[SCM] PostGIS branch master updated. 3.4.0rc1-1063-g3cb5ad154
Sun Mar 24 08:06:17 PDT 2024
the project "PostGIS".
       via  3cb5ad154268898901aea7577b33399c6b958dc2 (commit)
       via  62f95f9b1b5141a202fdb837b61162ed4fb72b1b (commit)
       via  2be64fb9ab5a275350e42fbb08236d04f9b798b8 (commit)
       via  3b2562143b2fc1a059cd884b9d62c6bb3454ac0a (commit)
       via  4195f89fab5e7582c4a93c41de274d0d92a69d6f (commit)
      from  c25c64341c5a31ecb0bbcd17740bb000bd9cf759 (commit)
revisions in full, below.
commit 3cb5ad154268898901aea7577b33399c6b958dc2
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Tue Mar 19 14:35:24 2024 +0100
    SFCGAL: copy/paste tests from ST_ to CG_
diff --git a/sfcgal/regress/regress_sfcgal.sql b/sfcgal/regress/regress_sfcgal.sql
index 87277db38..bbbc8fe3a 100644
--- a/sfcgal/regress/regress_sfcgal.sql
+++ b/sfcgal/regress/regress_sfcgal.sql
@@ -6,6 +6,7 @@
 -- Behaviour is already handled by SFCGAL own tests
 SELECT 'postgis_sfcgal_version', count(*) FROM (SELECT postgis_sfcgal_version()) AS f;
+SELECT 'postgis_sfcgal_noop', ST_NPoints(postgis_sfcgal_noop(ST_Buffer('POINT(0 0)', 5)));
 SELECT 'ST_Tesselate', ST_AsText(ST_Tesselate('GEOMETRYCOLLECTION(POINT(4 4),POLYGON((0 0,1 0,1 1,0 1,0 0)))'));
 SELECT 'ST_3DArea', ST_3DArea('POLYGON((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0))');
 SELECT 'ST_Extrude_point', ST_AsText(ST_Extrude('POINT(0 0)', 1, 0, 0));
@@ -28,17 +29,7 @@ SELECT 'ST_ForceLHR', ST_AsText(ST_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
 SELECT 'ST_Orientation_1', ST_Orientation(ST_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
 SELECT 'ST_Orientation_2', ST_Orientation(ST_ForceRHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
 SELECT 'ST_MinkowskiSum', ST_AsText(ST_MinkowskiSum('LINESTRING(0 0,4 0)','POLYGON((0 0,1 0,1 1,0 1,0 0))'));
-SELECT 'CG_StraightSkeleton', ST_AsText(CG_StraightSkeleton('POLYGON((1 1,2 1,2 2,1 2,1 1))'));
-SELECT 'CG_StraightSkeletonUseMDistance',
-CASE WHEN string_to_array(postgis_sfcgal_version(), '.')::int[] >= string_to_array('1.3.8', '.')::int[]
-THEN
-	ST_AsText(CG_StraightSkeleton('POLYGON((0 0,1 0,1 1,0 1,0 0))', true))
-ELSE
-	-- export result directly
-	'MULTILINESTRING M ((0 0 0,0.5 0.5 0.5),(1 0 0,0.5 0.5 0.5),(1 1 0,0.5 0.5 0.5),(0 1 0,0.5 0.5 0.5))'
-END;
 SELECT 'ST_ConstrainedDelaunayTriangles', ST_AsText(ST_ConstrainedDelaunayTriangles('GEOMETRYCOLLECTION(POINT(0 0), POLYGON((2 2, 2 -2, 4 0, 2 2)))'));
-SELECT 'postgis_sfcgal_noop', ST_NPoints(postgis_sfcgal_noop(ST_Buffer('POINT(0 0)', 5)));
 SELECT 'ST_3DConvexHull', ST_3DArea(ST_3DConvexHull('MULTIPOINTZ(0 0 5, 1 5 3, 5 7 6, 9 5 3 , 5 7 5, 6 3 5)'))::numeric(10,4);
 -- Result of ST_3DUnion is not deterministic and cannot be checked by
 -- simple string comparison
@@ -52,6 +43,50 @@ SELECT 'ST_3DUnion (aggregate)', ABS(ST_Volume(ST_3DUnion(g))) - 40 < 1e-12 FROM
     SELECT ST_Extrude(ST_GeomFromText('POLYGON((-1 -1 -2, 1 -1 -2, 1 1 -2, -1 1 -2, -1 -1 -2))'), 0, 0, 4) AS g
 ) AS f;
+SELECT 'CG_Tesselate', ST_AsText(CG_Tesselate('GEOMETRYCOLLECTION(POINT(4 4),POLYGON((0 0,1 0,1 1,0 1,0 0)))'));
+SELECT 'CG_3DArea', CG_3DArea('POLYGON((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0))');
+SELECT 'CG_Extrude_point', ST_AsText(CG_Extrude('POINT(0 0)', 1, 0, 0));
+SELECT 'CG_Extrude_line', ST_AsText(CG_Extrude(CG_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0));
+-- In the first SFCGAL versions, the extruded face was wrongly oriented
+-- we change the extrusion result to match the original
+SELECT 'CG_Extrude_surface',
+CASE WHEN postgis_sfcgal_version() = '1.0'
+THEN
+    ST_AsText(CG_Extrude(CG_Extrude(CG_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0), 0, 0, 1))
+ELSE
+    regexp_replace(
+    regexp_replace(
+    ST_AsText(CG_Extrude(CG_Extrude(CG_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0), 0, 0, 1)) ,
+    E'\\(\\(0 1 0,1 1 0,1 0 0,0 1 0\\)\\)', '((1 1 0,1 0 0,0 1 0,1 1 0))'),
+    E'\\(\\(0 1 0,1 0 0,0 0 0,0 1 0\\)\\)', '((1 0 0,0 0 0,0 1 0,1 0 0))')
+END;
+SELECT 'CG_ForceLHR', ST_AsText(CG_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
+SELECT 'CG_Orientation_1', CG_Orientation(CG_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
+SELECT 'CG_Orientation_2', CG_Orientation(ST_ForceRHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
+SELECT 'CG_MinkowskiSum', ST_AsText(CG_MinkowskiSum('LINESTRING(0 0,4 0)','POLYGON((0 0,1 0,1 1,0 1,0 0))'));
+SELECT 'CG_ConstrainedDelaunayTriangles', ST_AsText(CG_ConstrainedDelaunayTriangles('GEOMETRYCOLLECTION(POINT(0 0), POLYGON((2 2, 2 -2, 4 0, 2 2)))'));
+SELECT 'CG_3DConvexHull', CG_3DArea(CG_3DConvexHull('MULTIPOINTZ(0 0 5, 1 5 3, 5 7 6, 9 5 3 , 5 7 5, 6 3 5)'))::numeric(10,4);
+-- Result of CG_3DUnion is not deterministic and cannot be checked by
+-- simple string comparison
+SELECT 'CG_3DUnion', ABS(CG_Volume(CG_3DUnion(g1, g2)) - 40) < 1e-12 FROM (
+    SELECT CG_Extrude(ST_GeomFromText('POLYGON((-2 -2 -1, 2 -2 -1, 2 2 -1, -2 2 -1, -2 -2 -1))'), 0, 0, 2) AS g1,
+    CG_Extrude(ST_GeomFromText('POLYGON((-1 -1 -2, 1 -1 -2, 1 1 -2, -1 1 -2, -1 -1 -2))'), 0, 0, 4) AS g2
+) AS f;
+SELECT 'CG_3DUnion (aggregate)', ABS(CG_Volume(CG_3DUnion(g))) - 40 < 1e-12 FROM (
+    UNION
+    SELECT CG_Extrude(ST_GeomFromText('POLYGON((-1 -1 -2, 1 -1 -2, 1 1 -2, -1 1 -2, -1 -1 -2))'), 0, 0, 4) AS g
+) AS f;
+SELECT 'CG_StraightSkeleton', ST_AsText(CG_StraightSkeleton('POLYGON((1 1,2 1,2 2,1 2,1 1))'));
+SELECT 'CG_StraightSkeletonUseMDistance',
+CASE WHEN string_to_array(postgis_sfcgal_version(), '.')::int[] >= string_to_array('1.3.8', '.')::int[]
+THEN
+	ST_AsText(CG_StraightSkeleton('POLYGON((0 0,1 0,1 1,0 1,0 0))', true))
+ELSE
+	-- export result directly
+	'MULTILINESTRING M ((0 0 0,0.5 0.5 0.5),(1 0 0,0.5 0.5 0.5),(1 1 0,0.5 0.5 0.5),(0 1 0,0.5 0.5 0.5))'
+END;
 SELECT 'CG_Distance', CG_Distance('LINESTRING(0.0 0.0,-1.0 -1.0)', 'LINESTRING(3.0 4.0,4.0 5.0)');
 SELECT 'CG_3DDistance', CG_3DDistance('LINESTRING(-1.0 0.0 2.0,1.0 0.0 3.0)', 'TRIANGLE((-4.0 0.0 1.0,4.0 0.0 1.0,0.0 4.0 1.0,-4.0 0.0 1.0))');
 SELECT 'CG_Area', CG_Area('Polygon ((0 0, 0 5, 5 5, 5 0, 0 0), (1 1, 2 1, 2 2, 1 2, 1 1), (3 3, 4 3, 4 4, 3 4, 3 3))');
diff --git a/sfcgal/regress/regress_sfcgal_expected b/sfcgal/regress/regress_sfcgal_expected
index 3afb45430..772eeb04f 100644
--- a/sfcgal/regress/regress_sfcgal_expected
+++ b/sfcgal/regress/regress_sfcgal_expected
@@ -1,4 +1,5 @@
 postgis_sfcgal_version|1
+postgis_sfcgal_noop|33
 ST_Tesselate|GEOMETRYCOLLECTION(POINT(4 4),TIN(((0 1,1 0,1 1,0 1)),((0 1,0 0,1 0,0 1))))
 ST_3DArea|1
 ST_Extrude_point|LINESTRING Z (0 0 0,1 0 0)
@@ -8,13 +9,25 @@ ST_ForceLHR|POLYGON((0 0,1 0,1 1,0 1,0 0))
 ST_Orientation_1|-1
 ST_Orientation_2|1
 ST_MinkowskiSum|MULTIPOLYGON(((0 0,1 0,5 0,5 1,4 1,0 1,0 0)))
-CG_StraightSkeleton|MULTILINESTRING((1 1,1.5 1.5),(2 1,1.5 1.5),(2 2,1.5 1.5),(1 2,1.5 1.5))
-CG_StraightSkeletonUseMDistance|MULTILINESTRING M ((0 0 0,0.5 0.5 0.5),(1 0 0,0.5 0.5 0.5),(1 1 0,0.5 0.5 0.5),(0 1 0,0.5 0.5 0.5))
 ST_ConstrainedDelaunayTriangles|TIN(((4 0,2 2,2 -2,4 0)),((2 2,0 0,2 -2,2 2)))
-postgis_sfcgal_noop|33
 ST_3DConvexHull|80.9227
 ST_3DUnion|t
 ST_3DUnion (aggregate)|t
+CG_Tesselate|GEOMETRYCOLLECTION(POINT(4 4),TIN(((0 1,1 0,1 1,0 1)),((0 1,0 0,1 0,0 1))))
+CG_3DArea|1
+CG_Extrude_point|LINESTRING Z (0 0 0,1 0 0)
+CG_Extrude_line|POLYHEDRALSURFACE Z (((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0)))
+CG_Extrude_surface|POLYHEDRALSURFACE Z (((1 1 0,1 0 0,0 1 0,1 1 0)),((0 1 1,1 0 1,1 1 1,0 1 1)),((1 0 0,0 0 0,0 1 0,1 0 0)),((0 1 1,0 0 1,1 0 1,0 1 1)),((1 0 0,1 1 0,1 1 1,1 0 1,1 0 0)),((1 1 0,0 1 0,0 1 1,1 1 1,1 1 0)),((0 1 0,0 0 0,0 0 1,0 1 1,0 1 0)),((0 0 0,1 0 0,1 0 1,0 0 1,0 0 0)))
+CG_ForceLHR|POLYGON((0 0,1 0,1 1,0 1,0 0))
+CG_Orientation_1|-1
+CG_Orientation_2|1
+CG_MinkowskiSum|MULTIPOLYGON(((0 0,1 0,5 0,5 1,4 1,0 1,0 0)))
+CG_ConstrainedDelaunayTriangles|TIN(((4 0,2 2,2 -2,4 0)),((2 2,0 0,2 -2,2 2)))
+CG_3DConvexHull|80.9227
+CG_3DUnion|t
+CG_3DUnion (aggregate)|t
+CG_StraightSkeleton|MULTILINESTRING((1 1,1.5 1.5),(2 1,1.5 1.5),(2 2,1.5 1.5),(1 2,1.5 1.5))
+CG_StraightSkeletonUseMDistance|MULTILINESTRING M ((0 0 0,0.5 0.5 0.5),(1 0 0,0.5 0.5 0.5),(1 1 0,0.5 0.5 0.5),(0 1 0,0.5 0.5 0.5))
 CG_Distance|5
 CG_3DDistance|1
 CG_Area|23
commit 62f95f9b1b5141a202fdb837b61162ed4fb72b1b
Date:   Mon Mar 18 11:03:30 2024 +0100
    Add NEWS entry
diff --git a/NEWS b/NEWS
index 878fc9099..6a469da99 100644
--- a/NEWS
+++ b/NEWS
@@ -32,6 +32,8 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
