[SCM] PostGIS branch master updated. 3.4.0rc1-1055-gd200bf040
Fri Mar 22 19:34:58 PDT 2024
the project "PostGIS".
       via  d200bf04076854e28258896634d227e6a1a6aae4 (commit)
       via  87a24c544d8123f744593b8c97bba00aa36abfbc (commit)
       via  56d773211e9a34e77e41ed7cd86529ff626da5f5 (commit)
       via  4cbbb76e7b45e0f0d8367ad0b5149b0feebeec9c (commit)
       via  dcb7fb0ce61f14459eade4e291de906100bc8a23 (commit)
       via  36266d326e4ffb28edcab2be6faba10ef56c425c (commit)
       via  5a92e9f1dc8427df95c8f7e8cd4a1a3ce2a04870 (commit)
      from  51b13566a175c1ba21d6c2ae03f6e02a32370cbc (commit)
revisions in full, below.
commit d200bf04076854e28258896634d227e6a1a6aae4
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Mar 22 22:32:52 2024 -0400
    Try to fix woodpecker bad_habit warning
diff --git a/.woodpecker/docs-localized.yml.in b/.woodpecker/docs-localized.yml.in
index ecec2526c..8f114be9f 100644
--- a/.woodpecker/docs-localized.yml.in
+++ b/.woodpecker/docs-localized.yml.in
@@ -5,8 +5,8 @@
       - make -C build-docs/doc/po/@LANG@ local- at TARGET@
     depends_on: @DEP@
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/@LANG@/*.po"
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 6fe4b1dba..6e4fd86bd 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -50,8 +50,8 @@ steps:
     commands:
       - make -C build-docs/doc images
     when:
-        - path: *when_path_full
-          event: [tag, pull_request, push]
+      - path: *when_path_full
+        event: [tag, pull_request, push]
   build-html:
     image: *test_image
     pull: true
@@ -98,9 +98,9 @@ steps:
       - make -C build-docs/doc/po/it_IT local-check-xml
     depends_on: prepare
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/it_IT/*.po"
   check-xml-pt_BR:
@@ -110,9 +110,9 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-check-xml
     depends_on: prepare
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/pt_BR/*.po"
   check-xml-fr:
@@ -122,9 +122,9 @@ steps:
       - make -C build-docs/doc/po/fr local-check-xml
     depends_on: prepare
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/fr/*.po"
   check-xml-es:
@@ -134,9 +134,9 @@ steps:
       - make -C build-docs/doc/po/es local-check-xml
     depends_on: prepare
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/es/*.po"
   check-xml-pl:
@@ -146,9 +146,9 @@ steps:
       - make -C build-docs/doc/po/pl local-check-xml
     depends_on: prepare
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/pl/*.po"
   check-xml-ko_KR:
@@ -158,9 +158,9 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-check-xml
     depends_on: prepare
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ko_KR/*.po"
   check-xml-de:
@@ -170,9 +170,9 @@ steps:
       - make -C build-docs/doc/po/de local-check-xml
     depends_on: prepare
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/de/*.po"
   check-xml-ja:
@@ -182,9 +182,9 @@ steps:
       - make -C build-docs/doc/po/ja local-check-xml
     depends_on: prepare
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ja/*.po"
   check-xml-ru:
@@ -194,9 +194,9 @@ steps:
       - make -C build-docs/doc/po/ru local-check-xml
     depends_on: prepare
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ru/*.po"
   check-xml-zh_Hans:
@@ -206,9 +206,9 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-check-xml
     depends_on: prepare
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/zh_Hans/*.po"
   check-xml-ro:
@@ -218,9 +218,9 @@ steps:
       - make -C build-docs/doc/po/ro local-check-xml
     depends_on: prepare
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ro/*.po"
   check-xml-uk:
@@ -230,9 +230,9 @@ steps:
       - make -C build-docs/doc/po/uk local-check-xml
     depends_on: prepare
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/uk/*.po"
 ### TARGET html
@@ -243,9 +243,9 @@ steps:
       - make -C build-docs/doc/po/it_IT local-html
     depends_on: check-xml-it_IT
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   html-pt_BR:
@@ -255,9 +255,9 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-html
     depends_on: check-xml-pt_BR
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   html-fr:
@@ -267,9 +267,9 @@ steps:
       - make -C build-docs/doc/po/fr local-html
     depends_on: check-xml-fr
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/fr/*.po"
   html-es:
@@ -279,9 +279,9 @@ steps:
       - make -C build-docs/doc/po/es local-html
     depends_on: check-xml-es
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/es/*.po"
   html-pl:
@@ -291,9 +291,9 @@ steps:
       - make -C build-docs/doc/po/pl local-html
     depends_on: check-xml-pl
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/pl/*.po"
   html-ko_KR:
@@ -303,9 +303,9 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-html
     depends_on: check-xml-ko_KR
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   html-de:
@@ -315,9 +315,9 @@ steps:
       - make -C build-docs/doc/po/de local-html
     depends_on: check-xml-de
