[SCM] PostGIS branch master updated. 3.4.0rc1-1033-g475392e85
Fri Mar 15 04:49:20 PDT 2024
the project "PostGIS".
       via  475392e85ef4a2cf4c248fa18ec87e17f76bb73b (commit)
      from  d21b94d1155e595a782fe7cbd8833d4cc6f20b59 (commit)
revisions in full, below.
commit 475392e85ef4a2cf4c248fa18ec87e17f76bb73b
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Mar 15 12:49:02 2024 +0100
    Translate a string in italian, and drop fuzzy strings
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index e89812e67..d1fa285e3 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -41983,6 +41983,9 @@ msgid ""
 "directory for each record. Requires you have plpython installed. Should work "
 "fine with both plpythonu and plpython3u."
 msgstr ""
+"Si tratta di una funzione plpython che crea un file per ogni record nella "
+"directory del server. Richiede la presenza di plpython. Dovrebbe "
+"funzionare bene sia con plpythonu che plpython3u."
 #. Tag: title
 #, no-c-format
@@ -42154,424 +42157,3 @@ msgstr "Supporta il 2.5/3D"
 #, no-c-format
 msgid "Supports geography"
 msgstr "Supporta il tipo geography"
-#, no-c-format
-#~ msgid ""
-#~ ", <xref linkend=\"CreateTopology\"/>, <xref linkend=\"DropTopology\"/>"
-#~ msgstr ""
-#, no-c-format
-#~ msgid ""
-#~ ", <xref linkend=\"TopoGeo_AddPolygon\"/>, <xref linkend=\"AddNode\"/>, "
-#~ "<xref linkend=\"CreateTopology\"/>"
-#~ msgstr ""
-#, no-c-format
-#~ msgid ""
-#~ ", <xref linkend=\"TopoGeo_AddPolygon\"/>, <xref linkend=\"AddEdge\"/>, "
-#~ msgstr ""
-#, no-c-format
-#~ msgid ""
-#~ ", <xref linkend=\"TopoGeo_AddLineString\"/>, <xref linkend=\"AddFace\"/>, "
-#~ msgstr ""
-#, no-c-format
-#~ msgid ""
-#~ "&reference_type; &reference_management; &reference_constructor; "
-#~ "&reference_accessor; &reference_editor; &reference_validation; "
-#~ "&reference_srs; &reference_input; &reference_output; &reference_operator; "
-#~ "&reference_relationship; &reference_measure; &reference_overlay; "
-#~ "&reference_processing; &reference_coverage; &reference_transformation; "
-#~ "&reference_cluster; &reference_bbox; &reference_lrs; "
-#~ "&reference_trajectory; &reference_sfcgal; &reference_transaction; "
-#~ "&reference_version; &reference_guc; &reference_troubleshooting;"
-#~ msgstr ""
-#, no-c-format
-#~ msgid ""
-#~ "Returns a simplified version of a geometry, using the Douglas-Peucker "
-#~ "algorithm."
-#~ msgstr ""
-#~ "Restituisce una versione semplificata di una geometria, utilizzando "
-#~ "l'algoritmo di Douglas-Peucker."
-#, no-c-format
-#~ msgid ""
-#~ "Returns a \"simplified\" version of the given geometry using the Douglas-"
-#~ "Peucker algorithm. Will actually do something only with (multi)lines and "
-#~ "(multi)polygons but you can safely call it with any kind of geometry. "
-#~ "Since simplification occurs on a object-by-object basis you can also feed "
-#~ "a GeometryCollection to this function."
-#~ msgstr ""
-#~ "Restituisce una versione \"semplificata\" della geometria data, "
-#~ "utilizzando l'algoritmo di Douglas-Peucker. In realtà, funziona solo con "
-#~ "(multi)linee e (multi)poligoni, ma può essere tranquillamente richiamato "
-#~ "con qualsiasi tipo di geometria. Poiché la semplificazione avviene "
-#~ "oggetto per oggetto, è possibile fornire a questa funzione anche una "
-#~ "collezione di geometrie."
-#, no-c-format
-#~ msgid ""
-#~ "The \"preserve collapsed\" flag will retain objects that would otherwise "
-#~ "be too small given the tolerance. For example, a 1m long line simplified "
-#~ "with a 10m tolerance. If <varname>preserveCollapsed</varname> argument is "
-#~ "specified as true, the line will not disappear. This flag is useful for "
-#~ "rendering engines, to avoid having large numbers of very small objects "
-#~ "disappear from a map leaving surprising gaps."
