[SCM] PostGIS branch master updated. 3.4.0rc1-1020-ge92da8d2a
Thu Mar 14 07:04:21 PDT 2024
the project "PostGIS".
       via  e92da8d2a0572ffbaf06118280817ca2939eee55 (commit)
      from  2342a3f0348c14ddf1644e1301ca5284e8f964a1 (commit)
revisions in full, below.
commit e92da8d2a0572ffbaf06118280817ca2939eee55
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Mar 14 10:04:19 2024 -0400
    Missed some spots
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 486083112..16b29ab1f 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -35,7 +35,7 @@ steps:
   check-xml:
     image: *test_image
     pull: true
-    depends_on: check-xml-and-build-images
+    depends_on: prepare
     commands:
       - make -C build-docs/doc check
     when:
@@ -43,7 +43,7 @@ steps:
   build-images:
     image: *test_image
     pull: true
     commands:
       - make -C build-docs/doc images
     when:
@@ -51,7 +51,7 @@ steps:
   build-html:
     image: *test_image
     pull: true
-    group: output
+    depends_on: build-images
     commands:
       - make -C build-docs/doc html
     when:
@@ -59,7 +59,7 @@ steps:
   build-cheatsheets:
     image: *test_image
     pull: true
-    group: output
     commands:
       - make -C build-docs/doc/ cheatsheets
     when:
@@ -67,7 +67,7 @@ steps:
   build-chunked-html:
     image: *test_image
     pull: true
-    group: output
     commands:
     when:
@@ -75,7 +75,7 @@ steps:
   build-pdf:
     image: *test_image
     pull: true
-    group: output
     commands:
       - make -C build-docs/doc/ pdf
     when:
Summary of changes:
 .woodpecker/docs.yml | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