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/de/*.po"
   html-ja:
@@ -327,9 +327,9 @@ steps:
       - make -C build-docs/doc/po/ja local-html
     depends_on: check-xml-ja
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ja/*.po"
   html-ru:
@@ -339,9 +339,9 @@ steps:
       - make -C build-docs/doc/po/ru local-html
     depends_on: check-xml-ru
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ru/*.po"
   html-zh_Hans:
@@ -351,9 +351,9 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-html
     depends_on: check-xml-zh_Hans
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   html-ro:
@@ -363,9 +363,9 @@ steps:
       - make -C build-docs/doc/po/ro local-html
     depends_on: check-xml-ro
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ro/*.po"
   html-uk:
@@ -375,9 +375,9 @@ steps:
       - make -C build-docs/doc/po/uk local-html
     depends_on: check-xml-uk
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/uk/*.po"
 ### TARGET cheatsheets
@@ -388,9 +388,9 @@ steps:
       - make -C build-docs/doc/po/it_IT local-cheatsheets
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   cheatsheets-pt_BR:
@@ -400,9 +400,9 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-cheatsheets
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   cheatsheets-fr:
@@ -412,9 +412,9 @@ steps:
       - make -C build-docs/doc/po/fr local-cheatsheets
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/fr/*.po"
   cheatsheets-es:
@@ -424,9 +424,9 @@ steps:
       - make -C build-docs/doc/po/es local-cheatsheets
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/es/*.po"
   cheatsheets-pl:
@@ -436,9 +436,9 @@ steps:
       - make -C build-docs/doc/po/pl local-cheatsheets
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/pl/*.po"
   cheatsheets-ko_KR:
@@ -448,9 +448,9 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-cheatsheets
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   cheatsheets-de:
@@ -460,9 +460,9 @@ steps:
       - make -C build-docs/doc/po/de local-cheatsheets
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/de/*.po"
   cheatsheets-ja:
@@ -472,9 +472,9 @@ steps:
       - make -C build-docs/doc/po/ja local-cheatsheets
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ja/*.po"
   cheatsheets-ru:
@@ -484,9 +484,9 @@ steps:
       - make -C build-docs/doc/po/ru local-cheatsheets
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ru/*.po"
   cheatsheets-zh_Hans:
@@ -496,9 +496,9 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-cheatsheets
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   cheatsheets-ro:
@@ -508,9 +508,9 @@ steps:
       - make -C build-docs/doc/po/ro local-cheatsheets
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ro/*.po"
   cheatsheets-uk:
@@ -520,9 +520,9 @@ steps:
       - make -C build-docs/doc/po/uk local-cheatsheets
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/uk/*.po"
 ### TARGET check-cheatsheets
@@ -533,9 +533,9 @@ steps:
       - make -C build-docs/doc/po/it_IT local-check-cheatsheets
     depends_on: [ cheatsheets-it_IT, build-cheatsheets ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   check-cheatsheets-pt_BR:
@@ -545,9 +545,9 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-check-cheatsheets
     depends_on: [ cheatsheets-pt_BR, build-cheatsheets ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   check-cheatsheets-fr:
@@ -557,9 +557,9 @@ steps:
       - make -C build-docs/doc/po/fr local-check-cheatsheets
     depends_on: [ cheatsheets-fr, build-cheatsheets ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/fr/*.po"
   check-cheatsheets-es:
@@ -569,9 +569,9 @@ steps:
       - make -C build-docs/doc/po/es local-check-cheatsheets
     depends_on: [ cheatsheets-es, build-cheatsheets ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/es/*.po"
   check-cheatsheets-pl:
@@ -581,9 +581,9 @@ steps:
       - make -C build-docs/doc/po/pl local-check-cheatsheets
     depends_on: [ cheatsheets-pl, build-cheatsheets ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/pl/*.po"
   check-cheatsheets-ko_KR:
@@ -593,9 +593,9 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-check-cheatsheets
     depends_on: [ cheatsheets-ko_KR, build-cheatsheets ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   check-cheatsheets-de:
@@ -605,9 +605,9 @@ steps:
       - make -C build-docs/doc/po/de local-check-cheatsheets
     depends_on: [ cheatsheets-de, build-cheatsheets ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/de/*.po"
   check-cheatsheets-ja:
@@ -617,9 +617,9 @@ steps:
       - make -C build-docs/doc/po/ja local-check-cheatsheets
     depends_on: [ cheatsheets-ja, build-cheatsheets ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ja/*.po"
   check-cheatsheets-ru:
@@ -629,9 +629,9 @@ steps:
       - make -C build-docs/doc/po/ru local-check-cheatsheets
     depends_on: [ cheatsheets-ru, build-cheatsheets ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ru/*.po"
   check-cheatsheets-zh_Hans:
@@ -641,9 +641,9 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-check-cheatsheets