 * Deprecated signatures *
   - GH-761, ST_StraightSkeleton => CG_StraightSkeleton (Loïc Bartoletti)
+  - GT-189, All SFCGAL functions now use the prefix CG_, with the old onesusing
+            ST_ being deprecated. (Loïc Bartoletti)
 * New Features *
commit 2be64fb9ab5a275350e42fbb08236d04f9b798b8
Date:   Wed Mar 13 17:46:09 2024 +0100
    SFCGAL: Update documentation with new CG_ methods and deprecate ST_ ones
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index f8f7e696f..3e71101e9 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -90,10 +90,9 @@
                 <para>These functions access or set properties of geometries. Geometries primarily supported by these functions are TINS and Polyhedral Surfaces.</para>
             </abstract>
         </info>
-        <refentry xml:id="ST_ForceLHR">
+        <refentry xml:id="CG_ForceLHR">
             <refnamediv>
-                <refname>ST_ForceLHR</refname>
+                <refname>CG_ForceLHR</refname>
                 <refpurpose>Force LHR orientation</refpurpose>
             </refnamediv>
@@ -101,7 +100,7 @@
             <refsynopsisdiv>
                 <funcsynopsis>
                     <funcprototype>
-                        <funcdef>geometry <function>ST_ForceLHR</function></funcdef>
+                        <funcdef>geometry <function>CG_ForceLHR</function></funcdef>
                         <paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
                     </funcprototype>
                 </funcsynopsis>
@@ -110,7 +109,7 @@
             <refsection>
                 <title>Description</title>
-                <para role="availability" conformance="2.1.0">Availability: 2.1.0</para>
+                <para role="availability" conformance="3.5.0">Availability: 3.5.0</para>
                 <para>&sfcgal_required;</para>
                 <para>&Z_support;</para>
                 <para>&P_support;</para>
@@ -119,9 +118,9 @@
         </refentry>
-        <refentry xml:id="ST_IsPlanar">
+        <refentry xml:id="CG_IsPlanar">
             <refnamediv>
-                <refname>ST_IsPlanar</refname>
+                <refname>CG_IsPlanar</refname>
                 <refpurpose>Check if a surface is or not planar</refpurpose>
             </refnamediv>
@@ -129,7 +128,7 @@
             <refsynopsisdiv>
                 <funcsynopsis>
                     <funcprototype>
-                        <funcdef>boolean <function>ST_IsPlanar</function></funcdef>
+                        <funcdef>boolean <function>CG_IsPlanar</function></funcdef>
                     </funcprototype>
                 </funcsynopsis>
@@ -138,7 +137,7 @@
             <refsection>
-                <para role="availability" conformance="2.2.0">Availability: 2.2.0: This was documented in 2.1.0 but got accidentally left out in 2.1 release.</para>
@@ -147,9 +146,9 @@
         </refentry>
-        <refentry xml:id="ST_IsSolid">
+        <refentry xml:id="CG_IsSolid">
             <refnamediv>
-                <refname>ST_IsSolid</refname>
+                <refname>CG_IsSolid</refname>
                 <refpurpose>Test if the geometry is a solid. No validity check is performed.</refpurpose>
             </refnamediv>
@@ -157,7 +156,7 @@
             <refsynopsisdiv>
                 <funcsynopsis>
                     <funcprototype>
-                        <funcdef>boolean <function>ST_IsSolid</function></funcdef>
+                        <funcdef>boolean <function>CG_IsSolid</function></funcdef>
                         <paramdef><type>geometry</type> <parameter>geom1</parameter></paramdef>
                     </funcprototype>
                 </funcsynopsis>
@@ -166,7 +165,7 @@
             <refsection>
-                <para role="availability" conformance="2.2.0">Availability: 2.2.0</para>
@@ -175,9 +174,9 @@
         </refentry>
-        <refentry xml:id="ST_MakeSolid">
+        <refentry xml:id="CG_MakeSolid">
             <refnamediv>
-                <refname>ST_MakeSolid</refname>
+                <refname>CG_MakeSolid</refname>
                 <refpurpose>Cast the geometry into a solid. No check is performed. To obtain a valid solid, the input geometry must be a closed Polyhedral Surface or a closed TIN.</refpurpose>
             </refnamediv>
@@ -185,7 +184,7 @@
             <refsynopsisdiv>
                 <funcsynopsis>
                     <funcprototype>
-                        <funcdef>geometry <function>ST_MakeSolid</function></funcdef>
+                        <funcdef>geometry <function>CG_MakeSolid</function></funcdef>
                     </funcprototype>
                 </funcsynopsis>
@@ -194,7 +193,7 @@
             <refsection>
@@ -202,9 +201,9 @@
             </refsection>
         </refentry>
-        <refentry xml:id="ST_Orientation">
+        <refentry xml:id="CG_Orientation">
             <refnamediv>
-                <refname>ST_Orientation</refname>
+                <refname>CG_Orientation</refname>
                 <refpurpose>Determine surface orientation</refpurpose>
             </refnamediv>
@@ -212,7 +211,7 @@
             <refsynopsisdiv>
                 <funcsynopsis>
                     <funcprototype>
-                        <funcdef>integer <function>ST_Orientation</function></funcdef>
+                        <funcdef>integer <function>CG_Orientation</function></funcdef>
                     </funcprototype>
                 </funcsynopsis>
@@ -223,7 +222,7 @@
                 <para>The function only applies to polygons. It returns -1 if the polygon is counterclockwise oriented and 1 if the polygon is clockwise oriented.</para>
             </refsection>
@@ -270,6 +269,278 @@
         </refsection>
     </refentry>
+    <refentry xml:id="CG_3DArea">
+        <refnamediv>
+            <refname>CG_3DArea</refname>
+            <refpurpose>Computes area of 3D surface geometries.  Will return 0 for solids.</refpurpose>
+        </refnamediv>
+        <refsynopsisdiv>
+            <funcsynopsis>
+                <funcprototype>
+                    <funcdef>float<function>CG_3DArea</function></funcdef>
+                    <paramdef><type>geometry</type> <parameter>geom1</parameter></paramdef>
+                </funcprototype>
+            </funcsynopsis>
+        </refsynopsisdiv>
+        <refsection>
+            <title>Description</title>
+            <para>&sfcgal_required;</para>
+            <para>&sqlmm_compliant; SQL-MM IEC 13249-3: 8.1, 10.5</para>
+            <para>&Z_support;</para>
+            <para>&P_support;</para>
+            <para>&T_support;</para>
+        </refsection>
+        <refsection><title>Examples</title>
+            <para>Note: By default a PolyhedralSurface built from WKT is a surface geometry, not solid.  It therefore has surface area.  Once converted to a solid, no area.</para>
+            <programlisting>SELECT CG_3DArea(geom) As cube_surface_area,
+            CG_3DArea(CG_MakeSolid(geom)) As solid_surface_area
+            FROM (SELECT 'POLYHEDRALSURFACE( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
+            ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)),
+            ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)),
+            ((1 1 0, 1 1 1, 1 0 1, 1 0 0, 1 1 0)),
+            ((0 1 0, 0 1 1, 1 1 1, 1 1 0, 0 1 0)),
+            ((0 0 1, 1 0 1, 1 1 1, 0 1 1, 0 0 1)) )'::geometry) As f(geom);
+            cube_surface_area | solid_surface_area
+            6 |                  0    </programlisting>
+    </refsection>
+    <refsection>
+        <title>See Also</title>
+        <para><xref linkend="CG_Area"/>, <xref linkend="CG_MakeSolid"/>, <xref linkend="CG_IsSolid"/>, <xref linkend="CG_Area"/></para>
+    </refsection>
+</refentry>
+<refentry xml:id="CG_Volume">
+    <refnamediv>
+        <refname>CG_Volume</refname>
+        <refpurpose>Computes the volume of a 3D solid. If applied to surface (even closed) geometries will return 0.</refpurpose>
+    </refnamediv>
+    <refsynopsisdiv>
+        <funcsynopsis>
+            <funcprototype>
+                <funcdef>float <function>CG_Volume</function></funcdef>
+            </funcprototype>
+        </funcsynopsis>
+    </refsynopsisdiv>
+    <refsection>
+        <para>&sqlmm_compliant; SQL-MM IEC 13249-3: 9.1 (same as CG_3DVolume)</para>
+    </refsection>
+    <refsection>
+        <title>Example</title>
+        <para>When closed surfaces are created with WKT, they are treated as areal rather than solid.  To make them solid, you need to use <xref linkend="CG_MakeSolid"/>.
