[SCM] PostGIS branch master updated. 3.4.0rc1-1030-g86db77037
Thu Mar 14 11:02:37 PDT 2024
the project "PostGIS".
       via  86db770371679ab2d16fcf81448c86b935d676d5 (commit)
      from  c1c45e50d962ac8c644c9902a6cdb957a68c32aa (commit)
revisions in full, below.
commit 86db770371679ab2d16fcf81448c86b935d676d5
Author: Weblate <noreply at weblate.org>
Date:   Thu Mar 14 17:58:10 2024 +0000
    Update translation files
    Updated by "Update PO files to match POT (msgmerge)" hook in Weblate.
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index 6a462afe2..30a1abb37 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -8,7 +8,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2024-03-12 16:22+0000\n"
+"POT-Creation-Date: 2024-03-14 17:56+0000\n"
 "PO-Revision-Date: 2024-02-26 08:45+0000\n"
 "Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -5658,8 +5658,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid ", <xref linkend=\"CreateTopology\"/>, <xref linkend=\"DropTopology\"/>"
-msgstr ", <xref linkend=\"CreateTopology\"/>, <xref linkend=\"DropTopology\"/>"
+msgid ""
+", <xref linkend=\"AddTopoGeometryColumn\"/>, <xref "
+"linkend=\"CreateTopology\"/>, <xref linkend=\"DropTopology\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5685,11 +5687,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-", <xref linkend=\"TopoGeo_AddPolygon\"/>, <xref linkend=\"AddNode\"/>, <xref "
+", <xref linkend=\"TopoGeo_AddPolygon\"/>, <xref "
+"linkend=\"TopoGeo_LoadGeometry\"/>, <xref linkend=\"AddNode\"/>, <xref "
 "linkend=\"CreateTopology\"/>"
 msgstr ""
-"linkend=\"CreateTopology\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -5728,11 +5729,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-", <xref linkend=\"TopoGeo_AddPolygon\"/>, <xref linkend=\"AddEdge\"/>, <xref "
+"linkend=\"TopoGeo_LoadGeometry\"/>, <xref linkend=\"AddEdge\"/>, <xref "
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5761,11 +5761,36 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-", <xref linkend=\"TopoGeo_AddLineString\"/>, <xref linkend=\"AddFace\"/>, "
-"<xref linkend=\"CreateTopology\"/>"
+", <xref linkend=\"TopoGeo_AddLineString\"/>, <xref "
+"linkend=\"TopoGeo_LoadGeometry\"/>, <xref linkend=\"AddFace\"/>, <xref "
+"linkend=\"CreateTopology\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Load a geometry into an existing topology, snapping and splitting as needed."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Loads a geometry into an existing topology. The given geometry will snap to "
+"existing nodes or edges within given tolerance. Existing edges and faces may "
+"be split as a consequence of the load."
+msgstr ""
+#. Tag: para
+#, fuzzy, no-c-format
+msgid "Availability: 3.5.0"
+msgstr "Verfügbarkeit: 3.5.0"
+#. Tag: para
+#, no-c-format
+msgid ""
+"linkend=\"TopoGeo_AddPolygon\"/>, <xref linkend=\"CreateTopology\"/>"
 msgstr ""
 #. Tag: title
 #, no-c-format
@@ -10779,6 +10804,11 @@ msgstr "Ingvild Nystuen"
 msgid "Jackie Leng"
 msgstr "Jackie Leng"
+#. Tag: member
+#, no-c-format
+msgid "James Addison"
+msgstr ""
 #. Tag: member
 msgid "James Marca"
@@ -14276,11 +14306,6 @@ msgstr ""
 "Diese Funktion ist nützlich, um festzustellen, ob eine Geometrie Höhen- oder "
 "Breiteninformationen enthält."
-#. Tag: para
-#, fuzzy, no-c-format
-msgid "Availability: 3.5.0"
-msgstr "Verfügbarkeit: 3.5.0"
 #. Tag: refpurpose
 msgid "Checks if a geometry has an M (measure) dimension."
