[SCM] PostGIS branch master updated. 3.4.0rc1-1029-gc1c45e50d
Thu Mar 14 10:57:43 PDT 2024
the project "PostGIS".
       via  c1c45e50d962ac8c644c9902a6cdb957a68c32aa (commit)
       via  f2c79aaaa99bd4a05246b88109155bd0315c0aa9 (commit)
      from  217206904c36b31add4092816df3b7144daba2e8 (commit)
revisions in full, below.
commit c1c45e50d962ac8c644c9902a6cdb957a68c32aa
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Mar 14 18:57:08 2024 +0100
    Update pot, due after TopoGeo_LoadGeometry addition
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index bf9622755..af518f50f 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2024-03-12 16:22+0000\n"
+"POT-Creation-Date: 2024-03-14 17:56+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -4201,7 +4201,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid ", <xref linkend=\"CreateTopology\"/>, <xref linkend=\"DropTopology\"/>"
+msgid ""
+", <xref linkend=\"AddTopoGeometryColumn\"/>, <xref "
+"linkend=\"CreateTopology\"/>, <xref linkend=\"DropTopology\"/>"
 msgstr ""
 #. Tag: refpurpose
@@ -4222,7 +4224,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-", <xref linkend=\"TopoGeo_AddPolygon\"/>, <xref linkend=\"AddNode\"/>, <xref "
+", <xref linkend=\"TopoGeo_AddPolygon\"/>, <xref "
+"linkend=\"TopoGeo_LoadGeometry\"/>, <xref linkend=\"AddNode\"/>, <xref "
 "linkend=\"CreateTopology\"/>"
 msgstr ""
@@ -4252,7 +4255,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-", <xref linkend=\"TopoGeo_AddPolygon\"/>, <xref linkend=\"AddEdge\"/>, <xref "
+"linkend=\"TopoGeo_LoadGeometry\"/>, <xref linkend=\"AddEdge\"/>, <xref "
 msgstr ""
@@ -4275,8 +4279,35 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-", <xref linkend=\"TopoGeo_AddLineString\"/>, <xref linkend=\"AddFace\"/>, "
-"<xref linkend=\"CreateTopology\"/>"
+", <xref linkend=\"TopoGeo_AddLineString\"/>, <xref "
+"linkend=\"TopoGeo_LoadGeometry\"/>, <xref linkend=\"AddFace\"/>, <xref "
+"linkend=\"CreateTopology\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Load a geometry into an existing topology, snapping and splitting as needed."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Loads a geometry into an existing topology. The given geometry will snap to "
+"existing nodes or edges within given tolerance. Existing edges and faces may "
+"be split as a consequence of the load."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.5.0"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"linkend=\"TopoGeo_AddPolygon\"/>, <xref linkend=\"CreateTopology\"/>"
 msgstr ""
 #. Tag: title
@@ -8037,6 +8068,11 @@ msgstr ""
 msgid "Jackie Leng"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgid "James Addison"
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "James Marca"
@@ -10889,11 +10925,6 @@ msgid ""
 "height information."
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Availability: 3.5.0"
-msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Checks if a geometry has an M (measure) dimension."
