[PostGIS] #5698: XX000: SQL/MM Spatial exception - point not on edge
PostGIS trac at osgeo.org
Thu Mar 21 07:20:30 PDT 2024
 Reporter:  Lars Aksel Opsahl  |      Owner:  strk
     Type:  defect             |     Status:  new
 Priority:  medium             |  Milestone:  PostGIS 3.4.3
Component:  topology           |    Version:  3.4.x
 Keywords:                     |
 When running attached before_error.sql it runs ok with no errors
 PostgreSQL 12.6 (Ubuntu 12.6-0ubuntu0.20.04.1) on x86_64-pc-linux-gnu,
 compiled by gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, 64-bit
 POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="120" GEOS="3.12.1-CAPI-1.18.1"
 (compiled against GEOS 3.10.2) SFCGAL="1.3.7" PROJ="8.2.0
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
 GDAL="GDAL 3.4.3, released 2022/04/22" LIBXML="2.9.10" LIBJSON="0.13.1"
 LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
 But then I run line below and I get the topology error
 SELECT
 topology.TopoGeo_addLinestring('tmp_dyrkbarjord_04_t3_a_test_issue_70_114','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',0);
 Here is the error message
 ERROR:  XX000: SQL/MM Spatial exception - point not on edge
 I also tested on my local mac and we have the same problem here running
 this setup
 PostgreSQL 14.10 (Homebrew) on aarch64-apple-darwin23.0.0, compiled by
 Apple clang version 15.0.0 (clang-1500.0.40.1), 64-bit
 POSTGIS="3.3.4 3.3.4" [EXTENSION] PGSQL="140" GEOS="3.12.1-CAPI-1.18.1"
 PROJ="9.3.1" LIBXML="2.11.5" LIBJSON="0.17" LIBPROTOBUF="1.5.0"
 and on this system same problem
 PostgreSQL 15.4 (Ubuntu 15.4-2.pgdg22.04+1) on x86_64-pc-linux-gnu,
 compiled by gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, 64-bit
 POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="150" GEOS="3.10.2-CAPI-1.16.0"
 PROJ="8.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5698>