     depends_on: [ cheatsheets-zh_Hans, build-cheatsheets ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   check-cheatsheets-ro:
@@ -653,9 +653,9 @@ steps:
       - make -C build-docs/doc/po/ro local-check-cheatsheets
     depends_on: [ cheatsheets-ro, build-cheatsheets ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ro/*.po"
   check-cheatsheets-uk:
@@ -665,9 +665,9 @@ steps:
       - make -C build-docs/doc/po/uk local-check-cheatsheets
     depends_on: [ cheatsheets-uk, build-cheatsheets ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/uk/*.po"
 ### TARGET pdf
@@ -678,9 +678,9 @@ steps:
       - make -C build-docs/doc/po/it_IT local-pdf
     depends_on: [ build-images, check-xml-it_IT ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   pdf-pt_BR:
@@ -690,9 +690,9 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-pdf
     depends_on: [ build-images, check-xml-pt_BR ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   pdf-fr:
@@ -702,9 +702,9 @@ steps:
       - make -C build-docs/doc/po/fr local-pdf
     depends_on: [ build-images, check-xml-fr ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/fr/*.po"
   pdf-es:
@@ -714,9 +714,9 @@ steps:
       - make -C build-docs/doc/po/es local-pdf
     depends_on: [ build-images, check-xml-es ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/es/*.po"
   pdf-pl:
@@ -726,9 +726,9 @@ steps:
       - make -C build-docs/doc/po/pl local-pdf
     depends_on: [ build-images, check-xml-pl ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/pl/*.po"
   pdf-ko_KR:
@@ -738,9 +738,9 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-pdf
     depends_on: [ build-images, check-xml-ko_KR ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   pdf-de:
@@ -750,9 +750,9 @@ steps:
       - make -C build-docs/doc/po/de local-pdf
     depends_on: [ build-images, check-xml-de ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/de/*.po"
   pdf-ja:
@@ -762,9 +762,9 @@ steps:
       - make -C build-docs/doc/po/ja local-pdf
     depends_on: [ build-images, check-xml-ja ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ja/*.po"
   pdf-ru:
@@ -774,9 +774,9 @@ steps:
       - make -C build-docs/doc/po/ru local-pdf
     depends_on: [ build-images, check-xml-ru ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ru/*.po"
   pdf-zh_Hans:
@@ -786,9 +786,9 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-pdf
     depends_on: [ build-images, check-xml-zh_Hans ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
   pdf-ro:
@@ -798,9 +798,9 @@ steps:
       - make -C build-docs/doc/po/ro local-pdf
     depends_on: [ build-images, check-xml-ro ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/ro/*.po"
   pdf-uk:
@@ -810,8 +810,8 @@ steps:
       - make -C build-docs/doc/po/uk local-pdf
     depends_on: [ build-images, check-xml-uk ]
     when:
-        - event: push
-          path:
-           include:
+      - event: push
+        path:
+          include:
             - "doc/po/uk/*.po"
commit 87a24c544d8123f744593b8c97bba00aa36abfbc
Date:   Fri Mar 22 22:31:15 2024 -0400
index 387746644..6fe4b1dba 100644
@@ -31,7 +31,7 @@ steps:
       - make postgis_revision.h
       - xmllint --version
     when:
-        - event: [tag, pull_request, push]
+        - event: push
   check-xml:
commit 56d773211e9a34e77e41ed7cd86529ff626da5f5
Date:   Fri Mar 22 22:28:26 2024 -0400
index 74acba1a0..ecec2526c 100644
@@ -5,7 +5,8 @@
     depends_on: @DEP@
     when:
-        - path:
+        - event: push
+          path:
            include:
-        - event: [push, pull_request]
index 29508fd67..387746644 100644
@@ -98,10 +98,11 @@ steps:
     depends_on: prepare
     when:
-        - path:
+        - event: push
+          path:
            include:
   check-xml-pt_BR:
     image: *test_image
     pull: true
@@ -109,10 +110,11 @@ steps:
     depends_on: prepare
     when:
-        - path:
+        - event: push
+          path:
            include:
   check-xml-fr:
     image: *test_image
     pull: true
@@ -120,10 +122,11 @@ steps:
     depends_on: prepare
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/fr/*.po"
   check-xml-es:
     image: *test_image
     pull: true
@@ -131,10 +134,11 @@ steps:
     depends_on: prepare
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/es/*.po"
   check-xml-pl:
     image: *test_image
     pull: true
@@ -142,10 +146,11 @@ steps:
     depends_on: prepare
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/pl/*.po"
   check-xml-ko_KR:
     image: *test_image
     pull: true
@@ -153,10 +158,11 @@ steps:
     depends_on: prepare
     when:
-        - path:
+        - event: push
+          path:
            include:
   check-xml-de:
     image: *test_image
     pull: true
@@ -164,10 +170,11 @@ steps:
     depends_on: prepare
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/de/*.po"
   check-xml-ja:
     image: *test_image
     pull: true
@@ -175,10 +182,11 @@ steps:
     depends_on: prepare
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ja/*.po"
