[SCM] PostGIS branch master updated. 3.4.0rc1-1048-g51b13566a
Fri Mar 22 19:19:47 PDT 2024
the project "PostGIS".
       via  51b13566a175c1ba21d6c2ae03f6e02a32370cbc (commit)
       via  5d54c0df54b515189430f22a3f83172cf4b226d5 (commit)
       via  c4b40797c91e3d9367ce958ffe662ab4f5079713 (commit)
      from  468c76bdf231beb806117c14df046466f3f5e397 (commit)
revisions in full, below.
commit 51b13566a175c1ba21d6c2ae03f6e02a32370cbc
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Mar 22 22:07:47 2024 -0400
    Try to fix woodpecker bad_habit warning
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 3055a32fb..217882115 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -31,9 +31,8 @@ steps:
       - make postgis_revision.h
       - xmllint --version
     when:
-      - event: push
-      - event: pull_request
-        path: *when_path_full
+        - path: *when_path_full
+          event: [tag, pull_request, push]
   check-xml:
     image: *test_image
     pull: true
@@ -41,9 +40,8 @@ steps:
     commands:
       - make -C build-docs/doc check
     when:
-      - event: push
-        path: *when_path
   build-images:
     image: *test_image
     pull: true
@@ -51,9 +49,8 @@ steps:
     commands:
       - make -C build-docs/doc images
     when:
-      - event: push
   build-html:
     image: *test_image
     pull: true
@@ -61,9 +58,8 @@ steps:
     commands:
       - make -C build-docs/doc html
     when:
-      - event: push
-        path: *when_path
   build-cheatsheets:
     image: *test_image
     pull: true
@@ -71,9 +67,8 @@ steps:
     commands:
       - make -C build-docs/doc/ cheatsheets
     when:
-      - event: push
-        path: *when_path
   build-chunked-html:
     image: *test_image
     pull: true
@@ -81,9 +76,8 @@ steps:
     commands:
     when:
-      - event: push
-        path: *when_path
   build-pdf:
     image: *test_image
     pull: true
@@ -91,9 +85,8 @@ steps:
     commands:
       - make -C build-docs/doc/ pdf
     when:
-      - event: push
-        path: *when_path
   # DO NOT EDIT PAST THIS LINE, use update-docs-localized.sh to update #
 ### TARGET check-xml
commit 5d54c0df54b515189430f22a3f83172cf4b226d5
Date:   Fri Mar 22 21:57:31 2024 -0400
index b2b91bd8e..3055a32fb 100644
@@ -31,7 +31,9 @@ steps:
       - xmllint --version
     when:
+      - event: push
+      - event: pull_request
+        path: *when_path_full
   check-xml:
     image: *test_image
     pull: true
@@ -39,7 +41,9 @@ steps:
     commands:
     when:
-      path: *when_path
+      - event: push
+        path: *when_path
   build-images:
     image: *test_image
     pull: true
@@ -47,7 +51,9 @@ steps:
     commands:
     when:
+      - event: push
   build-html:
     image: *test_image
     pull: true
@@ -55,7 +61,9 @@ steps:
     commands:
     when:
-      path: *when_path
+      - event: push
+        path: *when_path
   build-cheatsheets:
     image: *test_image
     pull: true
@@ -63,7 +71,9 @@ steps:
     commands:
     when:
-      path: *when_path
+      - event: push
+        path: *when_path
   build-chunked-html:
     image: *test_image
     pull: true
@@ -71,7 +81,9 @@ steps:
     commands:
     when:
-      path: *when_path
+      - event: push
+        path: *when_path
   build-pdf:
     image: *test_image
     pull: true
@@ -79,7 +91,9 @@ steps:
     commands:
     when:
-      path: *when_path
+      - event: push
+        path: *when_path
commit c4b40797c91e3d9367ce958ffe662ab4f5079713
Date:   Fri Mar 22 21:53:35 2024 -0400
diff --git a/.woodpecker/docs-localized.yml.in b/.woodpecker/docs-localized.yml.in
index 3ad0506c1..b9fb04c52 100644
--- a/.woodpecker/docs-localized.yml.in
+++ b/.woodpecker/docs-localized.yml.in
@@ -5,7 +5,8 @@
       - make -C build-docs/doc/po/@LANG@ local- at TARGET@
     depends_on: @DEP@
     when:
-      - event: [push, pull_request]
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/@LANG@/*.po"
index b21d3bd9e..b2b91bd8e 100644
@@ -90,9 +90,10 @@ steps:
       - make -C build-docs/doc/po/it_IT local-check-xml
     depends_on: prepare
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/it_IT/*.po"
   check-xml-pt_BR:
     image: *test_image
@@ -101,9 +102,10 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-check-xml
     depends_on: prepare