+        Areal geometries have no volume.  Here is an example to demonstrate.</para>
+    <programlisting>SELECT CG_Volume(geom) As cube_surface_vol,
+    CG_Volume(CG_MakeSolid(geom)) As solid_surface_vol
+    cube_surface_vol | solid_surface_vol
+    0 |                 1
+</programlisting>
+    </refsection>
+    <refsection>
+        <para><xref linkend="CG_3DArea"/>, <xref linkend="CG_MakeSolid"/>, <xref linkend="CG_IsSolid"/></para>
+    </refsection>
+</refentry>
+        <refentry xml:id="ST_ForceLHR">
+            <refnamediv>
+                <refname>ST_ForceLHR</refname>
+                <refpurpose>Force LHR orientation</refpurpose>
+            </refnamediv>
+            <refsynopsisdiv>
+                <funcsynopsis>
+                    <funcprototype>
+                        <funcdef>geometry <function>ST_ForceLHR</function></funcdef>
+                        <paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
+                    </funcprototype>
+                </funcsynopsis>
+            </refsynopsisdiv>
+            <refsection>
+                <warning>
+                    <para>
+                        <xref linkend="ST_ForceLHR"/> is deprecated as of 3.5.0. Use <xref linkend="CG_ForceLHR"/> instead.
+                    </para>
+                </warning>
+                <para role="availability" conformance="2.1.0">Availability: 2.1.0</para>
+            </refsection>
+        </refentry>
+        <refentry xml:id="ST_IsPlanar">
+            <refnamediv>
+                <refname>ST_IsPlanar</refname>
+                <refpurpose>Check if a surface is or not planar</refpurpose>
+            </refnamediv>
+            <refsynopsisdiv>
+                <funcsynopsis>
+                    <funcprototype>
+                        <funcdef>boolean <function>ST_IsPlanar</function></funcdef>
+                    </funcprototype>
+                </funcsynopsis>
+            </refsynopsisdiv>
+            <refsection>
+                <warning>
+                    <para>
+                        <xref linkend="ST_IsPlanar"/> is deprecated as of 3.5.0. Use <xref linkend="CG_IsPlanar"/> instead.
+                    </para>
+                </warning>
+                <para role="availability" conformance="2.2.0">Availability: 2.2.0: This was documented in 2.1.0 but got accidentally left out in 2.1 release.</para>
+            </refsection>
+        </refentry>
+        <refentry xml:id="ST_IsSolid">
+            <refnamediv>
+                <refname>ST_IsSolid</refname>
+                <refpurpose>Test if the geometry is a solid. No validity check is performed.</refpurpose>
+            </refnamediv>
+            <refsynopsisdiv>
+                <funcsynopsis>
+                    <funcprototype>
+                        <funcdef>boolean <function>ST_IsSolid</function></funcdef>
+                    </funcprototype>
+                </funcsynopsis>
+            </refsynopsisdiv>
+            <refsection>
+                <warning>
+                    <para>
+                        <xref linkend="ST_IsSolid"/> is deprecated as of 3.5.0. Use <xref linkend="CG_IsSolid"/> instead.
+                    </para>
+                </warning>
+                <para role="availability" conformance="2.2.0">Availability: 2.2.0</para>
+            </refsection>
+        </refentry>
+        <refentry xml:id="ST_MakeSolid">
+            <refnamediv>
+                <refname>ST_MakeSolid</refname>
+                <refpurpose>Cast the geometry into a solid. No check is performed. To obtain a valid solid, the input geometry must be a closed Polyhedral Surface or a closed TIN.</refpurpose>
+            </refnamediv>
+            <refsynopsisdiv>
+                <funcsynopsis>
+                    <funcprototype>
+                        <funcdef>geometry <function>ST_MakeSolid</function></funcdef>
+                    </funcprototype>
+                </funcsynopsis>
+            </refsynopsisdiv>
+            <refsection>
+                <warning>
+                    <para>
+                        <xref linkend="ST_MakeSolid"/> is deprecated as of 3.5.0. Use <xref linkend="CG_MakeSolid"/> instead.
+                    </para>
+                </warning>
+            </refsection>
+        </refentry>
+        <refentry xml:id="ST_Orientation">
+            <refnamediv>
+                <refname>ST_Orientation</refname>
+                <refpurpose>Determine surface orientation</refpurpose>
+            </refnamediv>
+            <refsynopsisdiv>
+                <funcsynopsis>
+                    <funcprototype>
+                        <funcdef>integer <function>ST_Orientation</function></funcdef>
+                    </funcprototype>
+                </funcsynopsis>
+            </refsynopsisdiv>
+            <refsection>
+                <warning>
+                    <para>
+                        <xref linkend="ST_Orientation"/> is deprecated as of 3.5.0. Use <xref linkend="CG_Orientation"/> instead.
+                    </para>
+                </warning>
+                <para>The function only applies to polygons. It returns -1 if the polygon is counterclockwise oriented and 1 if the polygon is clockwise oriented.</para>
+            </refsection>
+        </refentry>
     <refentry xml:id="ST_3DArea">
         <refnamediv>
             <refname>ST_3DArea</refname>
@@ -289,6 +560,12 @@
         <refsection>
+            <warning>
+                <para>
+                    <xref linkend="ST_3DArea"/> is deprecated as of 3.5.0. Use <xref linkend="CG_3DArea"/> instead.
+                </para>
+            </warning>
@@ -339,6 +616,12 @@
     <refsection>
+        <warning>
+            <para>
+                <xref linkend="ST_Volume"/> is deprecated as of 3.5.0. Use <xref linkend="CG_Volume"/> instead.
+            </para>
+        </warning>
@@ -592,6 +875,13 @@
     <refsection>
+        <warning>
+            <para>
+                <xref linkend="ST_3DDifference"/> is deprecated as of 3.5.0. Use <xref linkend="CG_3DDifference"/> instead.
+            </para>
+        </warning>
         <para>Returns that part of geom1 that is not part of geom2.</para>
@@ -601,6 +891,43 @@
     </refsection>
+</refentry>
+<refentry xml:id="CG_3DDifference">
+    <refnamediv>
+        <refname>CG_3DDifference</refname>
+        <refpurpose>Perform 3D difference</refpurpose>
+    </refnamediv>
+    <refsynopsisdiv>
+        <funcsynopsis>
+            <funcprototype>
+                <funcdef>geometry <function>CG_3DDifference</function></funcdef>
+                <paramdef><type>geometry</type> <parameter>geom2</parameter></paramdef>
+            </funcprototype>
+        </funcsynopsis>
+    </refsynopsisdiv>
+    <refsection>
+        <warning>
+            <para>
+                <xref linkend="CG_3DDifference"/> is deprecated as of 3.5.0. Use <xref linkend="CG_3DDifference"/> instead.
+            </para>
+        </warning>
+        <para>Returns that part of geom1 that is not part of geom2.</para>
+        <para>&sqlmm_compliant; SQL-MM IEC 13249-3: 5.1</para>
+    </refsection>
     <refsection>
         <para>3D images were generated using PostGIS <xref linkend="ST_AsX3D"/> and rendering in HTML using <link xlink:href="http://www.x3dom.org">X3Dom HTML Javascript rendering library</link>.</para>
@@ -609,9 +936,9 @@
                 <tbody>
                     <row>
                         <entry><para>
-                                <programlisting>SELECT ST_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
+                                <programlisting>SELECT CG_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
                                 50, 'quad_segs=2'),0,0,30) AS geom1,
-                                ST_Extrude(ST_Buffer(ST_GeomFromText('POINT(80 80)'),
+                                CG_Extrude(ST_Buffer(ST_GeomFromText('POINT(80 80)'),
                                 50, 'quad_segs=1'),0,0,30) AS geom2;
                             </programlisting>
                             <informalfigure>
@@ -624,10 +951,10 @@
                         </informalfigure></para>
                     </entry>
                     <entry><para>
-                            <programlisting>SELECT ST_3DDifference(geom1,geom2)
-                            FROM ( SELECT ST_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
+                            <programlisting>SELECT CG_3DDifference(geom1,geom2)
+                            FROM ( SELECT CG_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
                             50, 'quad_segs=1'),0,0,30) AS geom2 ) As t;</programlisting>
                         <informalfigure>
                             <mediaobject>
@@ -649,9 +976,9 @@
         <para>
-            <xref linkend="ST_Extrude"/>,
-            <xref linkend="ST_AsX3D"/>,  <xref linkend="ST_3DIntersection"/>
-            <xref linkend="ST_3DUnion"/>
+            <xref linkend="CG_Extrude"/>,
+            <xref linkend="ST_AsX3D"/>,  <xref linkend="CG_3DIntersection"/>
+            <xref linkend="CG_3DUnion"/>
         </para>
     </refsection>
 </refentry>
@@ -698,7 +1025,7 @@
 </refsection>
 <refsection>
-    <para><xref linkend="CG_3DDistance"/>, <xref linkend="ST_Distance"/></para>
+    <para><xref linkend="CG_3DDistance"/>, <xref linkend="CG_Distance"/></para>
 </refsection>
 </refentry>
@@ -748,7 +1075,6 @@
 </refsection>
 </refentry>
 <refentry xml:id="ST_3DConvexHull">
     <refnamediv>
         <refname>ST_3DConvexHull</refname>
@@ -768,22 +1094,55 @@
     <refsection>
+        <warning>
+            <para>
+                <xref linkend="ST_3DConvexHull"/> is deprecated as of 3.5.0. Use <xref linkend="CG_3DConvexHull"/> instead.
