[PostGIS] #5699: ERROR: XX000: SQL/MM Spatial exception - geometry crosses an edge
trac at osgeo.org
Mon Mar 25 09:25:34 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.4.3
Component: topology | Version: 3.4.x
Resolution: | Keywords: robustness
Comment (by strk):
Using squared distance, edge2 is confirmed being closer than edge1:
psql:break.sql:10: DEBUG: [topo/lwgeom_topo.c:_lwt_AddPoint:5079] Edge 2
squared distance: 0
psql:break.sql:10: DEBUG: [topo/lwgeom_topo.c:_lwt_AddPoint:5079] Edge 1
squared distance: 1.64235648202829e-31
psql:break.sql:10: DEBUG: [topo/lwgeom_topo.c:_lwt_AddPoint:5110]
Splitting edge 2
So what happens here is that edge 1 is indeed crossed by the incoming edge
because the added node only splits edge 2 and leaves edge 1 untouched,
with the result that noding in the topology breaks.
I believe the solution here would be to implement snapping of all edges
upon inserting a new node, same as with
https://trac.osgeo.org/postgis/ticket/5310#comment:3 - handling edges
collapse as needed (the portions of edge1 and edge2 going from the new
node to their shared node would be equal and thus need to be collapsed
into one).
By changing
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5699#comment:5>