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/pt_BR/*.po"
   check-xml-fr:
     image: *test_image
@@ -112,9 +114,10 @@ steps:
       - make -C build-docs/doc/po/fr local-check-xml
     depends_on: prepare
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/fr/*.po"
   check-xml-es:
     image: *test_image
@@ -123,9 +126,10 @@ steps:
       - make -C build-docs/doc/po/es local-check-xml
     depends_on: prepare
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/es/*.po"
   check-xml-pl:
     image: *test_image
@@ -134,9 +138,10 @@ steps:
       - make -C build-docs/doc/po/pl local-check-xml
     depends_on: prepare
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/pl/*.po"
   check-xml-ko_KR:
     image: *test_image
@@ -145,9 +150,10 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-check-xml
     depends_on: prepare
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ko_KR/*.po"
   check-xml-de:
     image: *test_image
@@ -156,9 +162,10 @@ steps:
       - make -C build-docs/doc/po/de local-check-xml
     depends_on: prepare
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/de/*.po"
   check-xml-ja:
     image: *test_image
@@ -167,9 +174,10 @@ steps:
       - make -C build-docs/doc/po/ja local-check-xml
     depends_on: prepare
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ja/*.po"
   check-xml-ru:
     image: *test_image
@@ -178,9 +186,10 @@ steps:
       - make -C build-docs/doc/po/ru local-check-xml
     depends_on: prepare
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ru/*.po"
   check-xml-zh_Hans:
     image: *test_image
@@ -189,9 +198,10 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-check-xml
     depends_on: prepare
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/zh_Hans/*.po"
   check-xml-ro:
     image: *test_image
@@ -200,9 +210,10 @@ steps:
       - make -C build-docs/doc/po/ro local-check-xml
     depends_on: prepare
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ro/*.po"
   check-xml-uk:
     image: *test_image
@@ -211,9 +222,10 @@ steps:
       - make -C build-docs/doc/po/uk local-check-xml
     depends_on: prepare
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/uk/*.po"
 ### TARGET html
   html-it_IT:
@@ -223,9 +235,10 @@ steps:
       - make -C build-docs/doc/po/it_IT local-html
     depends_on: check-xml-it_IT
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   html-pt_BR:
     image: *test_image
@@ -234,9 +247,10 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-html
     depends_on: check-xml-pt_BR
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   html-fr:
     image: *test_image
@@ -245,9 +259,10 @@ steps:
       - make -C build-docs/doc/po/fr local-html
     depends_on: check-xml-fr
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/fr/*.po"
   html-es:
     image: *test_image
@@ -256,9 +271,10 @@ steps:
       - make -C build-docs/doc/po/es local-html
     depends_on: check-xml-es
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/es/*.po"
   html-pl:
     image: *test_image
@@ -267,9 +283,10 @@ steps:
       - make -C build-docs/doc/po/pl local-html
     depends_on: check-xml-pl
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/pl/*.po"
   html-ko_KR:
     image: *test_image
@@ -278,9 +295,10 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-html
     depends_on: check-xml-ko_KR
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   html-de:
     image: *test_image
@@ -289,9 +307,10 @@ steps:
       - make -C build-docs/doc/po/de local-html
     depends_on: check-xml-de
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/de/*.po"
   html-ja:
     image: *test_image
@@ -300,9 +319,10 @@ steps:
       - make -C build-docs/doc/po/ja local-html
     depends_on: check-xml-ja
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ja/*.po"
   html-ru:
     image: *test_image
@@ -311,9 +331,10 @@ steps:
       - make -C build-docs/doc/po/ru local-html
     depends_on: check-xml-ru
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ru/*.po"
   html-zh_Hans:
     image: *test_image
@@ -322,9 +343,10 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-html
     depends_on: check-xml-zh_Hans
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   html-ro:
     image: *test_image
@@ -333,9 +355,10 @@ steps:
       - make -C build-docs/doc/po/ro local-html
     depends_on: check-xml-ro
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ro/*.po"
   html-uk:
     image: *test_image
@@ -344,9 +367,10 @@ steps:
       - make -C build-docs/doc/po/uk local-html
     depends_on: check-xml-uk
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/uk/*.po"
 ### TARGET cheatsheets
   cheatsheets-it_IT:
@@ -356,9 +380,10 @@ steps:
       - make -C build-docs/doc/po/it_IT local-cheatsheets
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   cheatsheets-pt_BR:
     image: *test_image
@@ -367,9 +392,10 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-cheatsheets
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   cheatsheets-fr:
     image: *test_image
@@ -378,9 +404,10 @@ steps:
       - make -C build-docs/doc/po/fr local-cheatsheets
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/fr/*.po"
   cheatsheets-es:
     image: *test_image
@@ -389,9 +416,10 @@ steps:
       - make -C build-docs/doc/po/es local-cheatsheets
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/es/*.po"
   cheatsheets-pl:
     image: *test_image
@@ -400,9 +428,10 @@ steps:
       - make -C build-docs/doc/po/pl local-cheatsheets
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/pl/*.po"
   cheatsheets-ko_KR:
     image: *test_image
@@ -411,9 +440,10 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-cheatsheets
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   cheatsheets-de:
     image: *test_image
@@ -422,9 +452,10 @@ steps:
       - make -C build-docs/doc/po/de local-cheatsheets
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/de/*.po"
   cheatsheets-ja:
     image: *test_image
@@ -433,9 +464,10 @@ steps:
       - make -C build-docs/doc/po/ja local-cheatsheets
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ja/*.po"
   cheatsheets-ru:
     image: *test_image
@@ -444,9 +476,10 @@ steps:
       - make -C build-docs/doc/po/ru local-cheatsheets
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ru/*.po"
   cheatsheets-zh_Hans:
     image: *test_image
@@ -455,9 +488,10 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-cheatsheets
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   cheatsheets-ro:
     image: *test_image
@@ -466,9 +500,10 @@ steps:
       - make -C build-docs/doc/po/ro local-cheatsheets
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ro/*.po"
   cheatsheets-uk:
     image: *test_image
@@ -477,9 +512,10 @@ steps:
       - make -C build-docs/doc/po/uk local-cheatsheets
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/uk/*.po"
 ### TARGET check-cheatsheets
   check-cheatsheets-it_IT:
@@ -489,9 +525,10 @@ steps:
       - make -C build-docs/doc/po/it_IT local-check-cheatsheets
     depends_on: [ cheatsheets-it_IT, build-cheatsheets ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   check-cheatsheets-pt_BR:
     image: *test_image
@@ -500,9 +537,10 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-check-cheatsheets
     depends_on: [ cheatsheets-pt_BR, build-cheatsheets ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   check-cheatsheets-fr:
     image: *test_image
@@ -511,9 +549,10 @@ steps:
       - make -C build-docs/doc/po/fr local-check-cheatsheets
     depends_on: [ cheatsheets-fr, build-cheatsheets ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/fr/*.po"
   check-cheatsheets-es:
     image: *test_image
@@ -522,9 +561,10 @@ steps:
       - make -C build-docs/doc/po/es local-check-cheatsheets
     depends_on: [ cheatsheets-es, build-cheatsheets ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/es/*.po"
   check-cheatsheets-pl:
     image: *test_image
@@ -533,9 +573,10 @@ steps:
       - make -C build-docs/doc/po/pl local-check-cheatsheets
     depends_on: [ cheatsheets-pl, build-cheatsheets ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/pl/*.po"
   check-cheatsheets-ko_KR:
     image: *test_image
@@ -544,9 +585,10 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-check-cheatsheets
     depends_on: [ cheatsheets-ko_KR, build-cheatsheets ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   check-cheatsheets-de:
     image: *test_image
@@ -555,9 +597,10 @@ steps:
       - make -C build-docs/doc/po/de local-check-cheatsheets
