[SCM] PostGIS branch stable-3.4 updated. 3.4.2-25-gabfd6a99a
Sun Mar 24 05:56:11 PDT 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  abfd6a99a59d741cdce010b63e7b69505b15dfcd (commit)
      from  c1e36f1e5f40f7fc835429a48a01458e05239f74 (commit)
revisions in full, below.
commit abfd6a99a59d741cdce010b63e7b69505b15dfcd
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Mar 24 08:56:07 2024 -0400
    Quiet bad_habit Please set an event filter warnings. Missed some spots
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 5b37a9994..00e085186 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -31,7 +31,9 @@ steps:
       - make postgis_revision.h
       - xmllint --version
     when:
-      path: *when_path_full
+        - event: push
+          path: *when_path_full
   check-xml:
     image: *test_image
     pull: true
@@ -39,7 +41,8 @@ steps:
     commands:
       - make -C build-docs/doc check
     when:
-      path: *when_path
+      - path: *when_path
+        event: [tag, pull_request, push]
   build-images:
     image: *test_image
     pull: true
@@ -47,7 +50,8 @@ steps:
     commands:
       - make -C build-docs/doc images
     when:
+      - path: *when_path_full
   build-html:
     image: *test_image
     pull: true
@@ -55,7 +59,8 @@ steps:
     commands:
       - make -C build-docs/doc html
     when:
-      path: *when_path
   build-cheatsheets:
     image: *test_image
     pull: true
@@ -63,7 +68,8 @@ steps:
     commands:
       - make -C build-docs/doc/ cheatsheets
     when:
-      path: *when_path
   build-chunked-html:
     image: *test_image
     pull: true
@@ -71,7 +77,8 @@ steps:
     commands:
     when:
-      path: *when_path
   build-pdf:
     image: *test_image
     pull: true
@@ -79,7 +86,8 @@ steps:
     commands:
       - make -C build-docs/doc/ pdf
     when:
-      path: *when_path
   # DO NOT EDIT PAST THIS LINE, use update-docs-localized.sh to update #
 ### TARGET check-xml
Summary of changes:
 .woodpecker/docs.yml | 22 +++++++++++++++-------
 1 file changed, 15 insertions(+), 7 deletions(-)
hooks/post-receive