+            </para>
+        </warning>
         <para role="availability" conformance="3.3.0">Availability: 3.3.0</para>
     </refsection>
+</refentry>
+<refentry xml:id="CG_3DConvexHull">
+    <refnamediv>
+        <refname>CG_3DConvexHull</refname>
+        <refpurpose>Computes the 3D convex hull of a geometry.</refpurpose>
+    </refnamediv>
+    <refsynopsisdiv>
+        <funcsynopsis>
+            <funcprototype>
+                <funcdef>geometry <function>CG_3DConvexHull</function></funcdef>
+            </funcprototype>
+        </funcsynopsis>
+    </refsynopsisdiv>
+    <refsection>
+    </refsection>
     <refsection>
-        <programlisting>SELECT ST_AsText(ST_3DConvexHull('LINESTRING Z(0 0 5, 1 5 3, 5 7 6, 9 5 3 , 5 7 5, 6 3 5)'::geometry));</programlisting>
+        <programlisting>SELECT ST_AsText(CG_3DConvexHull('LINESTRING Z(0 0 5, 1 5 3, 5 7 6, 9 5 3 , 5 7 5, 6 3 5)'::geometry));</programlisting>
         <screen>POLYHEDRALSURFACE Z (((1 5 3,9 5 3,0 0 5,1 5 3)),((1 5 3,0 0 5,5 7 6,1 5 3)),((5 7 6,5 7 5,1 5 3,5 7 6)),((0 0 5,6 3 5,5 7 6,0 0 5)),((6 3 5,9 5 3,5 7 6,6 3 5)),((0 0 5,9 5 3,6 3 5,0 0 5)),((9 5 3,5 7 5,5 7 6,9 5 3)),((1 5 3,5 7 5,9 5 3,1 5 3)))</screen>
-        <programlisting>WITH f AS (SELECT i, ST_Extrude(geom, 0,0, i ) AS geom
+        <programlisting>WITH f AS (SELECT i, CG_Extrude(geom, 0,0, i ) AS geom
         FROM ST_Subdivide(ST_Letters('CH'),5) WITH ORDINALITY AS sd(geom,i)
-        SELECT ST_3DConvexHull(ST_Collect(f.geom) )
+        SELECT CG_3DConvexHull(ST_Collect(f.geom) )
         FROM f;</programlisting>
     <para>
         <informalfigure>
@@ -821,6 +1180,13 @@
         <refsection>
+            <warning>
+                <para>
+                    <xref linkend="ST_3DIntersection"/> is deprecated as of 3.5.0. Use <xref linkend="CG_3DIntersection"/> instead.
+                </para>
+            </warning>
             <para>Return a geometry that is the shared portion between geom1 and geom2.</para>
@@ -829,6 +1195,36 @@
         </refsection>
+    </refentry>
+    <refentry xml:id="CG_3DIntersection">
+        <refnamediv>
+            <refname>CG_3DIntersection</refname>
+            <refpurpose>Perform 3D intersection</refpurpose>
+        </refnamediv>
+        <refsynopsisdiv>
+            <funcsynopsis>
+                <funcprototype>
+                    <funcdef>geometry <function>CG_3DIntersection</function></funcdef>
+                </funcprototype>
+            </funcsynopsis>
+        </refsynopsisdiv>
+        <refsection>
+            <para>Return a geometry that is the shared portion between geom1 and geom2.</para>
+        </refsection>
         <refsection>
@@ -838,9 +1234,9 @@
                     <tbody>
                         <row>
                             <entry><para>
                                 </programlisting>
                                 <informalfigure>
@@ -853,10 +1249,10 @@
                         </entry>
                         <entry><para>
-                                <programlisting>SELECT ST_3DIntersection(geom1,geom2)
+                                <programlisting>SELECT CG_3DIntersection(geom1,geom2)
                             <informalfigure>
                                 <mediaobject>
@@ -873,7 +1269,7 @@
     </informaltable>
     <para>3D linestrings and polygons</para>
-    <programlisting>	SELECT ST_AsText(ST_3DIntersection(linestring, polygon)) As wkt
+    <programlisting>	SELECT ST_AsText(CG_3DIntersection(linestring, polygon)) As wkt
     FROM  ST_GeomFromText('LINESTRING Z (2 2 6,1.5 1.5 7,1 1 8,0.5 0.5 8,0 0 10)') AS linestring
     CROSS JOIN ST_GeomFromText('POLYGON((0 0 8, 0 1 8, 1 1 8, 1 0 8, 0 0 8))') AS polygon;
@@ -883,7 +1279,7 @@
 </programlisting>
 <para>Cube (closed Polyhedral Surface) and Polygon Z</para>
-<programlisting>SELECT ST_AsText(ST_3DIntersection(
+<programlisting>SELECT ST_AsText(CG_3DIntersection(
 ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
 ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)), ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)),
@@ -892,8 +1288,8 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
             <screen>TIN Z (((0 0 0,0 0 0.5,0 0.5 0.5,0 0 0)),((0 0.5 0,0 0 0,0 0.5 0.5,0 0.5 0)))</screen>
             <para>Intersection of 2 solids that result in volumetric intersection is also a solid (ST_Dimension returns 3)</para>
-            <programlisting>SELECT ST_AsText(ST_3DIntersection( ST_Extrude(ST_Buffer('POINT(10 20)'::geometry,10,1),0,0,30),
-            ST_Extrude(ST_Buffer('POINT(10 20)'::geometry,10,1),2,0,10) ));</programlisting>
+            <programlisting>SELECT ST_AsText(CG_3DIntersection( CG_Extrude(ST_Buffer('POINT(10 20)'::geometry,10,1),0,0,30),
+            CG_Extrude(ST_Buffer('POINT(10 20)'::geometry,10,1),2,0,10) ));</programlisting>
         <screen>POLYHEDRALSURFACE Z (((13.3333333333333 13.3333333333333 10,20 20 0,20 20 10,13.3333333333333 13.3333333333333 10)),
         ((20 20 10,16.6666666666667 23.3333333333333 10,13.3333333333333 13.3333333333333 10,20 20 10)),
         ((20 20 0,16.6666666666667 23.3333333333333 10,20 20 10,20 20 0)),
@@ -981,6 +1377,12 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <refsection>
+            <warning>
+                <para>
+                    <xref linkend="ST_3DUnion"/> is deprecated as of 3.5.0. Use <xref linkend="CG_3DUnion"/> instead.
+                </para>
+            </warning>
             <para role="availability" conformance="3.3.0">Availability: 3.3.0 aggregate variant was added</para>
@@ -999,6 +1401,55 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                 functions do and like most aggregates, it also ignores NULL geometries.
             </para>
         </refsection>
+    </refentry>
+    <refentry xml:id="CG_3DUnion">
+        <refnamediv>
+            <refname>CG_3DUnion</refname>
+            <refpurpose>Perform 3D union.</refpurpose>
+        </refnamediv>
+        <refsynopsisdiv>
+            <funcsynopsis>
+                <funcprototype>
+                    <funcdef>geometry <function>CG_3DUnion</function></funcdef>
+                </funcprototype>
+                <funcprototype>
+                    <paramdef><type>geometry set</type> <parameter>g1field</parameter></paramdef>
+                </funcprototype>
+            </funcsynopsis>
+        </refsynopsisdiv>
+        <refsection>
+            <warning>
+                <para>
+                    <xref linkend="CG_3DUnion"/> is deprecated as of 3.5.0. Use <xref linkend="CG_3DUnion"/> instead.
+                </para>
+            </warning>
+            <para>
+                <emphasis role="bold">Aggregate variant:</emphasis>
+                returns a geometry that is the 3D union of a rowset of geometries.
+                The CG_3DUnion() function is an "aggregate"
+                function in the terminology of PostgreSQL. That means that it
+                operates on rows of data, in the same way the SUM() and AVG()
+                functions do and like most aggregates, it also ignores NULL geometries.
+            </para>
+        </refsection>
         <refsection>
@@ -1008,9 +1459,9 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                     <tbody>
                         <row>
                             <entry><para>
                                 </programlisting>
                                 <informalfigure>
@@ -1023,10 +1474,10 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                         </entry>
                         <entry><para>
-                                <programlisting>SELECT ST_3DUnion(geom1,geom2)
+                                <programlisting>SELECT CG_3DUnion(geom1,geom2)
                             <informalfigure>
                                 <mediaobject>
@@ -1048,9 +1499,9 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
     <para>
-        <xref linkend="ST_3DDifference"/>
     </para>
 </refsection>
         </refentry>
@@ -1073,6 +1524,44 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                 </funcsynopsis>
             </refsynopsisdiv>
+            <refsection>
+                <warning>
+                    <para>
+                        <xref linkend="ST_AlphaShape"/> is deprecated as of 3.5.0. Use <xref linkend="CG_AlphaShape"/> instead.
