[SCM] PostGIS branch master updated. 3.4.0rc1-1019-g2342a3f03
Thu Mar 14 06:58:56 PDT 2024
the project "PostGIS".
       via  2342a3f0348c14ddf1644e1301ca5284e8f964a1 (commit)
       via  9342b64426d6f090743e14d8cf6364f0a632ce5a (commit)
      from  ec732bca814f1266a0cfbb60646e4bdbe892c82e (commit)
revisions in full, below.
commit 2342a3f0348c14ddf1644e1301ca5284e8f964a1
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Mar 14 09:58:53 2024 -0400
    Switch to valid depends on or remove depends on
diff --git a/.woodpecker/docs-localized.yml.in b/.woodpecker/docs-localized.yml.in
index 2831d723f..52ee1d6d6 100644
--- a/.woodpecker/docs-localized.yml.in
+++ b/.woodpecker/docs-localized.yml.in
@@ -3,7 +3,7 @@
     pull: true
     commands:
       - make -C build-docs/doc/po/@LANG@ local- at TARGET@
-    group: @GROUP@
+    #group: @GROUP@
     when:
       path:
         include:
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 086008bac..486083112 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -88,7 +88,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-check-xml
-    depends_on: localized-check-xml
+    #group: localized-check-xml
     when:
       path:
         include:
@@ -98,7 +98,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-check-xml
     when:
       path:
         include:
@@ -108,7 +108,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-check-xml
     when:
       path:
         include:
@@ -118,7 +118,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-check-xml
     when:
       path:
         include:
@@ -128,7 +128,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-check-xml
     when:
       path:
         include:
@@ -138,7 +138,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-check-xml
     when:
       path:
         include:
@@ -148,7 +148,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-check-xml
     when:
       path:
         include:
@@ -158,7 +158,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-check-xml
     when:
       path:
         include:
@@ -168,7 +168,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-check-xml
     when:
       path:
         include:
@@ -178,7 +178,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-check-xml
     when:
       path:
         include:
@@ -188,18 +188,28 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-check-xml
     when:
       path:
         include:
           - "doc/po/ro/*.po"
+  check-xml-uk:
+    image: *test_image
+    pull: true
+    commands:
+      - make -C build-docs/doc/po/uk local-check-xml
+    when:
+      path:
+        include:
+          - "doc/po/uk/*.po"
 ### TARGET html
   html-it_IT:
     image: *test_image
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-html
-    depends_on: localized-html
+    #group: localized-html
     when:
       path:
         include:
@@ -209,7 +219,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-html
     when:
       path:
         include:
@@ -219,7 +229,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-html
     when:
       path:
         include:
@@ -229,7 +239,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-html
     when:
       path:
         include:
@@ -239,7 +249,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-html
     when:
       path:
         include:
@@ -249,7 +259,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-html
     when:
       path:
         include:
@@ -259,7 +269,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-html
     when:
       path:
         include:
@@ -269,7 +279,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-html
     when:
       path:
         include:
@@ -279,7 +289,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-html
     when:
       path:
         include:
@@ -289,7 +299,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-html
     when:
       path:
         include:
@@ -299,18 +309,28 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-html
     when:
       path:
         include:
           - "doc/po/ro/*.po"
+  html-uk:
+    pull: true
+    commands:
+      - make -C build-docs/doc/po/uk local-html
+    when:
+      path:
+        include:
 ### TARGET cheatsheets
   cheatsheets-it_IT:
     image: *test_image
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-cheatsheets
-    depends_on: localized-cheatsheets
+    #group: localized-cheatsheets
     when:
       path:
         include:
@@ -320,7 +340,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-cheatsheets
     when:
       path:
         include:
@@ -330,7 +350,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-cheatsheets
     when:
       path:
         include:
@@ -340,7 +360,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-cheatsheets
     when:
       path:
         include:
@@ -350,7 +370,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-cheatsheets
     when:
       path:
         include:
@@ -360,7 +380,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-cheatsheets
     when:
       path:
         include:
@@ -370,7 +390,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-cheatsheets
     when:
       path:
         include:
@@ -380,7 +400,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-cheatsheets
     when:
       path:
         include:
@@ -390,7 +410,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-cheatsheets
     when:
       path:
         include:
@@ -400,7 +420,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-cheatsheets
     when:
       path:
         include:
@@ -410,18 +430,28 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-cheatsheets
     when:
       path:
         include:
           - "doc/po/ro/*.po"
