[SCM] PostGIS branch master updated. 3.4.0rc1-1035-gddae34d6a
Fri Mar 15 05:42:13 PDT 2024
the project "PostGIS".
       via  ddae34d6a894b08cd2d524356ed9444eb7447f4b (commit)
       via  04e3ff6f62afc151ddb7b87c1f4e67769ae10f1e (commit)
      from  475392e85ef4a2cf4c248fa18ec87e17f76bb73b (commit)
revisions in full, below.
commit ddae34d6a894b08cd2d524356ed9444eb7447f4b
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Mar 15 13:42:01 2024 +0100
    Translate another italian string
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index d1fa285e3..9bb0eba87 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -42146,7 +42146,7 @@ msgstr "Richiede GEOS (3.9,3.10,3.11,3.12) o versioni successive"
 #. Tag: para
 #, no-c-format
 msgid "Requires SFCGAL 1.5 or higher"
-msgstr ""
+msgstr "Richiede SFCGAL 1.5 o superiore"
 #. Tag: para
 #, no-c-format
commit 04e3ff6f62afc151ddb7b87c1f4e67769ae10f1e
Date:   Fri Mar 15 13:41:13 2024 +0100
    [woodie] localized cheatsheet check depends on the english one
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 32b6763f4..2c7c4870a 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -451,7 +451,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/it_IT local-check-cheatsheets
-    depends_on: cheatsheets-it_IT
+    depends_on: [ cheatsheets-it_IT, build-cheatsheets ]
     when:
       path:
         include:
@@ -461,7 +461,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-check-cheatsheets
-    depends_on: cheatsheets-pt_BR
+    depends_on: [ cheatsheets-pt_BR, build-cheatsheets ]
     when:
       path:
         include:
@@ -471,7 +471,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-check-cheatsheets
-    depends_on: cheatsheets-fr
+    depends_on: [ cheatsheets-fr, build-cheatsheets ]
     when:
       path:
         include:
@@ -481,7 +481,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-check-cheatsheets
-    depends_on: cheatsheets-es
+    depends_on: [ cheatsheets-es, build-cheatsheets ]
     when:
       path:
         include:
@@ -491,7 +491,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-check-cheatsheets
-    depends_on: cheatsheets-pl
+    depends_on: [ cheatsheets-pl, build-cheatsheets ]
     when:
       path:
         include:
@@ -501,7 +501,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-check-cheatsheets
-    depends_on: cheatsheets-ko_KR
+    depends_on: [ cheatsheets-ko_KR, build-cheatsheets ]
     when:
       path:
         include:
@@ -511,7 +511,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-check-cheatsheets
-    depends_on: cheatsheets-de
+    depends_on: [ cheatsheets-de, build-cheatsheets ]
     when:
       path:
         include:
@@ -521,7 +521,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-check-cheatsheets
-    depends_on: cheatsheets-ja
+    depends_on: [ cheatsheets-ja, build-cheatsheets ]
     when:
       path:
         include:
@@ -531,7 +531,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-check-cheatsheets
-    depends_on: cheatsheets-ru
+    depends_on: [ cheatsheets-ru, build-cheatsheets ]
     when:
       path:
         include:
@@ -541,7 +541,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-check-cheatsheets
-    depends_on: cheatsheets-zh_Hans
+    depends_on: [ cheatsheets-zh_Hans, build-cheatsheets ]
     when:
       path:
         include:
@@ -551,7 +551,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-check-cheatsheets
-    depends_on: cheatsheets-ro
+    depends_on: [ cheatsheets-ro, build-cheatsheets ]
     when:
       path:
         include:
@@ -561,7 +561,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/uk local-check-cheatsheets
-    depends_on: cheatsheets-uk
+    depends_on: [ cheatsheets-uk, build-cheatsheets ]
     when:
       path:
         include:
diff --git a/.woodpecker/update-docs-localized.sh b/.woodpecker/update-docs-localized.sh
index 07453cda7..98c3a6a14 100755
--- a/.woodpecker/update-docs-localized.sh
+++ b/.woodpecker/update-docs-localized.sh
@@ -26,7 +26,7 @@ do
         depends_on="[ build-images, check-xml-${lang} ]"
       check-cheatsheets)
-        depends_on=cheatsheets-${lang}
+        depends_on="[ cheatsheets-${lang}, build-cheatsheets ]"
         echo "Unexpected target ${target}" >&2
Summary of changes:
 .woodpecker/docs.yml                 | 24 ++++++++++++------------
 .woodpecker/update-docs-localized.sh |  2 +-
 doc/po/it_IT/postgis-manual.po       |  2 +-
 3 files changed, 14 insertions(+), 14 deletions(-)
hooks/post-receive