     depends_on: [ cheatsheets-de, build-cheatsheets ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/de/*.po"
   check-cheatsheets-ja:
     image: *test_image
@@ -566,9 +609,10 @@ steps:
       - make -C build-docs/doc/po/ja local-check-cheatsheets
     depends_on: [ cheatsheets-ja, build-cheatsheets ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ja/*.po"
   check-cheatsheets-ru:
     image: *test_image
@@ -577,9 +621,10 @@ steps:
       - make -C build-docs/doc/po/ru local-check-cheatsheets
     depends_on: [ cheatsheets-ru, build-cheatsheets ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ru/*.po"
   check-cheatsheets-zh_Hans:
     image: *test_image
@@ -588,9 +633,10 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-check-cheatsheets
     depends_on: [ cheatsheets-zh_Hans, build-cheatsheets ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   check-cheatsheets-ro:
     image: *test_image
@@ -599,9 +645,10 @@ steps:
       - make -C build-docs/doc/po/ro local-check-cheatsheets
     depends_on: [ cheatsheets-ro, build-cheatsheets ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ro/*.po"
   check-cheatsheets-uk:
     image: *test_image
@@ -610,9 +657,10 @@ steps:
       - make -C build-docs/doc/po/uk local-check-cheatsheets
     depends_on: [ cheatsheets-uk, build-cheatsheets ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/uk/*.po"
 ### TARGET pdf
   pdf-it_IT:
@@ -622,9 +670,10 @@ steps:
       - make -C build-docs/doc/po/it_IT local-pdf
     depends_on: [ build-images, check-xml-it_IT ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   pdf-pt_BR:
     image: *test_image
@@ -633,9 +682,10 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-pdf
     depends_on: [ build-images, check-xml-pt_BR ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   pdf-fr:
     image: *test_image
@@ -644,9 +694,10 @@ steps:
       - make -C build-docs/doc/po/fr local-pdf
     depends_on: [ build-images, check-xml-fr ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/fr/*.po"
   pdf-es:
     image: *test_image
@@ -655,9 +706,10 @@ steps:
       - make -C build-docs/doc/po/es local-pdf
     depends_on: [ build-images, check-xml-es ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/es/*.po"
   pdf-pl:
     image: *test_image
@@ -666,9 +718,10 @@ steps:
       - make -C build-docs/doc/po/pl local-pdf
     depends_on: [ build-images, check-xml-pl ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/pl/*.po"
   pdf-ko_KR:
     image: *test_image
@@ -677,9 +730,10 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-pdf
     depends_on: [ build-images, check-xml-ko_KR ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   pdf-de:
     image: *test_image
@@ -688,9 +742,10 @@ steps:
       - make -C build-docs/doc/po/de local-pdf
     depends_on: [ build-images, check-xml-de ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/de/*.po"
   pdf-ja:
     image: *test_image
@@ -699,9 +754,10 @@ steps:
       - make -C build-docs/doc/po/ja local-pdf
     depends_on: [ build-images, check-xml-ja ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ja/*.po"
   pdf-ru:
     image: *test_image
@@ -710,9 +766,10 @@ steps:
       - make -C build-docs/doc/po/ru local-pdf
     depends_on: [ build-images, check-xml-ru ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ru/*.po"
   pdf-zh_Hans:
     image: *test_image
@@ -721,9 +778,10 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-pdf
     depends_on: [ build-images, check-xml-zh_Hans ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
   pdf-ro:
     image: *test_image
@@ -732,9 +790,10 @@ steps:
       - make -C build-docs/doc/po/ro local-pdf
     depends_on: [ build-images, check-xml-ro ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/ro/*.po"
   pdf-uk:
     image: *test_image
@@ -743,7 +802,8 @@ steps:
       - make -C build-docs/doc/po/uk local-pdf
     depends_on: [ build-images, check-xml-uk ]
     when:
-      - path:
-        include:
+      - event: push
+        path:
+         include:
           - "doc/po/uk/*.po"
Summary of changes:
 .woodpecker/docs-localized.yml.in |   7 +-
 .woodpecker/docs.yml              | 441 ++++++++++++++++++++++----------------
 2 files changed, 258 insertions(+), 190 deletions(-)
hooks/post-receive