@@ -51883,6 +51908,36 @@ msgstr "2.5/3D-Unterstützung"
 msgid "Supports geography"
 msgstr "Unterstützt Geographie"
+#, no-c-format
+#~ msgid ""
+#~ ", <xref linkend=\"CreateTopology\"/>, <xref linkend=\"DropTopology\"/>"
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ ", <xref linkend=\"TopoGeo_AddPolygon\"/>, <xref linkend=\"AddNode\"/>, "
+#~ "<xref linkend=\"CreateTopology\"/>"
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ ", <xref linkend=\"TopoGeo_AddPolygon\"/>, <xref linkend=\"AddEdge\"/>, "
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ ", <xref linkend=\"TopoGeo_AddLineString\"/>, <xref linkend=\"AddFace\"/>, "
+#~ msgstr ""
 #~ msgid ""
 #~ "the <parameter>geom</parameter> field <varname>LINESTRING</varname>s "
diff --git a/doc/po/es/postgis-manual.po b/doc/po/es/postgis-manual.po
index 5fc73ccee..5adb88784 100644
--- a/doc/po/es/postgis-manual.po
+++ b/doc/po/es/postgis-manual.po
@@ -5,7 +5,7 @@ msgid ""
 msgstr ""
 "PO-Revision-Date: 2023-09-22 19:23+0000\n"
 "Last-Translator: Anonymous <noreply at weblate.org>\n"
 "Language-Team: Spanish <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -4562,8 +4562,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -4589,11 +4591,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -4628,11 +4629,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -4661,11 +4661,36 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
@@ -9169,6 +9194,11 @@ msgstr ""
 msgid "Jackie Leng"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "James Marca"
@@ -12418,11 +12448,6 @@ msgid ""
 "height information."
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -41890,6 +41915,36 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
 #, no-c-format
 #~ msgid ""
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 2d03d412e..b3c25443e 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-11-29 16:23+0000\n"
 "Last-Translator: Vincent Bre <vincent.bre at oslandia.com>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -5642,8 +5642,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5669,11 +5671,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5711,11 +5712,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5744,11 +5744,36 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr "Disponibilité : 3.5.0"
+#. Tag: para
+#, no-c-format
+msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
@@ -10726,6 +10751,11 @@ msgstr "Ingvild Nystuen"
 msgid "Jackie Leng"
+#. Tag: member
+#, no-c-format
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "James Marca"
@@ -14189,11 +14219,6 @@ msgstr ""
 "Cette fonction est utile pour déterminer si une géométrie contient des "
 "informations sur l'altitude ou la hauteur."
-#. Tag: para
-#, no-c-format
-msgstr "Disponibilité : 3.5.0"
 #. Tag: refpurpose
 #, no-c-format
@@ -51593,6 +51618,36 @@ msgstr "Support 2.5/3D"
 msgstr "Prise en charge du type geography"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
 #, no-c-format
 #~ msgid ""
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index 427f3a802..e89812e67 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "PO-Revision-Date: 2023-12-15 20:10+0000\n"
 "Last-Translator: Regina Obe <regina at arrival3d.com>\n"
 "Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -4833,8 +4833,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -4854,11 +4856,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -4886,11 +4887,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -4911,11 +4911,36 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
@@ -9306,6 +9331,11 @@ msgstr ""
 msgid "Jackie Leng"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "James Marca"
@@ -12521,11 +12551,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -42130,6 +42155,36 @@ msgstr "Supporta il 2.5/3D"
 msgstr "Supporta il tipo geography"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
 #, no-c-format
 #~ msgid ""
 #~ "&reference_type; &reference_management; &reference_constructor; "
