[SCM] PostGIS branch master updated. 3.4.0rc1-1067-gc2931466d
Mon Mar 25 11:21:36 PDT 2024
the project "PostGIS".
       via  c2931466ddb2f3b7b9e7581561aa0c7c8391791f (commit)
      from  09270d595112341b94b899bd39390eccd7c0a972 (commit)
revisions in full, below.
commit c2931466ddb2f3b7b9e7581561aa0c7c8391791f
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Mar 25 19:18:06 2024 +0100
    Simplify edge crossing validation by using boundary node rule
    Boundary node rule is available in GEOS since 3.3 while
    we require 3.8 or higher.
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index 3375fb006..df71b5690 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -747,7 +747,7 @@ BEGIN
       e2.edge_id as id2,
       e1.geom as g1,
       e2.geom as g2,
-      ST_Relate(e1.geom, e2.geom) as im
+      ST_Relate(e1.geom, e2.geom, 2) as im
     FROM
       edge e1,
       edge e2
@@ -771,51 +771,9 @@ BEGIN
   LOOP --{
-    IF ST_RelateMatch(rec.im, 'FF1F**1*2') THEN
-      CONTINUE; -- no interior intersection
-    -- Closed lines have no boundary, so endpoint
-    -- intersection would be considered interior
-    -- See http://trac.osgeo.org/postgis/ticket/770
-    -- See also full explanation in topology.AddEdge
-    ELSIF ST_RelateMatch(rec.im, 'FF10F01F2') THEN
-      -- first line (g1) is open, second (g2) is closed
-      -- first boundary has puntual intersection with second interior
-      -- compute intersection, check it equals second endpoint
-      IF ST_Equals(ST_Intersection(rec.g2, rec.g1),
-                   ST_StartPoint(rec.g2))
-      THEN
-        CONTINUE;
-      END IF;
-    ELSIF ST_RelateMatch(rec.im, 'F01FFF102') THEN
-      -- second line (g2) is open, first (g1) is closed
-      -- second boundary has puntual intersection with first interior
-      -- compute intersection, check it equals first endpoint
-                   ST_StartPoint(rec.g1))
-      THEN
-        CONTINUE;
-      END IF;
-    ELSIF ST_RelateMatch(rec.im, '0F1FFF1F2') THEN
-      -- both lines are closed (boundary intersects nothing)
-      -- they have puntual intersection between interiors
-      -- compute intersection, check it's a single point
-      -- and equals first StartPoint _and_ second StartPoint
-      IF ST_Equals(ST_Intersection(rec.g1, rec.g2),
-                   ST_StartPoint(rec.g1)) AND
-         ST_Equals(ST_StartPoint(rec.g1), ST_StartPoint(rec.g2))
-      THEN
-        CONTINUE;
-      END IF;
+    IF ST_RelateMatch(rec.im, 'FF*F*****') THEN
+      -- no interior-interior or interior-boundary intersections
+      CONTINUE;
     END IF;
     retrec.error = 'edge crosses edge';
Summary of changes:
 topology/sql/manage/ValidateTopology.sql.in | 50 +++--------------------------
 1 file changed, 4 insertions(+), 46 deletions(-)
hooks/post-receive
