[PostGIS] #5699: ERROR: XX000: SQL/MM Spatial exception - geometry crosses an edge
PostGIS trac at osgeo.org
Mon Mar 25 10:33:20 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  assigned
  Priority:  medium             |  Milestone:  PostGIS 3.4.3
 Component:  topology           |    Version:  3.4.x
Resolution:                     |   Keywords:  robustness
Comment (by strk):
 A probably more severe issue here is that we ALLOW an invalid topology to
 be created. This should supposedly not happen as the code is theoretically
 checking for all these invalid conditions before accepting the change.
 The relevant snippt of the log is this:
 sql:break.sql:10: DEBUG:  [topo/lwgeom_topo.c:_lwt_CheckEdgeCrossing:682]
 lwt_be_getEdgeWithinBox2D returned 3 edges
 psql:break.sql:10: DEBUG:  [topo/lwgeom_topo.c:_lwt_CheckEdgeCrossing:713]
 Edge 5 converted to GEOS
 psql:break.sql:10: DEBUG:  [topo/lwgeom_topo.c:_lwt_CheckEdgeCrossing:726]
 Edge 5 relate pattern is FF1F00102
 Edge 2 converted to GEOS
 Edge 2 relate pattern is FF1F00102
 Edge 1 converted to GEOS
 Edge 1 relate pattern is F01FF0102
 psql:break.sql:10: DEBUG:  [topo/lwgeom_topo.c:_lwt_CheckEdgeCrossing:792]
 No edge crossing detected amongh the 3 candidate edges
 The last edge (Edge 1) is clearly having the a boundary-interior
 intersection but the code is not considering that as problematic, while it
 IS, in this case.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5699#comment:6>
