[SCM] PostGIS branch master updated. 3.4.0rc1-1024-g57e3f4778
Thu Mar 14 10:26:50 PDT 2024
the project "PostGIS".
       via  57e3f477860748d62d88b465b55e95d0e9091706 (commit)
      from  9454b1125a8c366d9ce74f066846c03f365cc0de (commit)
revisions in full, below.
commit 57e3f477860748d62d88b465b55e95d0e9091706
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Mar 14 18:26:24 2024 +0100
    [woodie] streamline docs dependencies
diff --git a/.woodpecker/docs-localized.yml.in b/.woodpecker/docs-localized.yml.in
index 52ee1d6d6..ece9af87e 100644
--- a/.woodpecker/docs-localized.yml.in
+++ b/.woodpecker/docs-localized.yml.in
@@ -3,7 +3,7 @@
     pull: true
     commands:
       - make -C build-docs/doc/po/@LANG@ local- at TARGET@
-    #group: @GROUP@
+    depends_on: @DEP@
     when:
       path:
         include:
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 16b29ab1f..a91288f29 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -51,7 +51,7 @@ steps:
   build-html:
     image: *test_image
     pull: true
-    depends_on: build-images
+    depends_on: prepare
     commands:
       - make -C build-docs/doc html
     when:
@@ -88,7 +88,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-check-xml
-    #group: localized-check-xml
     when:
       path:
         include:
@@ -98,7 +98,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-check-xml
     when:
       path:
         include:
@@ -108,7 +108,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-check-xml
     when:
       path:
         include:
@@ -118,7 +118,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-check-xml
     when:
       path:
         include:
@@ -128,7 +128,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-check-xml
     when:
       path:
         include:
@@ -138,7 +138,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-check-xml
     when:
       path:
         include:
@@ -148,7 +148,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-check-xml
     when:
       path:
         include:
@@ -158,7 +158,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-check-xml
     when:
       path:
         include:
@@ -168,7 +168,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-check-xml
     when:
       path:
         include:
@@ -178,7 +178,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-check-xml
     when:
       path:
         include:
@@ -188,7 +188,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-check-xml
     when:
       path:
         include:
@@ -198,7 +198,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/uk local-check-xml
     when:
       path:
         include:
@@ -209,7 +209,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-html
-    #group: localized-html
     when:
       path:
         include:
@@ -219,7 +219,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-html
     when:
       path:
         include:
@@ -229,7 +229,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-html
     when:
       path:
         include:
@@ -239,7 +239,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-html
     when:
       path:
         include:
@@ -249,7 +249,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-html
     when:
       path:
         include:
@@ -259,7 +259,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-html
     when:
       path:
         include:
@@ -269,7 +269,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-html
     when:
       path:
         include:
@@ -279,7 +279,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-html
     when:
       path:
         include:
@@ -289,7 +289,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-html
     when:
       path:
         include:
@@ -299,7 +299,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-html
     when:
       path:
         include:
@@ -309,7 +309,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-html
     when:
       path:
         include:
@@ -319,7 +319,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/uk local-html
     when:
       path:
         include:
@@ -330,7 +330,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-cheatsheets
-    #group: localized-cheatsheets
     when:
       path:
         include:
@@ -340,7 +340,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-cheatsheets
     when:
       path:
         include:
@@ -350,7 +350,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-cheatsheets
     when:
       path:
         include:
@@ -360,7 +360,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-cheatsheets
     when:
       path:
         include:
@@ -370,7 +370,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-cheatsheets
     when:
       path:
         include:
@@ -380,7 +380,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-cheatsheets
     when:
       path:
         include:
@@ -390,7 +390,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-cheatsheets
     when:
       path:
         include:
@@ -400,7 +400,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-cheatsheets
     when:
       path:
         include:
@@ -410,7 +410,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-cheatsheets
     when:
       path:
         include:
@@ -420,7 +420,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-cheatsheets
     when:
       path:
         include:
@@ -430,7 +430,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-cheatsheets
     when:
       path:
         include:
@@ -440,7 +440,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/uk local-cheatsheets
     when:
       path:
         include:
@@ -451,7 +451,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-check-cheatsheets
-    #group: localized-check-cheatsheets
+    depends_on: cheatsheets-it_IT
     when:
       path:
         include:
@@ -461,7 +461,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-check-cheatsheets
+    depends_on: cheatsheets-pt_BR
     when:
       path:
         include:
@@ -471,7 +471,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-check-cheatsheets
+    depends_on: cheatsheets-fr
     when:
       path:
         include:
@@ -481,7 +481,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-check-cheatsheets
+    depends_on: cheatsheets-es
     when:
       path:
         include:
@@ -491,7 +491,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-check-cheatsheets
+    depends_on: cheatsheets-pl
     when:
       path:
         include:
@@ -501,7 +501,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-check-cheatsheets
+    depends_on: cheatsheets-ko_KR
     when:
       path:
         include:
@@ -511,7 +511,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-check-cheatsheets
+    depends_on: cheatsheets-de
     when:
       path:
         include:
@@ -521,7 +521,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-check-cheatsheets
+    depends_on: cheatsheets-ja
     when:
       path:
         include:
@@ -531,7 +531,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-check-cheatsheets
+    depends_on: cheatsheets-ru
     when:
       path:
         include:
@@ -541,7 +541,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-check-cheatsheets
+    depends_on: cheatsheets-zh_Hans
     when:
       path:
         include:
@@ -551,7 +551,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-check-cheatsheets
+    depends_on: cheatsheets-ro
     when:
       path:
         include:
@@ -561,7 +561,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/uk local-check-cheatsheets
+    depends_on: cheatsheets-uk
     when:
       path:
         include:
@@ -572,7 +572,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-pdf
-    #group: localized-pdf
+    depends_on: build-images
     when:
       path:
         include:
@@ -582,7 +582,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-pdf
     when:
       path:
         include:
@@ -592,7 +592,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-pdf
     when:
       path:
         include:
@@ -602,7 +602,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-pdf
     when:
       path:
         include:
@@ -612,7 +612,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-pdf
     when:
       path:
         include:
@@ -622,7 +622,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-pdf
     when:
       path:
         include:
@@ -632,7 +632,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-pdf
     when:
       path:
         include:
@@ -642,7 +642,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-pdf
     when:
       path:
         include:
@@ -652,7 +652,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-pdf
     when:
       path:
         include:
@@ -662,7 +662,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-pdf
     when:
       path:
         include:
@@ -672,7 +672,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-pdf
     when:
       path:
         include:
@@ -682,7 +682,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/uk local-pdf
     when:
       path:
         include:
diff --git a/.woodpecker/update-docs-localized.sh b/.woodpecker/update-docs-localized.sh
index 25bcfe67c..34cb7bb90 100755
--- a/.woodpecker/update-docs-localized.sh
+++ b/.woodpecker/update-docs-localized.sh
@@ -15,8 +15,21 @@ do
   echo "### TARGET ${target}"
   for lang in ${SUPPORTED_LANGUAGES};
   do
-    group=localized-${target}
-    sed "s/@LANG@/${lang}/;s/@TARGET@/${target}/;s/@GROUP@/${group}/" docs-localized.yml.in
+    case ${target} in
+      check-xml|html|cheatsheets)
+        depends_on=prepare
+      pdf)
+        depends_on=build-images
+      check-cheatsheets)
+        depends_on=cheatsheets-${lang}
+        echo "Unexpected target ${target}" >&2
+        exit 1
+    esac
+    sed "s/@LANG@/${lang}/;s/@TARGET@/${target}/;s/@DEP@/${depends_on}/" docs-localized.yml.in
   done
 done
Summary of changes:
 .woodpecker/docs-localized.yml.in    |   2 +-
 .woodpecker/docs.yml                 | 122 +++++++++++++++++------------------
 .woodpecker/update-docs-localized.sh |  17 ++++-
 3 files changed, 77 insertions(+), 64 deletions(-)
hooks/post-receive