+                    </para>
+                </warning>
+                <para>Computes the
+                <link xlink:href="https://en.wikipedia.org/wiki/Alpha_shape">Alpha-Shape</link>
+                of the points in a geometry.
+                An alpha-shape is a (usually) concave polygonal geometry which contains all the vertices of the input,
+                and whose vertices are a subset of the input vertices.
+                An alpha-shape provides a closer fit to the shape of the input
+                than the shape produced by the <link linkend="ST_ConvexHull">convex hull</link>.
+            </para>
+        </refsection>
+    </refentry>
+        <refentry xml:id="CG_AlphaShape">
+            <refnamediv>
+                <refname>CG_AlphaShape</refname>
+                <refpurpose>Computes an Alpha-shape enclosing a geometry</refpurpose>
+            </refnamediv>
+            <refsynopsisdiv>
+                <funcsynopsis>
+                    <funcprototype>
+                        <funcdef>geometry <function>CG_AlphaShape</function></funcdef>
+                        <paramdef choice="opt"><type>float </type> <parameter>alpha</parameter></paramdef>
+                        <paramdef choice="opt"><type>boolean </type> <parameter>allow_holes = false</parameter></paramdef>
+                    </funcprototype>
+                </funcsynopsis>
+            </refsynopsisdiv>
             <refsection>
@@ -1109,7 +1598,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
             but uses CGAL and a different algorithm.
         </para>
-        <para role="availability" conformance="3.3.0">Availability: 3.3.0 - requires SFCGAL >= 1.4.1.</para>
+        <para role="availability" conformance="3.5.0">Availability: 3.5.0 - requires SFCGAL >= 1.4.1.</para>
     </refsection>
@@ -1121,10 +1610,10 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                     <imageobject>
                         <imagedata fileref="images/st_alphashape01.png"/>
                     </imageobject>
-                    <caption><para>Alpha-shape of a MultiPoint (same example As <xref linkend="ST_OptimalAlphaShape"/>)</para></caption>
+                    <caption><para>Alpha-shape of a MultiPoint (same example As <xref linkend="CG_OptimalAlphaShape"/>)</para></caption>
                 </mediaobject>
             </informalfigure>
-            <programlisting>SELECT ST_AsText(ST_AlphaShape('MULTIPOINT((63 84),(76 88),(68 73),(53 18),(91 50),(81 70),
+            <programlisting>SELECT ST_AsText(CG_AlphaShape('MULTIPOINT((63 84),(76 88),(68 73),(53 18),(91 50),(81 70),
             (88 29),(24 82),(32 51),(37 23),(27 54),(84 19),(75 87),(44 42),(77 67),(90 30),(36 61),(32 65),
             (81 47),(88 58),(68 73),(49 95),(81 60),(87 50),
             (78 16),(79 21),(30 22),(78 43),(26 85),(48 34),(35 35),(36 40),(31 79),(83 29),(27 84),(52 98),(72 95),(85 71),
@@ -1142,10 +1631,10 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
             <imageobject>
                 <imagedata fileref="images/st_alphashape02.png"/>
             </imageobject>
-            <caption><para>Alpha-shape of a MultiPoint, allowing holes (same example as <xref linkend="ST_OptimalAlphaShape"/>)</para></caption>
+            <caption><para>Alpha-shape of a MultiPoint, allowing holes (same example as <xref linkend="CG_OptimalAlphaShape"/>)</para></caption>
         </mediaobject>
     </informalfigure>
-    <programlisting>SELECT ST_AsText(ST_AlphaShape('MULTIPOINT((63 84),(76 88),(68 73),(53 18),(91 50),(81 70),(88 29),(24 82),(32 51),(37 23),(27 54),(84 19),(75 87),(44 42),(77 67),(90 30),(36 61),(32 65),(81 47),(88 58),(68 73),(49 95),(81 60),(87 50),
+    <programlisting>SELECT ST_AsText(CG_AlphaShape('MULTIPOINT((63 84),(76 88),(68 73),(53 18),(91 50),(81 70),(88 29),(24 82),(32 51),(37 23),(27 54),(84 19),(75 87),(44 42),(77 67),(90 30),(36 61),(32 65),(81 47),(88 58),(68 73),(49 95),(81 60),(87 50),
     (75 84),(75 77),(81 29),(77 73),(41 42),(83 72),(23 36),(89 53),(27 57),(57 97),(27 77),(39 88),(60 81),
     (80 72),(54 32),(55 26),(62 22),(70 20),(76 27),(84 35),(87 42),(82 54),(83 64),(69 86),(60 90),(50 86),(43 80),(36 73),
@@ -1165,7 +1654,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                         <caption><para>Alpha-shape of a MultiPoint, allowing holes (same example as <xref linkend="ST_ConcaveHull"/>)</para></caption>
                     </mediaobject>
                 </informalfigure>
                 'MULTIPOINT ((132 64), (114 64), (99 64), (81 64), (63 64), (57 49), (52 36), (46 20), (37 20), (26 20), (32 36), (39 55), (43 69), (50 84), (57 100), (63 118), (68 133), (74 149), (81 164), (88 180), (101 180), (112 180), (119 164), (126 149), (132 131), (139 113), (143 100), (150 84), (157 69), (163 51), (168 36), (174 20), (163 20), (150 20), (143 36), (139 49), (132 64), (99 151), (92 138), (88 124), (81 109), (74 93), (70 82), (83 82), (99 82), (112 82), (126 82), (121 96), (114 109), (110 122), (103 138), (99 151), (34 27), (43 31), (48 44), (46 58), (52 73), (63 73), (61 84), (72 71), (90 69), (101 76), (123 71), (141 62), (166 27), (150 33), (159 36), (146 44), (154 53), (152 62), (146 73), (134 76), (143 82), (141 91), (130 98), (126 104), (132 113), (128 127), (117 122), (112 133), (119 144), (108 147), (119 153), (110 171), (103 164), (92 171), (86 160), (88 142), (79 140), (72 124), (83 131), (79 118), (68 113), (63 102), (68 93), (35 45))'::geometry,102.
 2, true));</programlisting>
             <screen>POLYGON((26 20,32 36,35 45,39 55,43 69,50 84,57 100,63 118,68 133,74 149,81 164,88 180,
             101 180,112 180,119 164,126 149,132 131,139 113,143 100,150 84,157 69,163 51,168 36,
@@ -1175,7 +1664,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
 </refsection>
 <refsection>
-    <para><xref linkend="ST_ConcaveHull"/>, <xref linkend="ST_OptimalAlphaShape"/></para>
+    <para><xref linkend="ST_ConcaveHull"/>, <xref linkend="CG_OptimalAlphaShape"/></para>
 </refsection>
         </refentry>
@@ -1254,6 +1743,12 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <refsection>
+            <warning>
+                <para>
+                    <xref linkend="ST_ApproximateMedialAxis"/> is deprecated as of 3.5.0. Use <xref linkend="CG_ApproximateMedialAxis"/> instead.
+                </para>
+            </warning>
             <para>
                 Return an approximate medial axis for the areal input based on
                 its straight skeleton. Uses an SFCGAL specific API when built against
@@ -1267,9 +1762,43 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         </refsection>
+    </refentry>
+    <refentry xml:id="CG_ApproximateMedialAxis">
+        <refnamediv>
+            <refname>CG_ApproximateMedialAxis</refname>
+            <refpurpose>Compute the approximate medial axis of an areal geometry.</refpurpose>
+        </refnamediv>
+        <refsynopsisdiv>
+            <funcsynopsis>
+                <funcprototype>
+                    <funcdef>geometry <function>CG_ApproximateMedialAxis</function></funcdef>
+                </funcprototype>
+            </funcsynopsis>
+        </refsynopsisdiv>
+        <refsection>
+            <para>
+                Return an approximate medial axis for the areal input based on
+                its straight skeleton. Uses an SFCGAL specific API when built against
+                a capable version (1.2.0+). Otherwise the function is just a wrapper
+                around CG_StraightSkeleton (slower case).
+            </para>
+        </refsection>
-            <programlisting>SELECT ST_ApproximateMedialAxis(ST_GeomFromText('POLYGON (( 190 190, 10 190, 10 10, 190 10, 190 20, 160 30, 60 30, 60 130, 190 140, 190 190 ))'));</programlisting>
+            <programlisting>SELECT CG_ApproximateMedialAxis(ST_GeomFromText('POLYGON (( 190 190, 10 190, 10 10, 190 10, 190 20, 160 30, 60 30, 60 130, 190 140, 190 190 ))'));</programlisting>
             <informaltable>
                 <tgroup cols="1">
@@ -1319,6 +1848,50 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <refsection>
+            <warning>
+                <para>
+                    <xref linkend="ST_ConstrainedDelaunayTriangles"/> is deprecated as of 3.5.0. Use <xref linkend="CG_ConstrainedDelaunayTriangles"/> instead.
+                </para>
+            </warning>
+            <para>
+                Return a <link xlink:href="https://en.wikipedia.org/wiki/Constrained_Delaunay_triangulation">Constrained Delaunay
+                triangulation</link> around the vertices of the input geometry.
+                Output is a TIN.
+            </para>
+            <para role="availability" conformance="3.0.0">Availability: 3.0.0</para>
+        </refsection>
+    </refentry>
+    <refentry xml:id="CG_ConstrainedDelaunayTriangles">
+        <refnamediv>
+            <refname>CG_ConstrainedDelaunayTriangles</refname>
+            <refpurpose>
+                Return a constrained Delaunay triangulation around the given input geometry.
+            </refpurpose>
+        </refnamediv>
+        <refsynopsisdiv>
+            <funcsynopsis>
+                <funcprototype>
+                    <funcdef>geometry <function>CG_ConstrainedDelaunayTriangles</function></funcdef>
+                    <paramdef><type>geometry </type> <parameter>g1</parameter></paramdef>
+                </funcprototype>
+            </funcsynopsis>
+        </refsynopsisdiv>
+        <refsection>
+            <warning>
+                <para>
+                    <xref linkend="CG_ConstrainedDelaunayTriangles"/> is deprecated as of 3.5.0. Use <xref linkend="CG_ConstrainedDelaunayTriangles"/> instead.