commit f2c79aaaa99bd4a05246b88109155bd0315c0aa9
Date:   Thu Mar 14 18:55:02 2024 +0100
    [woodie] Fix localized docs dependencies
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index b36726b53..e22d5ee44 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -209,7 +209,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-html
-    depends_on: check-xml
+    depends_on: check-xml-it_IT
     when:
       path:
         include:
@@ -219,7 +219,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-html
+    depends_on: check-xml-pt_BR
     when:
       path:
         include:
@@ -229,7 +229,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-html
+    depends_on: check-xml-fr
     when:
       path:
         include:
@@ -239,7 +239,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-html
+    depends_on: check-xml-es
     when:
       path:
         include:
@@ -249,7 +249,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-html
+    depends_on: check-xml-pl
     when:
       path:
         include:
@@ -259,7 +259,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-html
+    depends_on: check-xml-ko_KR
     when:
       path:
         include:
@@ -269,7 +269,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-html
+    depends_on: check-xml-de
     when:
       path:
         include:
@@ -279,7 +279,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-html
+    depends_on: check-xml-ja
     when:
       path:
         include:
@@ -289,7 +289,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-html
+    depends_on: check-xml-ru
     when:
       path:
         include:
@@ -299,7 +299,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-html
+    depends_on: check-xml-zh_Hans
     when:
       path:
         include:
@@ -309,7 +309,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-html
+    depends_on: check-xml-ro
     when:
       path:
         include:
@@ -319,7 +319,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/uk local-html
+    depends_on: check-xml-uk
     when:
       path:
         include:
@@ -330,7 +330,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-cheatsheets
     when:
       path:
         include:
@@ -340,7 +340,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-cheatsheets
     when:
       path:
         include:
@@ -350,7 +350,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-cheatsheets
     when:
       path:
         include:
@@ -360,7 +360,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-cheatsheets
     when:
       path:
         include:
@@ -370,7 +370,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-cheatsheets
     when:
       path:
         include:
@@ -380,7 +380,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-cheatsheets
     when:
       path:
         include:
@@ -390,7 +390,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-cheatsheets
     when:
       path:
         include:
@@ -400,7 +400,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-cheatsheets
     when:
       path:
         include:
@@ -410,7 +410,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-cheatsheets
     when:
       path:
         include:
@@ -420,7 +420,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-cheatsheets
     when:
       path:
         include:
@@ -430,7 +430,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-cheatsheets
     when:
       path:
         include:
@@ -440,7 +440,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/uk local-cheatsheets
     when:
       path:
         include:
@@ -572,7 +572,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-pdf
-    depends_on: [ build-images, check-xml ]
+    depends_on: [ build-images, check-xml-it_IT ]
     when:
       path:
         include:
@@ -582,7 +582,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-pdf
+    depends_on: [ build-images, check-xml-pt_BR ]
     when:
       path:
         include:
@@ -592,7 +592,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-pdf
+    depends_on: [ build-images, check-xml-fr ]
     when:
       path:
         include:
@@ -602,7 +602,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-pdf
+    depends_on: [ build-images, check-xml-es ]
     when:
       path:
         include:
@@ -612,7 +612,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-pdf
+    depends_on: [ build-images, check-xml-pl ]
     when:
       path:
         include:
@@ -622,7 +622,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-pdf
+    depends_on: [ build-images, check-xml-ko_KR ]
     when:
       path:
         include:
@@ -632,7 +632,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-pdf
+    depends_on: [ build-images, check-xml-de ]
     when:
       path:
         include:
@@ -642,7 +642,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-pdf
+    depends_on: [ build-images, check-xml-ja ]
     when:
       path:
         include:
@@ -652,7 +652,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-pdf
+    depends_on: [ build-images, check-xml-ru ]
     when:
       path:
         include:
@@ -662,7 +662,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-pdf
+    depends_on: [ build-images, check-xml-zh_Hans ]
     when:
       path:
         include:
@@ -672,7 +672,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-pdf
+    depends_on: [ build-images, check-xml-ro ]
     when:
       path:
         include:
@@ -682,7 +682,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/uk local-pdf
+    depends_on: [ build-images, check-xml-uk ]
     when:
       path:
         include:
diff --git a/.woodpecker/update-docs-localized.sh b/.woodpecker/update-docs-localized.sh
index fb6520706..07453cda7 100755
--- a/.woodpecker/update-docs-localized.sh
+++ b/.woodpecker/update-docs-localized.sh
@@ -20,10 +20,10 @@ do
         depends_on=prepare
       html|cheatsheets)
-        depends_on=check-xml
+        depends_on=check-xml-${lang}
       pdf)
-        depends_on="[ build-images, check-xml ]"
+        depends_on="[ build-images, check-xml-${lang} ]"
       check-cheatsheets)
         depends_on=cheatsheets-${lang}
Summary of changes:
 .woodpecker/docs.yml                 | 72 ++++++++++++++++++------------------
 .woodpecker/update-docs-localized.sh |  4 +-
 doc/po/templates/postgis-manual.pot  | 53 ++++++++++++++++++++------
 3 files changed, 80 insertions(+), 49 deletions(-)
hooks/post-receive