   check-xml-ru:
     image: *test_image
     pull: true
@@ -186,10 +194,11 @@ steps:
     depends_on: prepare
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ru/*.po"
   check-xml-zh_Hans:
     image: *test_image
     pull: true
@@ -197,10 +206,11 @@ steps:
     depends_on: prepare
     when:
-        - path:
+        - event: push
+          path:
            include:
   check-xml-ro:
     image: *test_image
     pull: true
@@ -208,10 +218,11 @@ steps:
     depends_on: prepare
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ro/*.po"
   check-xml-uk:
     image: *test_image
     pull: true
@@ -219,10 +230,11 @@ steps:
     depends_on: prepare
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/uk/*.po"
 ### TARGET html
   html-it_IT:
     image: *test_image
@@ -231,10 +243,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
   html-pt_BR:
     image: *test_image
     pull: true
@@ -242,10 +255,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
   html-fr:
     image: *test_image
     pull: true
@@ -253,10 +267,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/fr/*.po"
   html-es:
     image: *test_image
     pull: true
@@ -264,10 +279,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/es/*.po"
   html-pl:
     image: *test_image
     pull: true
@@ -275,10 +291,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/pl/*.po"
   html-ko_KR:
     image: *test_image
     pull: true
@@ -286,10 +303,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
   html-de:
     image: *test_image
     pull: true
@@ -297,10 +315,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/de/*.po"
   html-ja:
     image: *test_image
     pull: true
@@ -308,10 +327,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ja/*.po"
   html-ru:
     image: *test_image
     pull: true
@@ -319,10 +339,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ru/*.po"
   html-zh_Hans:
     image: *test_image
     pull: true
@@ -330,10 +351,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
   html-ro:
     image: *test_image
     pull: true
@@ -341,10 +363,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ro/*.po"
   html-uk:
     image: *test_image
     pull: true
@@ -352,10 +375,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/uk/*.po"
   cheatsheets-it_IT:
     image: *test_image
@@ -364,10 +388,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
   cheatsheets-pt_BR:
     image: *test_image
     pull: true
@@ -375,10 +400,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
   cheatsheets-fr:
     image: *test_image
     pull: true
@@ -386,10 +412,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/fr/*.po"
   cheatsheets-es:
     image: *test_image
     pull: true
@@ -397,10 +424,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/es/*.po"
   cheatsheets-pl:
     image: *test_image
     pull: true
@@ -408,10 +436,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/pl/*.po"
   cheatsheets-ko_KR:
     image: *test_image
     pull: true
@@ -419,10 +448,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
   cheatsheets-de:
     image: *test_image
     pull: true
@@ -430,10 +460,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/de/*.po"
   cheatsheets-ja:
     image: *test_image
     pull: true
@@ -441,10 +472,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ja/*.po"
   cheatsheets-ru:
     image: *test_image
     pull: true
@@ -452,10 +484,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ru/*.po"
     image: *test_image
     pull: true
@@ -463,10 +496,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
   cheatsheets-ro:
     image: *test_image
     pull: true
@@ -474,10 +508,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ro/*.po"
   cheatsheets-uk:
     image: *test_image
     pull: true
@@ -485,10 +520,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/uk/*.po"
   check-cheatsheets-it_IT:
     image: *test_image
@@ -497,10 +533,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
     image: *test_image
     pull: true
@@ -508,10 +545,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
     image: *test_image
     pull: true
@@ -519,10 +557,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/fr/*.po"
     image: *test_image
     pull: true
@@ -530,10 +569,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/es/*.po"
     image: *test_image
     pull: true
@@ -541,10 +581,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/pl/*.po"
     image: *test_image
     pull: true
@@ -552,10 +593,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
     image: *test_image
     pull: true
@@ -563,10 +605,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/de/*.po"
     image: *test_image
     pull: true
@@ -574,10 +617,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ja/*.po"
     image: *test_image
     pull: true
@@ -585,10 +629,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ru/*.po"
     image: *test_image
     pull: true
@@ -596,10 +641,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