+                </para>
+            </warning>
             <para>
@@ -1339,11 +1912,11 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                                             <imageobject>
                                                 <imagedata fileref="images/st_constraineddelaunaytriangles01.png"/>
                                             </imageobject>
-                                            <caption><para>ST_ConstrainedDelaunayTriangles of 2 polygons</para></caption>
+                                            <caption><para>CG_ConstrainedDelaunayTriangles of 2 polygons</para></caption>
                                         </mediaobject>
                                     </informalfigure>
                                     <programlisting>
-                                        select ST_ConstrainedDelaunayTriangles(
+                                        select CG_ConstrainedDelaunayTriangles(
                                         ST_Union(
                                         'POLYGON((175 150, 20 40, 50 60, 125 100, 175 150))'::geometry,
                                         ST_Buffer('POINT(110 170)'::geometry, 20)
@@ -1378,7 +1951,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
             <para>
                 <xref linkend="ST_DelaunayTriangles"/>,
                 <xref linkend="ST_TriangulatePolygon"/>,
-                <xref linkend="ST_Tesselate"/>,
+                <xref linkend="CG_Tesselate"/>,
                 <xref linkend="ST_Dump"/>
             </para>
@@ -1407,12 +1980,48 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <refsection>
+            <warning>
+                <para>
+                    <xref linkend="ST_Extrude"/> is deprecated as of 3.5.0. Use <xref linkend="CG_Extrude"/> instead.
+                </para>
+            </warning>
         </refsection>
+    </refentry>
+    <refentry xml:id="CG_Extrude">
+        <refnamediv>
+            <refname>CG_Extrude</refname>
+            <refpurpose>Extrude a surface to a related volume</refpurpose>
+        </refnamediv>
+        <refsynopsisdiv>
+            <funcsynopsis>
+                <funcprototype>
+                    <funcdef>geometry <function>CG_Extrude</function></funcdef>
+                    <paramdef><type>float</type> <parameter>x</parameter></paramdef>
+                    <paramdef><type>float</type> <parameter>y</parameter></paramdef>
+                    <paramdef><type>float</type> <parameter>z</parameter></paramdef>
+                </funcprototype>
+            </funcsynopsis>
+        </refsynopsisdiv>
+        <refsection>
+        </refsection>
@@ -1434,7 +2043,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                         </entry>
                         <entry><para>
-                                <programlisting>ST_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
+                                <programlisting>CG_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
                                 50, 'quad_segs=2'),0,0,30);</programlisting>
                             <informalfigure>
                                 <mediaobject>
@@ -1460,7 +2069,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                     </entry>
                     <entry><para>
                             ST_GeomFromText('LINESTRING(50 50, 100 90, 95 150)'),0,0,10));</programlisting>
                         <informalfigure>
                             <mediaobject>
@@ -1508,7 +2117,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
             <note><para>
                     Perhaps the first (historically) use-case of straight skeletons: given a polygonal roof, the straight skeleton directly gives the layout of each tent. If each skeleton edge is lifted from the plane a height equal to its offset distance, the resulting roof is "correct" in that water will always fall down to the contour edges (the roof's border), regardless of where it falls on the roof.
-                    The function computes this extrusion aka "roof" on a polygon. If the argument body_height > 0, so the polygon is extruded like with ST_Extrude(polygon, 0, 0, body_height). The result is an union of these polyhedralsurfaces.
+                    The function computes this extrusion aka "roof" on a polygon. If the argument body_height > 0, so the polygon is extruded like with CG_Extrude(polygon, 0, 0, body_height). The result is an union of these polyhedralsurfaces.
             </para></note>
@@ -1586,7 +2195,6 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
 </refentry>
 <refentry xml:id="ST_MinkowskiSum">
     <refnamediv>
         <refname>ST_MinkowskiSum</refname>
@@ -1607,6 +2215,12 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
     <refsection>
+        <warning>
+            <para>
+                <xref linkend="ST_MinkowskiSum"/> is deprecated as of 3.5.0. Use <xref linkend="CG_MinkowskiSum"/> instead.
+            </para>
+        </warning>
         <para>This function performs a 2D minkowski sum of a point, line or polygon with a polygon.</para>
         <para>A minkowski sum of two geometries A and B is the set of all points that are the sum of any point in A and B. Minkowski sums are often used in motion planning and computer-aided design. More details on <link xlink:href="https://en.wikipedia.org/wiki/Minkowski_addition">Wikipedia Minkowski addition</link>.</para>
         <para>The first parameter can be any 2D geometry (point, linestring, polygon). If a 3D geometry is passed, it will be converted to 2D by forcing Z to 0, leading to possible cases of invalidity. The second parameter must be a 2D polygon.</para>
@@ -1617,6 +2231,38 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
     </refsection>
+</refentry>
+<refentry xml:id="CG_MinkowskiSum">
+    <refnamediv>
+        <refname>CG_MinkowskiSum</refname>
+        <refpurpose>Performs Minkowski sum</refpurpose>
+    </refnamediv>
+    <refsynopsisdiv>
+        <funcsynopsis>
+            <funcprototype>
+                <funcdef>geometry <function>CG_MinkowskiSum</function></funcdef>
+            </funcprototype>
+        </funcsynopsis>
+    </refsynopsisdiv>
+    <refsection>
+        <para>This function performs a 2D minkowski sum of a point, line or polygon with a polygon.</para>
+        <para>A minkowski sum of two geometries A and B is the set of all points that are the sum of any point in A and B. Minkowski sums are often used in motion planning and computer-aided design. More details on <link xlink:href="https://en.wikipedia.org/wiki/Minkowski_addition">Wikipedia Minkowski addition</link>.</para>
+        <para>The first parameter can be any 2D geometry (point, linestring, polygon). If a 3D geometry is passed, it will be converted to 2D by forcing Z to 0, leading to possible cases of invalidity. The second parameter must be a 2D polygon.</para>
+        <para>Implementation utilizes <link xlink:href="http://doc.cgal.org/latest/Minkowski_sum_2/">CGAL 2D Minkowskisum</link>.</para>
+    </refsection>
         <para>Minkowski Sum of Linestring and circle polygon where Linestring cuts thru the circle</para>
@@ -1653,7 +2299,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
             </tgroup>
         </informaltable>
         <programlisting>
-            SELECT ST_MinkowskiSum(line, circle))
+            SELECT CG_MinkowskiSum(line, circle))
             FROM (SELECT
             ST_MakeLine(ST_Point(10, 10),ST_Point(100, 100)) As line,
             ST_Buffer(ST_GeomFromText('POINT(50 50)'), 30) As circle) As foo;
@@ -1696,7 +2342,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                 </tbody>
             </tgroup>
         </informaltable>
-        <programlisting>SELECT ST_MinkowskiSum(mp, poly)
+        <programlisting>SELECT CG_MinkowskiSum(mp, poly)
         FROM (SELECT 'MULTIPOINT(25 50,70 25)'::geometry As mp,
         'POLYGON((130 150, 20 40, 50 60, 125 100, 130 150))'::geometry As poly
         ) As foo
@@ -1733,6 +2379,12 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
             <refsection>
+                <warning>
+                    <para>
+                        <xref linkend="ST_OptimalAlphaShape"/> is deprecated as of 3.5.0. Use <xref linkend="CG_OptimalAlphaShape"/> instead.
+                    </para>
+                </warning>
                 <para>Computes the "optimal" alpha-shape of the points in a geometry.
                 The alpha-shape is computed using a value of α chosen so that:
             </para>
@@ -1752,6 +2404,48 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         </refsection>
+        </refentry>
+        <refentry xml:id="CG_OptimalAlphaShape">
+            <refnamediv>
+                <refname>CG_OptimalAlphaShape</refname>
+                <refpurpose>Computes an Alpha-shape enclosing a geometry using an "optimal" alpha value.</refpurpose>
+            </refnamediv>
+            <refsynopsisdiv>
+                <funcsynopsis>
+                    <funcprototype>
+                        <funcdef>geometry <function>CG_OptimalAlphaShape</function></funcdef>
+                        <paramdef choice="opt"><type>integer </type> <parameter>nb_components = 1</parameter></paramdef>
+                    </funcprototype>
+                </funcsynopsis>
+            </refsynopsisdiv>
+            <refsection>
+                <para>Computes the "optimal" alpha-shape of the points in a geometry.
+                The alpha-shape is computed using a value of α chosen so that:
+            </para>
+            <orderedlist>
+                <listitem>
+                    <para>the number of polygon elements is equal to or smaller than <varname>nb_components</varname>
+                        (which defaults to 1)</para>
+                </listitem>
+                <listitem>
+                    <para>all input points are contained in the shape</para>
+                </listitem>
+            </orderedlist>
+            <para>
+                The result will not contain holes unless the optional <varname>allow_holes</varname> argument is specified as true.