-#~ msgstr ""
-#~ "Il flag \"conserva collassato\" conserva gli oggetti che altrimenti "
-#~ "sarebbero troppo piccoli data la tolleranza. Ad esempio, una linea lunga "
-#~ "1 metro semplificata con una tolleranza di 10 metri. Se l'argomento "
-#~ "<varname>preserveCollapsed</varname> è specificato come true, la linea "
-#~ "non scomparirà. Questo flag è utile per i motori di rendering, per "
-#~ "evitare che un gran numero di oggetti molto piccoli scompaia da una mappa "
-#~ "lasciando vuoti sorprendenti."
-#, no-c-format
-#~ msgid ""
-#~ "Buildbot Maintenance, Windows production and experimental builds, "
-#~ "documentation, alignment of PostGIS with PostgreSQL releases, X3D "
-#~ "support, TIGER geocoder support, management functions."
-#~ msgstr ""
-#~ "Manutenzione dei buildbot, compilazione pacchetti windows sperimentali e "
-#~ "di produzione, allineamento dei rilasci di PostGIS con quelli di "
-#~ "PostgreSQL, supporto X3D, support geocoder TIGER, funzioni di gestione."
-#, no-c-format
-#~ msgid ""
-#~ "Index improvements, bug fixing and geometry/geography function "
-#~ "improvements, SFCGAL, raster, GitHub curation, and bot maintenance."
-#~ msgstr ""
-#~ "Miglioramento degli indici, correzione di malfunzionamenti e migliorie "
-#~ "nelle funzioni a supporto di geometrie/geografie, SFCGAL, raster, cura di "
-#~ "GitHub e mantenimento bot."
-#, no-c-format
-#~ msgid ""
-#~ "Bug fixes and maintenance, buildbot maintenance, git mirror management, "
-#~ "management functions, integration of new GEOS functionality and alignment "
-#~ "with GEOS releases, topology support, and raster framework and low level "
-#~ "API functions."
-#~ msgstr ""
-#~ "Correzione e manutenzione di bug, manutenzione di buildbot, gestione del "
-#~ "mirror git, funzioni di gestione, integrazione di nuove funzionalità GEOS "
-#~ "e allineamento con le release GEOS, supporto della topologia, framework "
-#~ "raster e funzioni API di basso livello."
-#, no-c-format
-#~ msgid ""
-#~ "MapBox Vector Tile and GeoBuf functions. Gogs testing and GitLab "
-#~ "experimentation."
-#~ msgstr ""
-#~ "Funzioni MapBox Vector Tile e GeoBuf. Test su Gogs e sperimentazione su "
-#~ "GitLab."
-#, no-c-format
-#~ msgid ""
-#~ "A <inlinemediaobject><imageobject><imagedata fileref=\"images/"
-#~ "matrix_sfcgal_enhanced.png\"/></imageobject></inlinemediaobject> means "
-#~ "the function support is provided by SFCGAL if PostGIS compiled with "
-#~ "SFCGAL support, otherwise GEOS/built-in support."
-#~ msgstr ""
-#~ "Un <inlinemediaobject><imageobject><imagedata fileref=\"images/"
-#~ "matrix_sfcgal_enhanced.png\"/></imageobject> </inlinemediaobject> "
-#~ "significa che il supporto della funzione è fornito da SFCGAL se PostGIS è "
-#~ "stato compilato con il supporto di SFCGAL, altrimenti GEOS/supporto "
-#~ "incorporato."
-#, no-c-format
-#~ msgid ""
-#~ "GEOS geometry library, version 3.6 or greater, but GEOS 3.12+ is required "
-#~ "to take full advantage of all the new functions and features. GEOS is "
-#~ "available for download from <link xlink:href=\"https://libgeos.org/\"> "
-#~ "https://libgeos.org </link>."
-#~ msgstr ""
-#~ "Libreria geometrica GEOS, versione 3.6 o superiore, ma GEOS 3.12+ è "
-#~ "necessario per sfruttare appieno tutte le nuove funzioni e "
-#~ "caratteristiche. GEOS è disponibile per il download da <link xlink:"
-#~ "href=\"https://libgeos.org/\"> https://libgeos.org </link>."
-#, no-c-format
-#~ msgid ""
-#~ "SFCGAL, version 1.3.1 (or higher), 1.4.1 or higher is recommended and "
-#~ "required to be able to use all functionality. SFCGAL can be used to "
-#~ "provide additional 2D and 3D advanced analysis functions to PostGIS cf "
-#~ "<xref linkend=\"reference_sfcgal\"/>. And also allow to use SFCGAL rather "
-#~ "than GEOS for some 2D functions provided by both backends (like "
-#~ "ST_Intersection or ST_Area, for instance). A PostgreSQL configuration "
-#~ "variable <code>postgis.backend</code> allow end user to control which "
-#~ "backend he want to use if SFCGAL is installed (GEOS by default). Nota: "
-#~ "SFCGAL 1.2 require at least CGAL 4.3 and Boost 1.54 (cf: <link xlink:"
-#~ "href=\"https://oslandia.gitlab.io/SFCGAL/dev.html\">https://oslandia."
