[SCM] postgis.net branch website updated. clarity-final-89-g260de2c
Tue Mar 19 15:03:48 PDT 2024
the project "postgis.net".
The branch, website has been updated
       via  260de2cdce7b9427b9be301401470fffb3d5bbf9 (commit)
      from  a87b7e2533c73b4fe434f478dd3e2e8bfc59ee0f (commit)
revisions in full, below.
commit 260de2cdce7b9427b9be301401470fffb3d5bbf9
Author: mdavis <mtnclimb at gmail.com>
Date:   Tue Mar 19 15:03:43 2024 -0700
    Update content/documentation/tips/st-dwithin.md
diff --git a/content/documentation/tips/st-dwithin.md b/content/documentation/tips/st-dwithin.md
index 274ca5d..778eb96 100644
--- a/content/documentation/tips/st-dwithin.md
+++ b/content/documentation/tips/st-dwithin.md
@@ -1,5 +1,5 @@
-title: "Use ST_DWithin not ST_Distance for radius queries"
+title: "Use ST_DWithin for radius queries"
 layout: post
 category: tips
 tags: [newbie, geometry, geography, ST_DWithin]
@@ -11,20 +11,20 @@ geekdocHiddenTocTree: false
 weight: 10
-If you have a problem that involves finding the things within X distance of other things or finding what things "have nothing within X distance" do not use `ST_Distance` for filtering and also do not try to use [ST_Intersects](/docs/ST_Intersects.html) with [ST_Buffer](/docs/ST_Buffer.html).
+For queries that involve finding "things within distance X of other things" or "what things have nothing within distance X", use [ST_DWithin](/docs/ST_DWithin.html) for filtering.  Do not use [ST_Distance](/docs/ST_Distance.html) or [ST_Intersects](/docs/ST_Intersects.html) with [ST_Buffer](/docs/ST_Buffer.html).
-Use [ST_DWithin](/docs/manual-dev/ST_DWithin.html) instead. Why?
+Why?
-1. `ST_DWithin` can use an index and `ST_Distance` can not
-2. ` ST_Buffer` is just an approximation of a buffer and not an exact buffer
+1. `ST_DWithin` uses an spatial index (if available). `ST_Distance` does not
+2. `ST_DWithin` is more accurate than using `ST_Buffer`, which is only approximation of a true buffer outline. It is also amost always faster.
-Also note that `ST_DWithin` is supported for both geometry and geography.
+Note that `ST_DWithin` is supported for both `geometry` and `geography` types.
 ## Examples
-We show examples using geography. Note that geometry would use much the same except units are in the spatial reference units.
+We show examples using `geography`. Queries using `geometry` are similar, but the distance must be in the spatial reference units.
-### Finding closest things within 1609 meters (~1 mile)
+### Finding things within 1609 meters (~1 mile)
 ```postgres
 SELECT roads.road_name, pois.poi_name
Summary of changes:
 content/documentation/tips/st-dwithin.md | 16 ++++++++--------
 1 file changed, 8 insertions(+), 8 deletions(-)
hooks/post-receive
postgis.net
