[SCM] PostGIS branch master updated. 3.4.0rc1-1017-gec732bca8
Thu Mar 14 00:17:18 PDT 2024
the project "PostGIS".
       via  ec732bca814f1266a0cfbb60646e4bdbe892c82e (commit)
      from  94e382f007403bea1822d281299c050252287ec1 (commit)
revisions in full, below.
commit ec732bca814f1266a0cfbb60646e4bdbe892c82e
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Mar 14 02:51:31 2024 -0400
    Change woodpecker configs to work on 2.3
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 54f6de9b2..a36ade7a9 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -35,7 +35,7 @@ steps:
   check-xml:
     image: *test_image
     pull: true
-    group: check-xml-and-build-images
+    depends_on: check-xml-and-build-images
     commands:
       - make -C build-docs/doc check
     when:
@@ -43,7 +43,7 @@ steps:
   build-images:
     image: *test_image
     pull: true
     commands:
       - make -C build-docs/doc images
     when:
@@ -51,7 +51,7 @@ steps:
   build-html:
     image: *test_image
     pull: true
-    group: output
+    depends_on: output
     commands:
       - make -C build-docs/doc html
     when:
@@ -59,7 +59,7 @@ steps:
   build-cheatsheets:
     image: *test_image
     pull: true
-    group: output
     commands:
       - make -C build-docs/doc/ cheatsheets
     when:
@@ -67,7 +67,7 @@ steps:
   build-chunked-html:
     image: *test_image
     pull: true
-    group: output
     commands:
     when:
@@ -75,7 +75,7 @@ steps:
   build-pdf:
     image: *test_image
     pull: true
-    group: output
     commands:
       - make -C build-docs/doc/ pdf
     when:
@@ -88,7 +88,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-check-xml
-    group: localized-check-xml
+    depends_on: localized-check-xml
     when:
       path:
         include:
@@ -98,7 +98,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-check-xml
     when:
       path:
         include:
@@ -108,7 +108,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-check-xml
     when:
       path:
         include:
@@ -118,7 +118,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-check-xml
     when:
       path:
         include:
@@ -128,7 +128,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-check-xml
     when:
       path:
         include:
@@ -138,7 +138,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-check-xml
     when:
       path:
         include:
@@ -148,7 +148,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-check-xml
     when:
       path:
         include:
@@ -158,7 +158,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-check-xml
     when:
       path:
         include:
@@ -168,7 +168,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-check-xml
     when:
       path:
         include:
@@ -178,7 +178,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-check-xml
     when:
       path:
         include:
@@ -188,7 +188,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-check-xml
     when:
       path:
         include:
@@ -199,7 +199,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-html
-    group: localized-html
+    depends_on: localized-html
     when:
       path:
         include:
@@ -209,7 +209,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-html
     when:
       path:
         include:
@@ -219,7 +219,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-html
     when:
       path:
         include:
@@ -229,7 +229,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-html
     when:
       path:
         include:
@@ -239,7 +239,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-html
     when:
       path:
         include:
@@ -249,7 +249,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-html
     when:
       path:
         include:
@@ -259,7 +259,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-html
     when:
       path:
         include:
@@ -269,7 +269,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-html
     when:
       path:
         include:
@@ -279,7 +279,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-html
     when:
       path:
         include:
@@ -289,7 +289,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-html
     when:
       path:
         include:
@@ -299,7 +299,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-html
     when:
       path:
         include:
@@ -310,7 +310,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-cheatsheets
-    group: localized-cheatsheets
+    depends_on: localized-cheatsheets
     when:
       path:
         include:
@@ -320,7 +320,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-cheatsheets
     when:
       path:
         include:
@@ -330,7 +330,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-cheatsheets
     when:
       path:
         include:
@@ -340,7 +340,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-cheatsheets
     when:
       path:
         include:
@@ -350,7 +350,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-cheatsheets
     when:
       path:
         include:
