[PostGIS] #5697: fix or document id escaping for ST_EstimatedExtent params
PostGIS trac at osgeo.org
Sat Mar 16 00:53:28 PDT 2024
  Reporter:  Yuri     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.4.3
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Description changed by Yuri:
Old description:
> Function ST_EstimatedExtent -
> https://postgis.net/docs/ST_EstimatedExtent.html has an usual param
> pattern - it requires schema, table, and geometry columns to be strings
> in some uncertain escaping - later it gets used directly without quotes
> in an internal schema/table identity lookup. (uncertain)
> As the result, it is not clear what escaping is needed in "complex"
> cases. Moreover, I suspect there might be a security bug here too, but
> not certain.
> I could not get this function to run for this (convoluted) case.
> CREATE SCHEMA """Quotes' and Space.Dot.";
> CREATE TABLE """Quotes' and Space.Dot.".". Points"" 'quote"
>     "' id '"      SERIAL PRIMARY KEY,
>     ".namE "      TEXT,
>     ". '""Geom""" GEOMETRY(POINT, 4326)
> INSERT INTO """Quotes' and Space.Dot.".". Points"" 'quote"
> values (1, '02daedc70702ec68753fde38351f5d9d',
> '0101000020E610000050C4D38CE9DA61401EFC0EC7C3DA2740'),
>        (2, '7418427ba8a960c3661235f47cc13d46',
> '0101000020E6100000CC2F4170E9DA6140DEDB02B581DA2740');
> CREATE INDEX ON """Quotes' and Space.Dot.".". Points"" 'quote" USING GIST
> (". '""Geom""");
> SELECT ST_EstimatedExtent(?, ?, ?) as bounds;
New description:
 pattern - it requires schema, table, and geometry columns to be strings in
 some uncertain escaping - later it gets used directly without quotes in an
 As the result, it is not clear what escaping is needed in "complex" cases.
 Moreover, I suspect there might be a security bug here too, but not
 certain.
     ".namE "      TEXT,
 (". '""Geom""");
 An even more convoluted case (might be better as it covers a few more edge
 cases):
 CREATE SCHEMA """Quotes' \ \' \"" and Space.Dot.";
 CREATE TABLE """Quotes' \ \' \"" and Space.Dot.".". Points"" \ \' \""
 'quote"
     ".namE "                TEXT,
     ". ' \ \' \"" ""Geom""" GEOMETRY(POINT, 4326)
 INSERT INTO """Quotes' \ \' \"" and Space.Dot.".". Points"" \ \' \""
 'quote"
 CREATE INDEX ON """Quotes' \ \' \"" and Space.Dot.".". Points"" \ \' \""
 'quote" USING GIST (". ' \ \' \"" ""Geom""");
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5697#comment:2>