     image: *test_image
     pull: true
@@ -607,10 +653,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ro/*.po"
     image: *test_image
     pull: true
@@ -618,10 +665,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/uk/*.po"
 ### TARGET pdf
   pdf-it_IT:
     image: *test_image
@@ -630,10 +678,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
   pdf-pt_BR:
     image: *test_image
     pull: true
@@ -641,10 +690,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
   pdf-fr:
     image: *test_image
     pull: true
@@ -652,10 +702,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/fr/*.po"
   pdf-es:
     image: *test_image
     pull: true
@@ -663,10 +714,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/es/*.po"
   pdf-pl:
     image: *test_image
     pull: true
@@ -674,10 +726,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/pl/*.po"
   pdf-ko_KR:
     image: *test_image
     pull: true
@@ -685,10 +738,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
   pdf-de:
     image: *test_image
     pull: true
@@ -696,10 +750,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/de/*.po"
   pdf-ja:
     image: *test_image
     pull: true
@@ -707,10 +762,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ja/*.po"
   pdf-ru:
     image: *test_image
     pull: true
@@ -718,10 +774,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ru/*.po"
   pdf-zh_Hans:
     image: *test_image
     pull: true
@@ -729,10 +786,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
   pdf-ro:
     image: *test_image
     pull: true
@@ -740,10 +798,11 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/ro/*.po"
   pdf-uk:
     image: *test_image
     pull: true
@@ -751,7 +810,8 @@ steps:
     when:
-        - path:
+        - event: push
+          path:
            include:
             - "doc/po/uk/*.po"
commit 4cbbb76e7b45e0f0d8367ad0b5149b0feebeec9c
Date:   Fri Mar 22 22:26:46 2024 -0400
index 2c16e0870..74acba1a0 100644
@@ -6,7 +6,6 @@
     depends_on: @DEP@
     when:
         - path:
-          include:
-           - "doc/po/@LANG@/*.po"
-          event: push
-          event: pull_request
+           include:
+            - "doc/po/@LANG@/*.po"
+        - event: [push, pull_request]
index 936f97430..29508fd67 100644
@@ -99,10 +99,9 @@ steps:
     depends_on: prepare
     when:
         - path:
-          include:
-           - "doc/po/it_IT/*.po"
-          event: push
+           include:
+            - "doc/po/it_IT/*.po"
   check-xml-pt_BR:
     image: *test_image
     pull: true
@@ -111,10 +110,9 @@ steps:
     depends_on: prepare
     when:
         - path:
-          include:
-           - "doc/po/pt_BR/*.po"
-          event: push
+           include:
+            - "doc/po/pt_BR/*.po"
   check-xml-fr:
     image: *test_image
     pull: true
@@ -123,10 +121,9 @@ steps:
     depends_on: prepare
     when:
         - path:
-          include:
-           - "doc/po/fr/*.po"
-          event: push
+           include:
+            - "doc/po/fr/*.po"
   check-xml-es:
     image: *test_image
     pull: true
@@ -135,10 +132,9 @@ steps:
     depends_on: prepare
     when:
         - path:
-          include:
-           - "doc/po/es/*.po"
-          event: push
+           include:
+            - "doc/po/es/*.po"
   check-xml-pl:
     image: *test_image
     pull: true
@@ -147,10 +143,9 @@ steps:
     depends_on: prepare
     when:
         - path:
-          include:
-           - "doc/po/pl/*.po"
-          event: push
+           include:
+            - "doc/po/pl/*.po"
   check-xml-ko_KR:
     image: *test_image
     pull: true
@@ -159,10 +154,9 @@ steps:
     depends_on: prepare
     when:
         - path:
-          include:
-           - "doc/po/ko_KR/*.po"
-          event: push
+           include:
+            - "doc/po/ko_KR/*.po"
   check-xml-de:
     image: *test_image
     pull: true
@@ -171,10 +165,9 @@ steps:
     depends_on: prepare
     when:
         - path:
-          include:
-           - "doc/po/de/*.po"
-          event: push
+           include:
+            - "doc/po/de/*.po"
   check-xml-ja:
     image: *test_image
     pull: true
@@ -183,10 +176,9 @@ steps:
     depends_on: prepare
     when:
         - path:
-          include:
-           - "doc/po/ja/*.po"
-          event: push
+           include:
+            - "doc/po/ja/*.po"
   check-xml-ru:
     image: *test_image
     pull: true
@@ -195,10 +187,9 @@ steps:
     depends_on: prepare
     when:
         - path:
-          include:
-           - "doc/po/ru/*.po"
-          event: push
+           include:
+            - "doc/po/ru/*.po"
   check-xml-zh_Hans:
     image: *test_image
     pull: true
@@ -207,10 +198,9 @@ steps:
     depends_on: prepare
     when:
         - path:
-          include:
-           - "doc/po/zh_Hans/*.po"
-          event: push
+           include:
+            - "doc/po/zh_Hans/*.po"
   check-xml-ro:
     image: *test_image
     pull: true
@@ -219,10 +209,9 @@ steps:
     depends_on: prepare
     when:
         - path:
-          include:
-           - "doc/po/ro/*.po"
-          event: push
+           include:
+            - "doc/po/ro/*.po"
   check-xml-uk:
     image: *test_image
     pull: true
@@ -231,10 +220,9 @@ steps:
     depends_on: prepare
     when:
         - path:
-          include:
-           - "doc/po/uk/*.po"
-          event: push
+           include:
+            - "doc/po/uk/*.po"
 ### TARGET html
   html-it_IT:
     image: *test_image
@@ -244,10 +232,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   html-pt_BR:
     image: *test_image
     pull: true
@@ -256,10 +243,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   html-fr:
     image: *test_image
     pull: true
@@ -268,10 +254,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   html-es:
     image: *test_image
     pull: true
@@ -280,10 +265,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   html-pl:
     image: *test_image
     pull: true
@@ -292,10 +276,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   html-ko_KR:
     image: *test_image
     pull: true
@@ -304,10 +287,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   html-de:
     image: *test_image
     pull: true
@@ -316,10 +298,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   html-ja:
     image: *test_image
     pull: true
@@ -328,10 +309,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   html-ru:
     image: *test_image
     pull: true
@@ -340,10 +320,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   html-zh_Hans:
     image: *test_image
     pull: true
@@ -352,10 +331,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   html-ro:
     image: *test_image
     pull: true
@@ -364,10 +342,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   html-uk:
     image: *test_image
     pull: true
@@ -376,10 +353,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   cheatsheets-it_IT:
     image: *test_image
@@ -389,10 +365,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   cheatsheets-pt_BR:
     image: *test_image
     pull: true
@@ -401,10 +376,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   cheatsheets-fr:
     image: *test_image
     pull: true
@@ -413,10 +387,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   cheatsheets-es:
     image: *test_image
     pull: true
@@ -425,10 +398,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   cheatsheets-pl:
     image: *test_image
     pull: true
@@ -437,10 +409,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   cheatsheets-ko_KR:
     image: *test_image
     pull: true
@@ -449,10 +420,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   cheatsheets-de:
     image: *test_image
     pull: true
@@ -461,10 +431,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   cheatsheets-ja:
     image: *test_image
     pull: true
@@ -473,10 +442,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   cheatsheets-ru:
     image: *test_image
     pull: true
@@ -485,10 +453,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
     image: *test_image
     pull: true
@@ -497,10 +464,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   cheatsheets-ro:
     image: *test_image
     pull: true
@@ -509,10 +475,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   cheatsheets-uk:
     image: *test_image
     pull: true
@@ -521,10 +486,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
     image: *test_image
@@ -534,10 +498,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
     image: *test_image
     pull: true
@@ -546,10 +509,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
     image: *test_image
     pull: true
@@ -558,10 +520,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
     image: *test_image
     pull: true
@@ -570,10 +531,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
     image: *test_image
     pull: true
@@ -582,10 +542,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
     image: *test_image
     pull: true
@@ -594,10 +553,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
     image: *test_image
     pull: true
@@ -606,10 +564,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
     image: *test_image
     pull: true
@@ -618,10 +575,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
     image: *test_image
     pull: true
@@ -630,10 +586,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
     image: *test_image
     pull: true
@@ -642,10 +597,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
     image: *test_image
     pull: true
@@ -654,10 +608,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
     image: *test_image
     pull: true
@@ -666,10 +619,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
 ### TARGET pdf
   pdf-it_IT:
     image: *test_image
@@ -679,10 +631,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   pdf-pt_BR:
     image: *test_image
     pull: true
@@ -691,10 +642,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   pdf-fr:
     image: *test_image
     pull: true
@@ -703,10 +653,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   pdf-es:
     image: *test_image
     pull: true
@@ -715,10 +664,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   pdf-pl:
     image: *test_image
     pull: true
@@ -727,10 +675,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   pdf-ko_KR:
     image: *test_image
     pull: true
@@ -739,10 +686,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   pdf-de:
     image: *test_image
     pull: true
@@ -751,10 +697,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   pdf-ja:
     image: *test_image
     pull: true
@@ -763,10 +708,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   pdf-ru:
     image: *test_image
     pull: true
@@ -775,10 +719,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   pdf-zh_Hans:
     image: *test_image
     pull: true
@@ -787,10 +730,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   pdf-ro:
     image: *test_image
     pull: true
@@ -799,10 +741,9 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
   pdf-uk:
     image: *test_image
     pull: true
@@ -811,7 +752,6 @@ steps:
     when:
         - path:
-          include:
-          event: push
+           include:
commit dcb7fb0ce61f14459eade4e291de906100bc8a23
Date:   Fri Mar 22 22:23:55 2024 -0400
index b9fb04c52..2c16e0870 100644
@@ -5,8 +5,8 @@
     depends_on: @DEP@
     when:
-      - event: push
-      - event: pull_request
-        path:
-         include:
+        - path:
+          include:
+          event: push
+          event: pull_request
index 9479324c0..936f97430 100644
@@ -98,11 +98,11 @@ steps:
     depends_on: prepare
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   check-xml-pt_BR:
     image: *test_image
     pull: true
@@ -110,11 +110,11 @@ steps:
     depends_on: prepare
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   check-xml-fr:
     image: *test_image
     pull: true
@@ -122,11 +122,11 @@ steps:
     depends_on: prepare
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   check-xml-es:
     image: *test_image
     pull: true
@@ -134,11 +134,11 @@ steps:
     depends_on: prepare
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   check-xml-pl:
     image: *test_image
     pull: true
@@ -146,11 +146,11 @@ steps:
     depends_on: prepare
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   check-xml-ko_KR:
     image: *test_image
     pull: true
@@ -158,11 +158,11 @@ steps:
     depends_on: prepare
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   check-xml-de:
     image: *test_image
     pull: true
@@ -170,11 +170,11 @@ steps:
     depends_on: prepare
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   check-xml-ja:
     image: *test_image
     pull: true
@@ -182,11 +182,11 @@ steps:
     depends_on: prepare
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   check-xml-ru:
     image: *test_image
     pull: true
@@ -194,11 +194,11 @@ steps:
     depends_on: prepare
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   check-xml-zh_Hans:
     image: *test_image
     pull: true
@@ -206,11 +206,11 @@ steps:
     depends_on: prepare
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   check-xml-ro:
     image: *test_image
     pull: true
@@ -218,11 +218,11 @@ steps:
     depends_on: prepare
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   check-xml-uk:
     image: *test_image
     pull: true
@@ -230,11 +230,11 @@ steps:
     depends_on: prepare
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
 ### TARGET html
   html-it_IT:
     image: *test_image
@@ -243,11 +243,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   html-pt_BR:
     image: *test_image
     pull: true
@@ -255,11 +255,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   html-fr:
     image: *test_image
     pull: true
@@ -267,11 +267,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   html-es:
     image: *test_image
     pull: true
@@ -279,11 +279,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   html-pl:
     image: *test_image
     pull: true
@@ -291,11 +291,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   html-ko_KR:
     image: *test_image
     pull: true
@@ -303,11 +303,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   html-de:
     image: *test_image
     pull: true
@@ -315,11 +315,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   html-ja:
     image: *test_image
     pull: true
@@ -327,11 +327,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   html-ru:
     image: *test_image
     pull: true
@@ -339,11 +339,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   html-zh_Hans:
     image: *test_image
     pull: true
@@ -351,11 +351,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   html-ro:
     image: *test_image
     pull: true
@@ -363,11 +363,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   html-uk:
     image: *test_image
     pull: true
@@ -375,11 +375,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   cheatsheets-it_IT:
     image: *test_image
@@ -388,11 +388,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   cheatsheets-pt_BR:
     image: *test_image
