lwgeom);
+  lwt_FreeTopology(topo);
+  POSTGIS_DEBUG(1, "TopoGeo_LoadGeometry calling SPI_finish");
+  SPI_finish();
+  PG_RETURN_VOID();
diff --git a/topology/sql/populate.sql.in b/topology/sql/populate.sql.in
index 96909066e..bd21a513e 100644
--- a/topology/sql/populate.sql.in
+++ b/topology/sql/populate.sql.in
@@ -721,6 +721,19 @@ CREATE OR REPLACE FUNCTION topology.TopoGeo_AddPolygon(atopology varchar, apoly
   LANGUAGE 'c' VOLATILE;
 --} TopoGeo_AddPolygon
+--  TopoGeo_LoadGeometry(toponame, geom, tolerance)
+--  Load a Geometry into a topology
+-- Availability: 3.5.0
+CREATE OR REPLACE FUNCTION topology.TopoGeo_LoadGeometry(atopology varchar, ageom geometry, tolerance float8 DEFAULT 0)
+	RETURNS void AS
+	'MODULE_PATHNAME', 'TopoGeo_LoadGeometry'
+  LANGUAGE 'c' VOLATILE;
+--} TopoGeo_LoadGeometry
 --  TopoGeo_AddGeometry(toponame, geom, tolerance)
@@ -731,7 +744,7 @@ CREATE OR REPLACE FUNCTION topology.TopoGeo_AddGeometry(atopology varchar, ageom
 DECLARE
 BEGIN
-	RAISE EXCEPTION 'TopoGeo_AddGeometry not implemented yet';
+	RAISE EXCEPTION 'TopoGeo_AddGeometry not implemented yet, use TopoGeo_LoadGeometry';
 END
 LANGUAGE 'plpgsql';
diff --git a/topology/test/regress/topogeo_loadgeometry.sql b/topology/test/regress/topogeo_loadgeometry.sql
new file mode 100644
index 000000000..dbb3db8d6
--- /dev/null
+++ b/topology/test/regress/topogeo_loadgeometry.sql
@@ -0,0 +1,108 @@
+SET client_min_messages TO WARNING;
+SELECT NULL FROM topology.CreateTopology('t');
+CREATE FUNCTION t.print_counts(lbl text) RETURNS TEXT
+AS $$
+  SELECT format('%s|%s nodes|%s edges|%s faces',
+    lbl,
+    ( SELECT count(*) FROM t.node ),
+    ( SELECT count(*) FROM t.edge ),
+    ( SELECT count(*) FROM t.face WHERE face_id != 0 )
+$$ LANGUAGE 'sql';
+--            o
+SELECT topology.TopoGeo_LoadGeometry('t', 'POINT(0 0)');
+SELECT t.print_counts('point1');
+--                      o {5,5}
+--            o {0,0}
+SELECT topology.TopoGeo_LoadGeometry('t', 'MULTIPOINT((0 0),(5 5))');
+SELECT t.print_counts('mpoint1');
+--        {0,10}  {5,10}       {10,10}
+--            o----------o-----------o
+--                       o {5,5}
+--         {0,0}         |
+--            o          |
+--                       o {5,-10}
+-- mline1|6 nodes|4 edges|0 faces
+SELECT topology.TopoGeo_LoadGeometry('t', 'MULTILINESTRING((5 -10,5 10),(0 10,10 10))');
+SELECT t.print_counts('mline1');
+--     {-10,20}                              {10,20}
+--         |   .------.{0,16}                    |
+--         |   o------'                          |
+--         |  {-5,15}                            |
+--         |     {0,10}  {5,10}           {10,10}|
+--         |          o---------o----------------o
+--         |                    o {5,5}          |
+--         |       {0,0}        |                |
+--         |          o         |                |
+--         o--------------------o----------------'
+--     {-10,-10}             {5,-10}          {10,-10}
+--   mpoly1|8 nodes|8 edges|3 faces
+SELECT topology.TopoGeo_LoadGeometry('t', 'MULTIPOLYGON(
+  ((-10 -10,10 -10,10 20,-10 20,-10 -10)),
+  ((-5 15,0 15,0 16,-5 16,-5 15))
+SELECT t.print_counts('mpoly1');
+--         |   .------.{0,16}     {8,16} o-------o--------.
+--         |   o------'                  `-------o--------' {12,15}
+--         |  {-5,15}                            |
+--         o----------o---------o----------------o
+--         |                    o {5,5}          |
+--         |       {0,0}        |                |
+--         |          o         |        o       |
+--         |                    |     {8,0}      |
+--   coll1|13 nodes|15 edges|6 faces
+SELECT topology.TopoGeo_LoadGeometry('t', 'GEOMETRYCOLLECTION(
+  POLYGON((8 16,12 16,12 15,8 16,8 16)),
+  MULTIPOINT((8 0)),
+  LINESTRING(-10 10,0 10)
+SELECT t.print_counts('coll1');
+SELECT 'unexpected invalidity', * FROM topology.ValidateTopology('t');
+SELECT NULL FROM topology.DropTopology('t');
diff --git a/topology/test/regress/topogeo_loadgeometry_expected b/topology/test/regress/topogeo_loadgeometry_expected
index 000000000..1467fa7f6
--- /dev/null
+++ b/topology/test/regress/topogeo_loadgeometry_expected
@@ -0,0 +1,5 @@
+point1|1 nodes|0 edges|0 faces
+mpoint1|2 nodes|0 edges|0 faces
+mline1|6 nodes|4 edges|0 faces
+mpoly1|8 nodes|8 edges|3 faces
+coll1|13 nodes|15 edges|6 faces
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 716fe291a..5f148a6ca 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -75,6 +75,7 @@ TESTS += \
 	$(top_srcdir)/topology/test/regress/topogeo_addlinestring.sql \
 	$(top_srcdir)/topology/test/regress/topogeo_addpoint.sql \
 	$(top_srcdir)/topology/test/regress/topogeo_addpolygon.sql \
+	$(top_srcdir)/topology/test/regress/topogeo_loadgeometry.sql \
 	$(top_srcdir)/topology/test/regress/topogeom_addtopogeom.sql \
 	$(top_srcdir)/topology/test/regress/topogeom_edit.sql \
 	$(top_srcdir)/topology/test/regress/topogeometry_srid.sql \
Summary of changes:
 NEWS                                               |   1 +
 doc/extras_topology.xml                            |  59 ++++++++++-
 liblwgeom/topo/liblwgeom_topo.h                    |  13 +++
 liblwgeom/topo/liblwgeom_topo_internal.h           |   6 +-
 liblwgeom/topo/lwgeom_topo.c                       | 110 ++++++++++++++++-----
 topology/postgis_topology.c                        |  58 ++++++++++-
 topology/sql/populate.sql.in                       |  15 ++-
 topology/test/regress/topogeo_loadgeometry.sql     | 108 ++++++++++++++++++++
 .../test/regress/topogeo_loadgeometry_expected     |   5 +
 topology/test/tests.mk                             |   1 +
 10 files changed, 346 insertions(+), 30 deletions(-)
 create mode 100644 topology/test/regress/topogeo_loadgeometry.sql
 create mode 100644 topology/test/regress/topogeo_loadgeometry_expected
hooks/post-receive