@@ -360,7 +360,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-cheatsheets
     when:
       path:
         include:
@@ -370,7 +370,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-cheatsheets
     when:
       path:
         include:
@@ -380,7 +380,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-cheatsheets
     when:
       path:
         include:
@@ -390,7 +390,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-cheatsheets
     when:
       path:
         include:
@@ -400,7 +400,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-cheatsheets
     when:
       path:
         include:
@@ -410,7 +410,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-cheatsheets
     when:
       path:
         include:
@@ -421,7 +421,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-check-cheatsheets
-    group: localized-check-cheatsheets
+    depends_on: localized-check-cheatsheets
     when:
       path:
         include:
@@ -431,7 +431,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-check-cheatsheets
     when:
       path:
         include:
@@ -441,7 +441,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-check-cheatsheets
     when:
       path:
         include:
@@ -451,7 +451,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-check-cheatsheets
     when:
       path:
         include:
@@ -461,7 +461,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-check-cheatsheets
     when:
       path:
         include:
@@ -471,7 +471,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-check-cheatsheets
     when:
       path:
         include:
@@ -481,7 +481,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-check-cheatsheets
     when:
       path:
         include:
@@ -491,7 +491,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-check-cheatsheets
     when:
       path:
         include:
@@ -501,7 +501,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-check-cheatsheets
     when:
       path:
         include:
@@ -511,7 +511,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-check-cheatsheets
     when:
       path:
         include:
@@ -521,7 +521,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-check-cheatsheets
     when:
       path:
         include:
@@ -532,7 +532,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-pdf
-    group: localized-pdf
+    depends_on: localized-pdf
     when:
       path:
         include:
@@ -542,7 +542,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-pdf
     when:
       path:
         include:
@@ -552,7 +552,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-pdf
     when:
       path:
         include:
@@ -562,7 +562,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-pdf
     when:
       path:
         include:
@@ -572,7 +572,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-pdf
     when:
       path:
         include:
@@ -582,7 +582,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-pdf
     when:
       path:
         include:
@@ -592,7 +592,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-pdf
     when:
       path:
         include:
@@ -602,7 +602,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-pdf
     when:
       path:
         include:
@@ -612,7 +612,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-pdf
     when:
       path:
         include:
@@ -622,7 +622,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-pdf
     when:
       path:
         include:
@@ -632,7 +632,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-pdf
     when:
       path:
         include:
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 6064250e8..3d6ac9fd4 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -57,7 +57,7 @@ steps:
   build-pg12:
     image: *test-image
-    group: build
+    depends_on: build
     environment:
       - PGVER=12
     commands:
@@ -66,7 +66,7 @@ steps:
   build-pg15:
     image: *test-image
-    group: build
+    depends_on: build
     environment:
       - PGVER=15
     commands:
   check-pg12:
     image: *test-image
-    group: check
+    depends_on: check
     environment:
       - PGVER=12
     commands:
@@ -85,7 +85,7 @@ steps:
   check-pg15:
     image: *test-image
-    group: check
+    depends_on: check
     environment:
       - PGVER=15
     commands:
@@ -95,7 +95,7 @@ steps:
   installcheck-pg12:
     image: *test-image
-    group: installcheck
+    depends_on: installcheck
     environment:
       - PGVER=12
     commands:
@@ -106,7 +106,7 @@ steps:
   installcheck-pg15:
     image: *test-image
     environment:
       - PGVER=15
     commands:
@@ -117,7 +117,7 @@ steps:
   upgradecheck-pg12:
     image: *test-image
-    group: upgradecheck
+    depends_on: upgradecheck
     environment:
       - PGVER=12
     commands:
   upgradecheck-pg15:
     image: *test-image
     environment:
       - PGVER=15
     commands:
Summary of changes:
 .woodpecker/docs.yml    | 122 ++++++++++++++++++++++++------------------------
 .woodpecker/regress.yml |  16 +++----
 2 files changed, 69 insertions(+), 69 deletions(-)
hooks/post-receive
