[PostGIS] #5697: fix or document id escaping for ST_EstimatedExtent params
PostGIS trac at osgeo.org
Sat Mar 16 02:12:36 PDT 2024
  Reporter:  Yuri     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.4.3
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by Yuri):
 After lots of back and forth, it seems this **may** work:
 * for schema, use identifier escaping rules to produce a double-quoted
 string, and afterwards remove the first and last double-quote character.
 * do the same for the table
 * pass geometry column as is
 Which means that when calling, schema and table name have to first be
 encoded as identifiers, remove first/last `"`, and then encode using
 literal string encoding. The geometry must only be literally encoded...
 Uncertain of this, but seems to work in some testing...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5697#comment:3>
