[SCM] PostGIS branch master updated. 3.4.0rc1-1027-g217206904
Thu Mar 14 10:43:54 PDT 2024
the project "PostGIS".
       via  217206904c36b31add4092816df3b7144daba2e8 (commit)
      from  2ddb52eab32b230db3424b79f5231813e73358ab (commit)
revisions in full, below.
commit 217206904c36b31add4092816df3b7144daba2e8
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Mar 14 18:43:32 2024 +0100
    [woodie] Fix docs.yml updater and actually run it
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index eed1c038b..b36726b53 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -209,7 +209,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-html
-    depends_on: prepare
+    depends_on: check-xml
     when:
       path:
         include:
@@ -219,7 +219,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-html
     when:
       path:
         include:
@@ -229,7 +229,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-html
     when:
       path:
         include:
@@ -239,7 +239,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-html
     when:
       path:
         include:
@@ -249,7 +249,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-html
     when:
       path:
         include:
@@ -259,7 +259,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-html
     when:
       path:
         include:
@@ -269,7 +269,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-html
     when:
       path:
         include:
@@ -279,7 +279,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-html
     when:
       path:
         include:
@@ -289,7 +289,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-html
     when:
       path:
         include:
@@ -299,7 +299,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-html
     when:
       path:
         include:
@@ -309,7 +309,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-html
     when:
       path:
         include:
@@ -319,7 +319,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/uk local-html
     when:
       path:
         include:
@@ -330,7 +330,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-cheatsheets
     when:
       path:
         include:
@@ -340,7 +340,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-cheatsheets
     when:
       path:
         include:
@@ -350,7 +350,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-cheatsheets
     when:
       path:
         include:
@@ -360,7 +360,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-cheatsheets
     when:
       path:
         include:
@@ -370,7 +370,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-cheatsheets
     when:
       path:
         include:
@@ -380,7 +380,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-cheatsheets
     when:
       path:
         include:
@@ -390,7 +390,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-cheatsheets
     when:
       path:
         include:
@@ -400,7 +400,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-cheatsheets
     when:
       path:
         include:
@@ -410,7 +410,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-cheatsheets
     when:
       path:
         include:
@@ -420,7 +420,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-cheatsheets
     when:
       path:
         include:
@@ -430,7 +430,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-cheatsheets
     when:
       path:
         include:
@@ -440,7 +440,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/uk local-cheatsheets
     when:
       path:
         include:
@@ -572,7 +572,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-pdf
-    depends_on: build-images
+    depends_on: [ build-images, check-xml ]
     when:
       path:
         include:
@@ -582,7 +582,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-pdf
     when:
       path:
         include:
@@ -592,7 +592,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-pdf
     when:
       path:
         include:
@@ -602,7 +602,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-pdf
     when:
       path:
         include:
@@ -612,7 +612,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-pdf
     when:
       path:
         include:
@@ -622,7 +622,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-pdf
     when:
       path:
         include:
@@ -632,7 +632,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-pdf
     when:
       path:
         include:
@@ -642,7 +642,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-pdf
     when:
       path:
         include:
@@ -652,7 +652,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-pdf
     when:
       path:
         include:
@@ -662,7 +662,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-pdf
     when:
       path:
         include:
@@ -672,7 +672,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-pdf
     when:
       path:
         include:
@@ -682,7 +682,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/uk local-pdf
     when:
       path:
         include:
diff --git a/.woodpecker/update-docs-localized.sh b/.woodpecker/update-docs-localized.sh
index a481d99cc..fb6520706 100755
--- a/.woodpecker/update-docs-localized.sh
+++ b/.woodpecker/update-docs-localized.sh
@@ -23,7 +23,7 @@ do
         depends_on=check-xml
       pdf)
-        depends_on=[ build-images, check-xml ]
+        depends_on="[ build-images, check-xml ]"
       check-cheatsheets)
         depends_on=cheatsheets-${lang}
Summary of changes:
 .woodpecker/docs.yml                 | 72 ++++++++++++++++++------------------
 .woodpecker/update-docs-localized.sh |  2 +-
 2 files changed, 37 insertions(+), 37 deletions(-)
hooks/post-receive
