[PostGIS] #5654: Missing line segment with self-intersection and MVT
PostGIS trac at osgeo.org
Thu Mar 21 11:21:05 PDT 2024
  Reporter:  mhkeller  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.4.3
 Component:  postgis   |    Version:  3.4.x
Resolution:            |   Keywords:  mvt, self-intersection
Comment (by robe):
 when I do
 select st_astext(
     st_simplify(
     'LINESTRING (2 2,3 2,4 1,3 2, 4 4)'
     ,0)
 I get back:
 LINESTRING(2 2,3 2,4 4)
 Using:
 SELECT postgis_full_version();
 POSTGIS="3.5.0dev 3.4.0rc1-972-ga832b8598" [EXTENSION] PGSQL="160"
 GEOS="3.13.0dev-CAPI-1.18.0" PROJ="9.3.1 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/share/proj/proj.db" GDAL="GDAL 3.8.1, released
 2023/11/28" LIBXML="2.9.14" LIBJSON="0.17" LIBPROTOBUF="1.4.1"
 WAGYU="0.5.0 (Internal)" (core procs from "3.5.0dev
 3.4.0rc1-1013-g1284f168d" need upgrade) RASTER (raster lib from "3.5.0dev
 3.4.0rc1-1039-g88c3893c7" need upgrade) (raster procs from "3.5.0dev
 This is different from the answer stated in the stack exchange you
 reference of:
 select st_astext(
     st_simplify(
     'LINESTRING (2 2,3 2,4 1,3 2)'
     ,0)
 "LINESTRING(2 2,3 2,3 2)"
 What exactly are you getting?  and please state the versions of postgis
 and related libs you are using.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5654#comment:5>