+  cheatsheets-uk:
+    pull: true
+    commands:
+      - make -C build-docs/doc/po/uk local-cheatsheets
+    when:
+      path:
+        include:
 ### TARGET check-cheatsheets
   check-cheatsheets-it_IT:
     image: *test_image
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-check-cheatsheets
-    depends_on: localized-check-cheatsheets
+    #group: localized-check-cheatsheets
     when:
       path:
         include:
@@ -431,7 +461,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-check-cheatsheets
     when:
       path:
         include:
@@ -441,7 +471,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-check-cheatsheets
     when:
       path:
         include:
@@ -451,7 +481,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-check-cheatsheets
     when:
       path:
         include:
@@ -461,7 +491,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-check-cheatsheets
     when:
       path:
         include:
@@ -471,7 +501,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-check-cheatsheets
     when:
       path:
         include:
@@ -481,7 +511,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-check-cheatsheets
     when:
       path:
         include:
@@ -491,7 +521,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-check-cheatsheets
     when:
       path:
         include:
@@ -501,7 +531,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-check-cheatsheets
     when:
       path:
         include:
@@ -511,7 +541,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-check-cheatsheets
     when:
       path:
         include:
@@ -521,18 +551,28 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-check-cheatsheets
     when:
       path:
         include:
           - "doc/po/ro/*.po"
+  check-cheatsheets-uk:
+    pull: true
+    commands:
+      - make -C build-docs/doc/po/uk local-check-cheatsheets
+    when:
+      path:
+        include:
 ### TARGET pdf
   pdf-it_IT:
     image: *test_image
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-pdf
-    depends_on: localized-pdf
+    #group: localized-pdf
     when:
       path:
         include:
@@ -542,7 +582,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-pdf
     when:
       path:
         include:
@@ -552,7 +592,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-pdf
     when:
       path:
         include:
@@ -562,7 +602,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-pdf
     when:
       path:
         include:
@@ -572,7 +612,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-pdf
     when:
       path:
         include:
@@ -582,7 +622,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-pdf
     when:
       path:
         include:
@@ -592,7 +632,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-pdf
     when:
       path:
         include:
@@ -602,7 +642,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-pdf
     when:
       path:
         include:
@@ -612,7 +652,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-pdf
     when:
       path:
         include:
@@ -622,7 +662,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-pdf
     when:
       path:
         include:
@@ -632,8 +672,18 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-pdf
     when:
       path:
         include:
           - "doc/po/ro/*.po"
+  pdf-uk:
+    pull: true
+    commands:
+      - make -C build-docs/doc/po/uk local-pdf
+    when:
+      path:
+        include:
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 3d6ac9fd4..1192124bd 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -57,7 +57,7 @@ steps:
   build-pg12:
     image: *test-image
-    depends_on: build
+    depends_on: autogen
     environment:
       - PGVER=12
     commands:
@@ -66,7 +66,7 @@ steps:
   build-pg15:
     image: *test-image
-    depends_on: build
     environment:
       - PGVER=15
     commands:
@@ -75,7 +75,7 @@ steps:
   check-pg12:
     image: *test-image
-    depends_on: check
     environment:
       - PGVER=12
     commands:
@@ -85,7 +85,7 @@ steps:
   check-pg15:
     image: *test-image
-    depends_on: check
     environment:
       - PGVER=15
     commands:
@@ -95,7 +95,7 @@ steps:
   installcheck-pg12:
     image: *test-image
-    depends_on: installcheck
     environment:
       - PGVER=12
     commands:
@@ -106,7 +106,7 @@ steps:
   installcheck-pg15:
     image: *test-image
     environment:
       - PGVER=15
     commands:
@@ -117,7 +117,7 @@ steps:
   upgradecheck-pg12:
     image: *test-image
-    depends_on: upgradecheck
     environment:
       - PGVER=12
     commands:
   upgradecheck-pg15:
     image: *test-image
     environment:
       - PGVER=15
     commands:
commit 9342b64426d6f090743e14d8cf6364f0a632ce5a
Date:   Thu Mar 14 03:22:23 2024 -0400
    Put back group
index a36ade7a9..086008bac 100644
@@ -51,7 +51,7 @@ steps:
   build-html:
     image: *test_image
     pull: true
-    depends_on: output
+    group: output
     commands:
       - make -C build-docs/doc html
     when:
@@ -59,7 +59,7 @@ steps:
   build-cheatsheets:
     image: *test_image
     pull: true
+    group: output
     commands:
       - make -C build-docs/doc/ cheatsheets
     when:
@@ -67,7 +67,7 @@ steps:
   build-chunked-html:
     image: *test_image
     pull: true
+    group: output
     commands:
     when:
   build-pdf:
     image: *test_image
     pull: true
+    group: output
     commands:
       - make -C build-docs/doc/ pdf
     when:
Summary of changes:
 .woodpecker/docs-localized.yml.in |   2 +-
 .woodpecker/docs.yml              | 168 +++++++++++++++++++++++++-------------
 .woodpecker/regress.yml           |  16 ++--
 3 files changed, 118 insertions(+), 68 deletions(-)
hooks/post-receive