+            </para>
+        </refsection>
         <refsection>
@@ -1761,10 +2455,10 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                         <imageobject>
                             <imagedata fileref="images/st_optimalalphashape01.png"/>
                         </imageobject>
-                        <caption><para>Optimal alpha-shape of a MultiPoint (same example as <xref linkend="ST_AlphaShape"/>)</para></caption>
+                        <caption><para>Optimal alpha-shape of a MultiPoint (same example as <xref linkend="CG_AlphaShape"/>)</para></caption>
                     </mediaobject>
                 </informalfigure>
-                <programlisting>SELECT ST_AsText(ST_OptimalAlphaShape('MULTIPOINT((63 84),(76 88),(68 73),(53 18),(91 50),(81 70),
+                <programlisting>SELECT ST_AsText(CG_OptimalAlphaShape('MULTIPOINT((63 84),(76 88),(68 73),(53 18),(91 50),(81 70),
@@ -1781,10 +2475,10 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                 <imageobject>
                     <imagedata fileref="images/st_optimalalphashape02.png"/>
                 </imageobject>
-                <caption><para>Optimal alpha-shape of a MultiPoint, allowing holes (same example as <xref linkend="ST_AlphaShape"/>)</para></caption>
+                <caption><para>Optimal alpha-shape of a MultiPoint, allowing holes (same example as <xref linkend="CG_AlphaShape"/>)</para></caption>
             </mediaobject>
         </informalfigure>
-        <programlisting>SELECT ST_AsText(ST_OptimalAlphaShape('MULTIPOINT((63 84),(76 88),(68 73),(53 18),(91 50),(81 70),(88 29),(24 82),(32 51),(37 23),(27 54),(84 19),(75 87),(44 42),(77 67),(90 30),(36 61),(32 65),(81 47),(88 58),(68 73),(49 95),(81 60),(87 50),
+        <programlisting>SELECT ST_AsText(CG_OptimalAlphaShape('MULTIPOINT((63 84),(76 88),(68 73),(53 18),(91 50),(81 70),(88 29),(24 82),(32 51),(37 23),(27 54),(84 19),(75 87),(44 42),(77 67),(90 30),(36 61),(32 65),(81 47),(88 58),(68 73),(49 95),(81 60),(87 50),
@@ -1795,7 +2489,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
             </refsection>
             <refsection>
-                <para><xref linkend="ST_ConcaveHull"/>, <xref linkend="ST_AlphaShape"/></para>
+                <para><xref linkend="ST_ConcaveHull"/>, <xref linkend="CG_AlphaShape"/></para>
             </refsection>
         </refentry>
@@ -1940,6 +2634,12 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <refsection>
+            <warning>
+                <para>
+                    <xref linkend="ST_StraightSkeleton"/> is deprecated as of 3.5.0. Use <xref linkend="CG_StraightSkeleton"/> instead.
+                </para>
+            </warning>
@@ -1984,7 +2684,6 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         </refsection>
     </refentry>
     <refentry xml:id="ST_Tesselate">
         <refnamediv>
             <refname>ST_Tesselate</refname>
@@ -2003,6 +2702,13 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <refsection>
+            <warning>
+                <para>
+                    <xref linkend="ST_Tesselate"/> is deprecated as of 3.5.0. Use <xref linkend="CG_Tesselate"/> instead.
+                </para>
+            </warning>
             <para>Takes as input a surface such a  MULTI(POLYGON) or POLYHEDRALSURFACE and returns a TIN representation via the process of tessellation using triangles.</para>
             <note><para><xref linkend="ST_TriangulatePolygon" /> does similar to this function except that it returns a geometry collection of polygons instead of a TIN and also only works with 2D geometries.</para></note>
@@ -2011,6 +2717,35 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         </refsection>
+    </refentry>
+    <refentry xml:id="CG_Tesselate">
+        <refnamediv>
+            <refname>CG_Tesselate</refname>
+            <refpurpose>Perform surface Tesselation of a polygon or polyhedralsurface and returns as a TIN or collection of TINS</refpurpose>
+        </refnamediv>
+        <refsynopsisdiv>
+            <funcsynopsis>
+                <funcprototype>
+                    <funcdef>geometry <function>CG_Tesselate</function></funcdef>
+                </funcprototype>
+            </funcsynopsis>
+        </refsynopsisdiv>
+        <refsection>
+            <para>Takes as input a surface such a  MULTI(POLYGON) or POLYHEDRALSURFACE and returns a TIN representation via the process of tessellation using triangles.</para>
+            <note><para><xref linkend="ST_TriangulatePolygon" /> does similar to this function except that it returns a geometry collection of polygons instead of a TIN and also only works with 2D geometries.</para></note>
+        </refsection>
             <informaltable>
@@ -2032,7 +2767,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                         </entry>
                         <entry><para>
-                                <programlisting>SELECT ST_Tesselate(ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
+                                <programlisting>SELECT CG_Tesselate(ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                                 ((0 1 0, 0 1 1, 1 1 1, 1 1 0, 0 1 0)), ((0 0 1, 1 0 1, 1 1 1, 0 1 1, 0 0 1)) )'));</programlisting></para>
@@ -2069,7 +2804,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                 </entry>
                 <entry><para>
-                        ST_Tesselate('POLYGON (( 10 190, 10 70, 80 70, 80 130, 50 160, 120 160, 120 190, 10 190 ))'::geometry);</programlisting>
+                        CG_Tesselate('POLYGON (( 10 190, 10 70, 80 70, 80 130, 50 160, 120 160, 120 190, 10 190 ))'::geometry);</programlisting>
                 </para>
                 <para>ST_AsText output</para>
                 <screen>TIN(((80 130,50 160,80 70,80 130)),((50 160,10 190,10 70,50 160)),
@@ -2093,7 +2828,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
             <refsection>
-                <para><xref linkend="ST_ConstrainedDelaunayTriangles"/>, <xref linkend="ST_DelaunayTriangles"/>, <xref linkend="ST_TriangulatePolygon"/></para>
+                <para><xref linkend="CG_ConstrainedDelaunayTriangles"/>, <xref linkend="ST_DelaunayTriangles"/>, <xref linkend="ST_TriangulatePolygon"/></para>
             </refsection>
@@ -2136,7 +2871,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         </refsection>
         <refsection>
         </refsection>
     </refentry>
commit 3b2562143b2fc1a059cd884b9d62c6bb3454ac0a
Date:   Tue Mar 12 18:14:03 2024 +0100
    SFCGAL: Standardize function name
    Use c-style name for function instead of SQL-like
diff --git a/sfcgal/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
index 3220e28a6..3575a1aec 100644
--- a/sfcgal/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -127,7 +127,7 @@ Datum sfcgal_approximate_medial_axis(PG_FUNCTION_ARGS);
 Datum sfcgal_is_planar(PG_FUNCTION_ARGS);
 Datum sfcgal_orientation(PG_FUNCTION_ARGS);
 Datum sfcgal_force_lhr(PG_FUNCTION_ARGS);
-Datum ST_ConstrainedDelaunayTriangles(PG_FUNCTION_ARGS);
+Datum sfcgal_constrained_delaunay_triangles(PG_FUNCTION_ARGS);
 Datum sfcgal_triangulate(PG_FUNCTION_ARGS);
 Datum sfcgal_tesselate(PG_FUNCTION_ARGS);
 Datum sfcgal_minkowski_sum(PG_FUNCTION_ARGS);
@@ -365,9 +365,9 @@ sfcgal_tesselate(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(output);
-PG_FUNCTION_INFO_V1(ST_ConstrainedDelaunayTriangles);
+PG_FUNCTION_INFO_V1(sfcgal_constrained_delaunay_triangles);
 Datum
-ST_ConstrainedDelaunayTriangles(PG_FUNCTION_ARGS)
+sfcgal_constrained_delaunay_triangles(PG_FUNCTION_ARGS)
 	GSERIALIZED *input, *output;
 	sfcgal_geometry_t *geom;
commit 4195f89fab5e7582c4a93c41de274d0d92a69d6f
Date:   Tue Mar 12 18:12:36 2024 +0100
    SFCGAL: Rename functions with CG_ prefix
    Rename all fucntions with CG_ prefix and deprecate all the old ones
diff --git a/sfcgal/sfcgal.sql.in b/sfcgal/sfcgal.sql.in
index de614c8ba..255794f81 100644
--- a/sfcgal/sfcgal.sql.in
+++ b/sfcgal/sfcgal.sql.in
@@ -45,13 +45,23 @@ CREATE OR REPLACE FUNCTION postgis_sfcgal_noop(geometry)
         LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
         COST 1;
--- Availability: 2.1.0
-CREATE OR REPLACE FUNCTION ST_3DIntersection(geom1 geometry, geom2 geometry)
+-- Availability: 3.5.0
+CREATE OR REPLACE FUNCTION CG_3DIntersection(geom1 geometry, geom2 geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_intersection3D'
        COST 100;
+-- Availability: 2.1.0
+-- Deprecation in 3.5.0
+CREATE OR REPLACE FUNCTION ST_3DIntersection(geometry, geometry)
+RETURNS geometry AS $$
+	SELECT @extschema at ._postgis_deprecate(
+		'ST_3DIntersection', 'CG_3DIntersection', '3.5.0');
+	SELECT @extschema at .CG_3DIntersection($1, $2);