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 4ce7fb2dc..3d2966450 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2024-01-29 04:45+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -5343,8 +5343,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5368,11 +5370,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5407,11 +5408,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5438,11 +5438,36 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr "Availability: 3.5.0"
+#. Tag: para
+#, no-c-format
+msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
@@ -10232,6 +10257,11 @@ msgstr "Ingvild Nystuen"
 msgid "Jackie Leng"
+#. Tag: member
+#, no-c-format
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "James Marca"
@@ -13574,11 +13604,6 @@ msgstr ""
 "この関数はジオメトリが標高や高さに関する情報を持つかどうかを判断するのに使い"
 "ます。"
-#. Tag: para
-#, no-c-format
-msgstr "Availability: 3.5.0"
 #. Tag: refpurpose
 #, no-c-format
@@ -48961,6 +48986,36 @@ msgstr "2.5次元/3次元対応"
 msgstr "ジオグラフィ対応"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
 #, no-c-format
 #~ msgid ""
diff --git a/doc/po/ko_KR/postgis-manual.po b/doc/po/ko_KR/postgis-manual.po
index 7d51abc57..00725e66e 100644
--- a/doc/po/ko_KR/postgis-manual.po
+++ b/doc/po/ko_KR/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-10-14 20:23+0000\n"
 "Language-Team: Korean <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -4981,8 +4981,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5004,11 +5006,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5036,11 +5037,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5061,11 +5061,36 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
@@ -9487,6 +9512,11 @@ msgstr ""
 msgid "Jackie Leng"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "James Marca"
@@ -12690,11 +12720,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -44425,6 +44450,36 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
 #~ msgid ""
diff --git a/doc/po/pl/postgis-manual.po b/doc/po/pl/postgis-manual.po
index 0c0c9fa3b..2e5bdb7c7 100644
--- a/doc/po/pl/postgis-manual.po
+++ b/doc/po/pl/postgis-manual.po
 msgstr ""
 "Language-Team: Polish <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -4213,8 +4213,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -4234,11 +4236,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -4266,11 +4267,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -4291,11 +4291,36 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
@@ -8084,6 +8109,11 @@ msgstr ""
 msgid "Jackie Leng"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "James Marca"
@@ -10959,11 +10989,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -39444,6 +39469,36 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
 #, no-c-format
 #~ msgid ""
 #~ ", <xref linkend=\"ST_PointFromText\"/>, <xref linkend=\"ST_SetSRID\"/>, "
diff --git a/doc/po/pt_BR/postgis-manual.po b/doc/po/pt_BR/postgis-manual.po
index 97cc372ba..e24772f53 100644
--- a/doc/po/pt_BR/postgis-manual.po
+++ b/doc/po/pt_BR/postgis-manual.po
 msgstr ""
 "Language-Team: Portuguese (Brazil) <https://weblate.osgeo.org/projects/"
@@ -5028,8 +5028,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5051,11 +5053,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5083,11 +5084,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5108,11 +5108,36 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
@@ -9611,6 +9636,11 @@ msgstr ""
 msgid "Jackie Leng"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "James Marca"
@@ -12830,11 +12860,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -44824,6 +44849,36 @@ msgstr ""
 msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
 #~ msgid ""
diff --git a/doc/po/ro/postgis-manual.po b/doc/po/ro/postgis-manual.po
index ce7f605b0..a9301949a 100644
--- a/doc/po/ro/postgis-manual.po
+++ b/doc/po/ro/postgis-manual.po
 msgstr ""
 "Language-Team: Romanian <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -4238,7 +4238,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
+msgid ""
 msgstr ""
 #. Tag: refpurpose
@@ -4259,7 +4261,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
@@ -4289,7 +4292,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
@@ -4312,8 +4316,35 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
 msgstr ""
 #. Tag: title
@@ -8074,6 +8105,11 @@ msgstr ""
