[PostGIS] #5654: Missing line segment with self-intersection and MVT
PostGIS trac at osgeo.org
Fri Mar 22 12:58:28 PDT 2024
  Reporter:  mhkeller  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.4.3
 Component:  postgis   |    Version:  3.4.x
Resolution:            |   Keywords:  mvt, self-intersection
Comment (by tjcaverly):
 `SELECT postgis_full_version()`
 `POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="140" GEOS="3.9.0-CAPI-1.16.2"
 PROJ="7.2.1" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3"
 WAGYU="0.5.0 (Internal)"`
 I get the same result as you,
 select st_astext(
     st_simplify(
     'LINESTRING (2 2,3 2,4 1,3 2, 4 4)'
     ,0)
 "LINESTRING(2 2,3 2,4 4)"
 This incorrectly removes the 3rd point, erasing a large portion of the
 geometry. It then removes the 4th point since it's the same as the 2nd,
 which doesn't affect anything. Correct behavior would be returning
 `LINESTRING (2 2,3 2,4 1,3 2, 4 4)`.
 The example on stackexchange is different but shows the same bug.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5654#comment:6>