-#~ "gitlab.io/SFCGAL/dev.html</link>) <link xlink:href=\"https://gitlab.com/"
-#~ "Oslandia/SFCGAL/\">https://gitlab.com/Oslandia/SFCGAL/</link>."
-#~ msgstr ""
-#~ "SFCGAL, versione 1.3.1 (o superiore), 1.4.1 o superiore è consigliato e "
-#~ "richiesto per poter utilizzare tutte le funzionalità. SFCGAL può essere "
-#~ "utilizzato per fornire ulteriori funzioni di analisi avanzata 2D e 3D a "
-#~ "PostGIS cf <xref linkend=\"reference_sfcgal\"/>. Inoltre, consente di "
-#~ "utilizzare SFCGAL anziché GEOS per alcune funzioni 2D fornite da entrambi "
-#~ "i backend (come ST_Intersection o ST_Area, ad esempio). Una variabile di "
-#~ "configurazione PostgreSQL <code>postgis.backend</code> permette "
-#~ "all'utente finale di controllare quale backend vuole usare se SFCGAL è "
-#~ "installato (GEOS di default). Nota: SFCGAL 1.2 richiede almeno CGAL 4.3 e "
-#~ "Boost 1.54 (cfr. <link xlink:href=\"https://oslandia.gitlab.io/SFCGAL/dev."
-#~ "html\">https://oslandia.gitlab.io/SFCGAL/dev.html</link>) <link xlink:"
-#~ "href=\"https://gitlab.com/Oslandia/SFCGAL/\">https://gitlab.com/Oslandia/"
-#~ "SFCGAL/</link>."
-#, fuzzy, no-c-format
-#~ msgid "Creates a 2D, 3D Z or 4D ZM Point geometry."
-#~ msgstr "Crea una BOX2D definita dalle geometrie dei punti dati."
-#, no-c-format
-#~ msgid ""
-#~ ", <xref linkend=\"ST_PointFromText\"/>, <xref linkend=\"ST_SetSRID\"/>, "
-#~ "<xref linkend=\"ST_MakePointM\"/>"
-#~ msgstr ""
-#, no-c-format
-#~ msgid ", <xref linkend=\"ST_MakePoint\"/>, <xref linkend=\"ST_SetSRID\"/>"
-#~ msgstr ", <xref linkend=\"ST_MakePoint\"/>, <xref linkend=\"ST_SetSRID\"/>"
-#, no-c-format
-#~ msgid ""
-#~ ", <xref linkend=\"ST_MakePoint\"/>, <xref linkend=\"ST_SetSRID\"/>, <xref "
-#~ "linkend=\"ST_Transform\"/>, <xref linkend=\"ST_PointZ\"/>, <xref "
-#~ "linkend=\"ST_PointM\"/>, <xref linkend=\"ST_PointZM\"/>"
-#~ msgstr ""
-#, no-c-format
-#~ msgid "MACRO_C"
-#~ msgstr "MACRO_C"
-#, no-c-format
-#~ msgid ""
-#~ "<emphasis role=\"bold\">MACRO_C output tokens</emphasis> (excerpted from "
-#~ "<link xlink:href=\"http://www.pagcgeo.org/docs/html/pagc-12.html#--r-typ--"
-#~ "\">http://www.pagcgeo.org/docs/html/pagc-12.html#--r-typ--</link>."
-#~ msgstr ""
-#~ "<emphasis role=\"bold\">MACRO_C output tokens</emphasis> (estratto da "
-#, no-c-format
-#~ msgid ""
-#~ "Returns a <varname>POINT</varname> which is guaranteed to lie in the "
-#~ "interior of a surface (POLYGON, MULTIPOLYGON, and CURVED POLYGON). In "
-#~ "PostGIS this function also works on line and point geometries."
-#~ msgstr ""
-#~ "Restituisce un <varname>POINT</varname> che è garantito essere "
-#~ "all'interno di una superficie (POLYGON, MULTIPOLYGON e CURVED POLYGON). "
-#~ "In PostGIS questa funzione funziona anche su geometrie di linee e punti."