+LANGUAGE 'sql' IMMUTABLE SECURITY INVOKER;
 CREATE OR REPLACE FUNCTION CG_Intersection(geom1 geometry, geom2 geometry)
        RETURNS geometry
@@ -73,14 +83,24 @@ CREATE OR REPLACE FUNCTION CG_Intersects(geom1 geometry, geom2 geometry)
        COST 100;
--- Availability: 2.2
-CREATE OR REPLACE FUNCTION ST_3DDifference(geom1 geometry, geom2 geometry)
+CREATE OR REPLACE FUNCTION CG_3DDifference(geom1 geometry, geom2 geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_difference3D'
        COST 100;
+-- Availability: 2.2
+CREATE OR REPLACE FUNCTION ST_3DDifference(geometry, geometry)
+		'ST_3DDifference', 'CG_3DDifference', '3.5.0');
+	SELECT @extschema at .CG_3DDifference($1, $2);
 CREATE OR REPLACE FUNCTION CG_Difference(geom1 geometry, geom2 geometry)
        RETURNS geometry
@@ -88,20 +108,38 @@ CREATE OR REPLACE FUNCTION CG_Difference(geom1 geometry, geom2 geometry)
        COST 100;
-CREATE OR REPLACE FUNCTION ST_3DUnion(geom1 geometry, geom2 geometry)
+CREATE OR REPLACE FUNCTION CG_3DUnion(geom1 geometry, geom2 geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_union3D'
        COST 100;
--- Availability: 3.3.0
-CREATE AGGREGATE ST_3DUnion(geometry) (
-       sfunc = ST_3DUnion,
+CREATE AGGREGATE CG_3DUnion(geometry) (
+       sfunc = CG_3DUnion,
        stype = geometry,
        parallel = safe
+-- Availability: 3.3.0
+CREATE AGGREGATE ST_3DUnion(geometry) (
+       stype = geometry,
+       parallel = safe
+CREATE OR REPLACE FUNCTION ST_3DUnion(geometry, geometry)
+		'ST_3DUnion', 'CG_3DUnion', '3.5.0');
+	SELECT @extschema at .CG_3DUnion($1, $2);
 CREATE OR REPLACE FUNCTION CG_Union(geom1 geometry, geom2 geometry)
        RETURNS geometry
@@ -116,13 +154,23 @@ CREATE AGGREGATE CG_Union(geometry) (
        parallel = safe
-CREATE OR REPLACE FUNCTION ST_Tesselate(geometry)
+CREATE OR REPLACE FUNCTION CG_Tesselate(geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_tesselate'
        COST 100;
+CREATE OR REPLACE FUNCTION ST_Tesselate(geometry)
+		'ST_Tesselate', 'CG_Tesselate', '3.5.0');
+	SELECT @extschema at .CG_Tesselate($1);
 CREATE OR REPLACE FUNCTION CG_Triangulate(geometry)
        RETURNS geometry
@@ -130,13 +178,23 @@ CREATE OR REPLACE FUNCTION CG_Triangulate(geometry)
        COST 100;
-CREATE OR REPLACE FUNCTION ST_3DArea(geometry)
+CREATE OR REPLACE FUNCTION CG_3DArea(geometry)
        RETURNS FLOAT8
        AS 'MODULE_PATHNAME','sfcgal_area3D'
        COST 100;
+CREATE OR REPLACE FUNCTION ST_3DArea(geometry)
+RETURNS FLOAT8 AS $$
+		'ST_3DArea', 'CG_3DArea', '3.5.0');
+	SELECT @extschema at .CG_3DArea($1);
 CREATE OR REPLACE FUNCTION CG_Area(geom1 geometry)
        RETURNS FLOAT8
@@ -158,34 +216,74 @@ CREATE OR REPLACE FUNCTION CG_Distance(geometry, geometry)
        COST 100;
-CREATE OR REPLACE FUNCTION ST_Extrude(geometry, float8, float8, float8)
+CREATE OR REPLACE FUNCTION CG_Extrude(geometry, float8, float8, float8)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_extrude'
        COST 100;
-CREATE OR REPLACE FUNCTION ST_ForceLHR(geometry)
+CREATE OR REPLACE FUNCTION ST_Extrude(geometry, float8, float8, float8)
+		'ST_Extrude', 'CG_Extrude', '3.5.0');
+	SELECT @extschema at .CG_Extrude($1, $2, $3, $4);
+CREATE OR REPLACE FUNCTION CG_ForceLHR(geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_force_lhr'
        COST 100;
-CREATE OR REPLACE FUNCTION ST_Orientation(geometry)
+CREATE OR REPLACE FUNCTION ST_ForceLHR(geometry)
+		'ST_ForceLHR', 'CG_ForceLHR', '3.5.0');
+	SELECT @extschema at .CG_ForceLHR($1);
+CREATE OR REPLACE FUNCTION CG_Orientation(geometry)
        RETURNS INT4
        AS 'MODULE_PATHNAME','sfcgal_orientation'
        COST 100;
-CREATE OR REPLACE FUNCTION ST_MinkowskiSum(geometry, geometry)
+CREATE OR REPLACE FUNCTION ST_Orientation(geometry)
+RETURNS INT4 AS $$
+		'ST_Orientation', 'CG_Orientation', '3.5.0');
+	SELECT @extschema at .CG_Orientation($1);
+CREATE OR REPLACE FUNCTION CG_MinkowskiSum(geometry, geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_minkowski_sum'
        COST 100;
+CREATE OR REPLACE FUNCTION ST_MinkowskiSum(geometry, geometry)
+		'ST_MinkowskiSum', 'CG_MinkowsikSum', '3.5.0');
+	SELECT @extschema at .CG_MinkowskiSum($1, $2);
 CREATE OR REPLACE FUNCTION CG_StraightSkeleton(geometry, use_m_as_distance boolean DEFAULT false)
        RETURNS geometry
@@ -203,8 +301,8 @@ RETURNS geometry AS $$
--- Availability: 2.2.0
-CREATE OR REPLACE FUNCTION ST_ApproximateMedialAxis(geometry)
+CREATE OR REPLACE FUNCTION CG_ApproximateMedialAxis(geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_approximate_medial_axis'
        LANGUAGE 'c'
@@ -212,61 +310,151 @@ CREATE OR REPLACE FUNCTION ST_ApproximateMedialAxis(geometry)
        COST 100;
-CREATE OR REPLACE FUNCTION ST_IsPlanar(geometry)
+CREATE OR REPLACE FUNCTION ST_ApproximateMedialAxis(geometry)
+		'ST_ApproximateMedialAxis', 'CG_ApproximateMedialAxis', '3.5.0');
+	SELECT @extschema at .CG_ApproximateMedialAxis($1);
+CREATE OR REPLACE FUNCTION CG_IsPlanar(geometry)
        RETURNS boolean
        AS 'MODULE_PATHNAME','sfcgal_is_planar'
        COST 100;
-CREATE OR REPLACE FUNCTION ST_Volume(geometry)
+-- Availability: 2.2.0
+CREATE OR REPLACE FUNCTION ST_IsPlanar(geometry)
+RETURNS boolean AS $$
+		'ST_IsPlanar', 'CG_IsPlanar', '3.5.0');
+	SELECT @extschema at .CG_IsPlanar($1);
+CREATE OR REPLACE FUNCTION CG_Volume(geometry)
        RETURNS FLOAT8
        AS 'MODULE_PATHNAME','sfcgal_volume'
        COST 100;
-CREATE OR REPLACE FUNCTION ST_MakeSolid(geometry)
+CREATE OR REPLACE FUNCTION ST_Volume(geometry)
+		'ST_Volume', 'CG_Volume', '3.5.0');
+	SELECT @extschema at .CG_Volume($1);
+CREATE OR REPLACE FUNCTION CG_MakeSolid(geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME','sfcgal_make_solid'
        COST 100;
-CREATE OR REPLACE FUNCTION ST_IsSolid(geometry)
+CREATE OR REPLACE FUNCTION ST_MakeSolid(geometry)
+		'ST_MakeSolid', 'CG_MakeSolid', '3.5.0');
+	SELECT @extschema at .CG_MakeSolid($1);
+CREATE OR REPLACE FUNCTION CG_IsSolid(geometry)
        RETURNS boolean
        AS 'MODULE_PATHNAME','sfcgal_is_solid'
        COST 100;
--- Availability: 3.0.0
-CREATE OR REPLACE FUNCTION ST_ConstrainedDelaunayTriangles(geometry)
+CREATE OR REPLACE FUNCTION ST_IsSolid(geometry)
+		'ST_IsSolid', 'CG_IsSolid', '3.5.0');
+	SELECT @extschema at .CG_IsSolid($1);
+CREATE OR REPLACE FUNCTION CG_ConstrainedDelaunayTriangles(geometry)
        RETURNS geometry
-       AS 'MODULE_PATHNAME', 'ST_ConstrainedDelaunayTriangles'
+       AS 'MODULE_PATHNAME', 'sfcgal_constrained_delaunay_triangles'
        COST 100;
-CREATE OR REPLACE FUNCTION ST_3DConvexHull(geometry)
+-- Availability: 3.0.0
+CREATE OR REPLACE FUNCTION ST_ConstrainedDelaunayTriangles(geometry)
+		'ST_ConstrainedDelaunayTriangles', 'CG_ConstrainedDelaunayTriangles', '3.5.0');
+	SELECT @extschema at .CG_ConstrainedDelaunayTriangles($1);
+CREATE OR REPLACE FUNCTION CG_3DConvexHull(geometry)
        RETURNS geometry
        AS 'MODULE_PATHNAME', 'sfcgal_convexhull3D'
        COST 100;
-CREATE OR REPLACE FUNCTION ST_AlphaShape(g1 geometry, alpha float8 DEFAULT 1.0, allow_holes boolean DEFAULT false)
+CREATE OR REPLACE FUNCTION ST_3DConvexHull(geometry)
+		'ST_3DConvexHull', 'CG_3DConvexHull', '3.5.0');
+	SELECT @extschema at .CG_3DConvexHull($1);
+CREATE OR REPLACE FUNCTION CG_AlphaShape(g1 geometry, alpha float8 DEFAULT 1.0, allow_holes boolean DEFAULT false)
        RETURNS geometry
        AS 'MODULE_PATHNAME', 'sfcgal_alphashape'
        COST 100;
-CREATE OR REPLACE FUNCTION ST_OptimalAlphaShape(g1 geometry, allow_holes boolean DEFAULT false, nb_components int DEFAULT 1)
+CREATE OR REPLACE FUNCTION ST_AlphaShape(g1 geometry, alpha float8 DEFAULT 1.0, allow_holes boolean DEFAULT false)
+		'ST_AlphaShape', 'CG_AlphaShape', '3.5.0');
+	SELECT @extschema at .CG_AlphaShape($1, $2, $3);
+CREATE OR REPLACE FUNCTION CG_OptimalAlphaShape(g1 geometry, allow_holes boolean DEFAULT false, nb_components int DEFAULT 1)
        RETURNS geometry
        AS 'MODULE_PATHNAME', 'sfcgal_optimalalphashape'
        COST 100;
+CREATE OR REPLACE FUNCTION ST_OptimalAlphaShape(g1 geometry, allow_holes boolean DEFAULT false, nb_components int DEFAULT 1)
+		'ST_OptimalAlphaShape', 'CG_OptimalAlphaShape', '3.5.0');
+	SELECT @extschema at .CG_OptimalAlphaShape($1, $2, $3);
 CREATE OR REPLACE FUNCTION CG_YMonotonePartition(g1 geometry)
        RETURNS geometry
Summary of changes:
 NEWS                                   |   2 +
 doc/reference_sfcgal.xml               | 905 +++++++++++++++++++++++++++++----
 sfcgal/lwgeom_sfcgal.c                 |   6 +-
 sfcgal/regress/regress_sfcgal.sql      |  55 +-
 sfcgal/regress/regress_sfcgal_expected |  19 +-
 sfcgal/sfcgal.sql.in                   | 250 +++++++--
 6 files changed, 1105 insertions(+), 132 deletions(-)
hooks/post-receive
