[SCM] PostGIS branch master updated. 3.4.0rc1-1026-g2ddb52eab
Thu Mar 14 10:39:07 PDT 2024
the project "PostGIS".
       via  2ddb52eab32b230db3424b79f5231813e73358ab (commit)
       via  16a6f896617ab6ce2445fee813c8a013a8db2a63 (commit)
      from  57e3f477860748d62d88b465b55e95d0e9091706 (commit)
revisions in full, below.
commit 2ddb52eab32b230db3424b79f5231813e73358ab
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Mar 14 18:34:36 2024 +0100
    [woodie] Further tweak dependencies
    - chunked-html does not strictly requires building images
    - check-xml is needed by all steps using the xml
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index a91288f29..eed1c038b 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -51,7 +51,7 @@ steps:
   build-html:
     image: *test_image
     pull: true
-    depends_on: prepare
+    depends_on: check-xml
     commands:
       - make -C build-docs/doc html
     when:
@@ -59,7 +59,7 @@ steps:
   build-cheatsheets:
     image: *test_image
     pull: true
     commands:
       - make -C build-docs/doc/ cheatsheets
     when:
@@ -67,7 +67,7 @@ steps:
   build-chunked-html:
     image: *test_image
     pull: true
-    depends_on: build-images
     commands:
     when:
@@ -75,7 +75,7 @@ steps:
   build-pdf:
     image: *test_image
     pull: true
+    depends_on: [ build-images, check-xml ]
     commands:
       - make -C build-docs/doc/ pdf
     when:
diff --git a/.woodpecker/update-docs-localized.sh b/.woodpecker/update-docs-localized.sh
index 34cb7bb90..a481d99cc 100755
--- a/.woodpecker/update-docs-localized.sh
+++ b/.woodpecker/update-docs-localized.sh
@@ -16,11 +16,14 @@ do
   for lang in ${SUPPORTED_LANGUAGES};
   do
     case ${target} in
-      check-xml|html|cheatsheets)
+      check-xml)
         depends_on=prepare
+      html|cheatsheets)
+        depends_on=check-xml
       pdf)
-        depends_on=build-images
+        depends_on=[ build-images, check-xml ]
       check-cheatsheets)
         depends_on=cheatsheets-${lang}
commit 16a6f896617ab6ce2445fee813c8a013a8db2a63
Date:   Thu Mar 14 18:34:06 2024 +0100
    [woodie] Fix linter
    Cannot use "clone" more than once, apparently:
    https://woodie.osgeo.org/repos/30/pipeline/1953/errors
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index c54c6bae5..2765002d5 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -43,7 +43,7 @@ variables:
     - egrep '(PASS|FAIL|SKIP|INFO|ERROR)' check.log
 clone:
-  clone:
+  git:
     image: woodpeckerci/plugin-git
     depth: 50
Summary of changes:
 .woodpecker/docs.yml                 | 8 ++++----
 .woodpecker/regress.yml              | 2 +-
 .woodpecker/update-docs-localized.sh | 7 +++++--
 3 files changed, 10 insertions(+), 7 deletions(-)
hooks/post-receive