 msgid "Jackie Leng"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "James Marca"
@@ -10926,11 +10962,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: refpurpose
 #, no-c-format
diff --git a/doc/po/ru/postgis-manual.po b/doc/po/ru/postgis-manual.po
index c17c13bd1..93b442a1e 100644
--- a/doc/po/ru/postgis-manual.po
+++ b/doc/po/ru/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-09-25 16:23+0000\n"
 "Language-Team: Russian <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -4234,7 +4234,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
+msgid ""
 msgstr ""
 #. Tag: refpurpose
@@ -4255,7 +4257,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
@@ -4285,7 +4288,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
@@ -4308,8 +4312,35 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
 msgstr ""
 #. Tag: title
@@ -8076,6 +8107,11 @@ msgstr ""
 msgid "Jackie Leng"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "James Marca"
@@ -10943,11 +10979,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: refpurpose
 #, no-c-format
diff --git a/doc/po/uk/postgis-manual.po b/doc/po/uk/postgis-manual.po
index d33a95746..2c6639eee 100644
--- a/doc/po/uk/postgis-manual.po
+++ b/doc/po/uk/postgis-manual.po
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Language-Team: Ukrainian <https://weblate.osgeo.org/projects/postgis/postgis-"
@@ -4205,7 +4205,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
+msgid ""
 msgstr ""
 #. Tag: refpurpose
@@ -4226,7 +4228,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
@@ -4256,7 +4259,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
@@ -4279,8 +4283,35 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
 msgstr ""
 #. Tag: title
@@ -8041,6 +8072,11 @@ msgstr ""
 msgid "Jackie Leng"
 msgstr ""
+#. Tag: member
+#, no-c-format
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "James Marca"
@@ -10893,11 +10929,6 @@ msgid ""
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgstr ""
 #. Tag: refpurpose
 #, no-c-format
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 8017d0526..7f5474872 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
 msgstr ""
 "PO-Revision-Date: 2023-12-28 09:45+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
@@ -5025,8 +5025,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
+msgid ""
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5048,11 +5050,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5084,11 +5085,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
@@ -5111,11 +5111,36 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr "可用性:3.5.0"
+#. Tag: para
+#, no-c-format
+msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
@@ -9577,6 +9602,11 @@ msgstr "Ingvild Nystuen"
 msgid "Jackie Leng"
+#. Tag: member
+#, no-c-format
+msgstr ""
 #. Tag: member
 #, no-c-format
 msgid "James Marca"
@@ -12794,11 +12824,6 @@ msgid ""
 msgstr "此函数对于确定几何图形是否具有高程或高度信息非常有用。"
-#. Tag: para
-#, no-c-format
-msgstr "可用性:3.5.0"
 #. Tag: refpurpose
 #, no-c-format
@@ -46310,6 +46335,36 @@ msgstr "2.5/3D 支持"
 msgstr "支持地理"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
 #, no-c-format
 #~ msgid ""
Summary of changes:
 doc/po/de/postgis-manual.po      | 91 ++++++++++++++++++++++++++++++++--------
 doc/po/es/postgis-manual.po      | 91 ++++++++++++++++++++++++++++++++--------
 doc/po/fr/postgis-manual.po      | 91 ++++++++++++++++++++++++++++++++--------
 doc/po/it_IT/postgis-manual.po   | 91 ++++++++++++++++++++++++++++++++--------
 doc/po/ja/postgis-manual.po      | 91 ++++++++++++++++++++++++++++++++--------
 doc/po/ko_KR/postgis-manual.po   | 91 ++++++++++++++++++++++++++++++++--------
 doc/po/pl/postgis-manual.po      | 91 ++++++++++++++++++++++++++++++++--------
 doc/po/pt_BR/postgis-manual.po   | 91 ++++++++++++++++++++++++++++++++--------
 doc/po/ro/postgis-manual.po      | 53 ++++++++++++++++++-----
 doc/po/ru/postgis-manual.po      | 53 ++++++++++++++++++-----
 doc/po/uk/postgis-manual.po      | 53 ++++++++++++++++++-----
 doc/po/zh_Hans/postgis-manual.po | 91 ++++++++++++++++++++++++++++++++--------
 12 files changed, 783 insertions(+), 195 deletions(-)
hooks/post-receive