     pull: true
@@ -400,11 +400,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   cheatsheets-fr:
     image: *test_image
     pull: true
@@ -412,11 +412,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   cheatsheets-es:
     image: *test_image
     pull: true
@@ -424,11 +424,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   cheatsheets-pl:
     image: *test_image
     pull: true
@@ -436,11 +436,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   cheatsheets-ko_KR:
     image: *test_image
     pull: true
@@ -448,11 +448,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   cheatsheets-de:
     image: *test_image
     pull: true
@@ -460,11 +460,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   cheatsheets-ja:
     image: *test_image
     pull: true
@@ -472,11 +472,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   cheatsheets-ru:
     image: *test_image
     pull: true
@@ -484,11 +484,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
     image: *test_image
     pull: true
@@ -496,11 +496,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   cheatsheets-ro:
     image: *test_image
     pull: true
@@ -508,11 +508,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   cheatsheets-uk:
     image: *test_image
     pull: true
@@ -520,11 +520,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
     image: *test_image
@@ -533,11 +533,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
     image: *test_image
     pull: true
@@ -545,11 +545,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
     image: *test_image
     pull: true
@@ -557,11 +557,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
     image: *test_image
     pull: true
@@ -569,11 +569,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
     image: *test_image
     pull: true
@@ -581,11 +581,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
     image: *test_image
     pull: true
@@ -593,11 +593,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
     image: *test_image
     pull: true
@@ -605,11 +605,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
     image: *test_image
     pull: true
@@ -617,11 +617,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
     image: *test_image
     pull: true
@@ -629,11 +629,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
     image: *test_image
     pull: true
@@ -641,11 +641,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
     image: *test_image
     pull: true
@@ -653,11 +653,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
     image: *test_image
     pull: true
@@ -665,11 +665,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
 ### TARGET pdf
   pdf-it_IT:
     image: *test_image
@@ -678,11 +678,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   pdf-pt_BR:
     image: *test_image
     pull: true
@@ -690,11 +690,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   pdf-fr:
     image: *test_image
     pull: true
@@ -702,11 +702,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   pdf-es:
     image: *test_image
     pull: true
@@ -714,11 +714,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   pdf-pl:
     image: *test_image
     pull: true
@@ -726,11 +726,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   pdf-ko_KR:
     image: *test_image
     pull: true
@@ -738,11 +738,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   pdf-de:
     image: *test_image
     pull: true
@@ -750,11 +750,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   pdf-ja:
     image: *test_image
     pull: true
@@ -762,11 +762,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   pdf-ru:
     image: *test_image
     pull: true
@@ -774,11 +774,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   pdf-zh_Hans:
     image: *test_image
     pull: true
@@ -786,11 +786,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   pdf-ro:
     image: *test_image
     pull: true
@@ -798,11 +798,11 @@ steps:
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
   pdf-uk:
     image: *test_image
     pull: true
     when:
-      - event: push
-        path:
-         include:
+        - path:
+          include:
+          event: push
commit 36266d326e4ffb28edcab2be6faba10ef56c425c
Date:   Fri Mar 22 22:16:56 2024 -0400
index ae3c7002e..9479324c0 100644
@@ -32,8 +32,7 @@ steps:
       - xmllint --version
     when:
-          path:
-            - <<: *when_path_full
+          path: *when_path_full
   check-xml:
     image: *test_image
commit 5a92e9f1dc8427df95c8f7e8cd4a1a3ce2a04870
Date:   Fri Mar 22 22:15:10 2024 -0400
index 217882115..ae3c7002e 100644
@@ -31,8 +31,10 @@ steps:
       - xmllint --version
     when:
+        - event: [tag, pull_request, push]
+          path:
+            - <<: *when_path_full
   check-xml:
     image: *test_image
     pull: true
Summary of changes:
 .woodpecker/docs-localized.yml.in |   6 +-
 .woodpecker/docs.yml              | 369 +++++++++++++++++++-------------------
 2 files changed, 188 insertions(+), 187 deletions(-)
hooks/post-receive