-#, no-c-format
-#~ msgid "make comments"
-#~ msgstr "make comments"
-#, no-c-format
-#~ msgid "make cheatsheets"
-#~ msgstr "make cheatsheets"
-#, no-c-format
-#~ msgid "make check"
-#~ msgstr "make check"
-#, no-c-format
-#~ msgid "make install"
-#~ msgstr "make install"
-#, no-c-format
-#~ msgid "make comments-install"
-#~ msgstr "make comments-install"
-#, no-c-format
-#~ msgid "git clone https://git.osgeo.org/gitea/postgis/postgis.git"
-#~ msgstr "git clone https://git.osgeo.org/gitea/postgis/postgis.git"
-#, no-c-format
-#~ msgid "vim doc/postgis.xml"
-#~ msgstr "vim doc/postgis.xml"
-#, no-c-format
-#~ msgid "git diff doc/postgis.xml > doc.patch"
-#~ msgstr "git diff doc/postgis.xml > doc.patch"
-#, no-c-format
-#~ msgid "building"
-#~ msgstr "compilare"
-#, no-c-format
-#~ msgid "<term>box</term>"
-#~ msgstr "<term>box</term>"
-#, no-c-format
-#~ msgid "unit"
-#~ msgstr "unità"
-#, no-c-format
-#~ msgid "<term>id</term>"
-#~ msgstr "<term>id</term>"
-#, no-c-format
-#~ msgid "MIXED"
-#~ msgstr "MISTO"
-#, no-c-format
-#~ msgid "<term>ORD</term>"
-#~ msgstr "<term>ORD</term>"
-#, no-c-format
-#~ msgid "<term>RR</term>"
-#~ msgstr "<term>RR</term>"
-#, no-c-format
-#~ msgid "TYPE"
-#~ msgstr "TYPE"
-#, no-c-format
-#~ msgid "<term>PCH</term>"
-#~ msgstr "<term>PCH</term>"
-#, no-c-format
-#~ msgid "<term>PCT</term>"
-#~ msgstr "<term>PCT</term>"
-#, no-c-format
-#~ msgid "<term>seq</term>"
-#~ msgstr "<term>seq</term>"
-#~ msgid "value"
-#~ msgstr "ST_Value"
-#, no-c-format
-#~ msgid "pixeltype"
-#~ msgstr "pixeltype"
-#, no-c-format
-#~ msgid "expression"
-#~ msgstr "espressione"
-#, no-c-format
-#~ msgid "rast"
-#~ msgstr "rast"
-#, no-c-format
-#~ msgid "ngbwidth"
-#~ msgstr "ngbwidth"
-#, no-c-format
-#~ msgid "ngbheight"
-#~ msgstr "ngbheight"
-#, no-c-format
-#~ msgid "args"
-#~ msgstr "args"
-#, no-c-format
-#~ msgid "<term>-c</term>"
-#~ msgstr "<term>-c</term>"
-#, no-c-format
-#~ msgid "<term>-a</term>"
-#~ msgstr "<term>-a</term>"
-#, no-c-format
-#~ msgid "<term>-d</term>"
-#~ msgstr "<term>-d</term>"
-#, no-c-format
-#~ msgid "<term>-p</term>"
-#~ msgstr "<term>-p</term>"
-#, no-c-format
-#~ msgid "<term>-?</term>"
-#~ msgstr "<term>-?</term>"
-#, no-c-format
-#~ msgid "<term>-k</term>"
-#~ msgstr "<term>-k</term>"
-#, no-c-format
-#~ msgid "<term>-I</term>"
-#~ msgstr "<term>-I</term>"
-#, no-c-format
-#~ msgid "<term>-e</term>"
-#~ msgstr "<term>-e</term>"
-#, no-c-format
-#~ msgid "<term>-G</term>"
-#~ msgstr "<term>-G</term>"
-#, no-c-format
-#~ msgid "<term>-r</term>"
-#~ msgstr "<term>-r</term>"
-#, no-c-format
-#~ msgid "<term>-C</term>"
-#~ msgstr "<term>-C</term>"
-#, no-c-format
-#~ msgid "<term>-x</term>"
-#~ msgstr "<term>-x</term>"
-#, no-c-format
-#~ msgid "-s <SRID>"
-#~ msgstr "-s <SRID>"
-#, no-c-format
-#~ msgid "-b BAND"
-#~ msgstr "-b BANDA"
-#, no-c-format
-#~ msgid "-t TILE_SIZE"
-#~ msgstr "-t DIMENSIONE_TILE"
-#, no-c-format
-#~ msgid "-R, --register"
-#~ msgstr "-R, --register"
-#, no-c-format
-#~ msgid "-f COLUMN"
-#~ msgstr "-f COLONNA"
-#, no-c-format
-#~ msgid "<term>-F</term>"
-#~ msgstr "<term>-F</term>"
-#, no-c-format
-#~ msgid "<term>-q</term>"
-#~ msgstr "<term>-q</term>"
-#, no-c-format
-#~ msgid "<term>-M</term>"
-#~ msgstr "<term>-M</term>"
-#, no-c-format
-#~ msgid "-E ENDIAN"
-#~ msgstr "-E ENDIAN"
Summary of changes:
 doc/po/it_IT/postgis-manual.po | 424 +----------------------------------------
 1 file changed, 3 insertions(+), 421 deletions(-)
hooks/post-receive
