[SCM] PostGIS branch master updated. 3.4.0rc1-1068-g41561a9d6
Mon Mar 25 12:42:54 PDT 2024
the project "PostGIS".
       via  41561a9d6f7049389b4f6f2224d960541e647a1e (commit)
      from  c2931466ddb2f3b7b9e7581561aa0c7c8391791f (commit)
revisions in full, below.
commit 41561a9d6f7049389b4f6f2224d960541e647a1e
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Mar 25 20:17:57 2024 +0100
    Add more debugging lines
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 73a539235..fde0b3992 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -5408,6 +5408,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
   lwpoint_free(start_point); /* too late if lwt_AddPoint calls lwerror */
   if ( nid[0] == -1 ) return -1; /* lwerror should have been called */
   moved += mm;
+  LWDEBUGF(1, "start point added or found as being %" LWTFMT_ELEMID " (moved ? %d)", nid[1], mm);
   end_point = lwline_get_lwpoint(edge, edge->points->npoints-1);
@@ -5420,9 +5421,10 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
   nid[1] = _lwt_AddPoint( topo, end_point,
                           _lwt_minTolerance(lwpoint_as_lwgeom(end_point)),
                           handleFaceSplit, &mm );
-  moved += mm;
   lwpoint_free(end_point); /* too late if lwt_AddPoint calls lwerror */
   if ( nid[1] == -1 ) return -1; /* lwerror should have been called */
+  moved += mm;
+  LWDEBUGF(1, "end point added or found as being %" LWTFMT_ELEMID " (moved ? %d)", nid[1], mm);
     -- Added endpoints may have drifted due to tolerance, so
@@ -5431,6 +5433,8 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
   if ( moved )
+    LWDEBUG(1, "One or both line endpoints moved by snap, updating line");
     nn = nid[0] == nid[1] ? 1 : 2;
     node = lwt_be_getNodeById( topo, nid, &nn,
                                LWT_COL_NODE_NODE_ID|LWT_COL_NODE_GEOM );
@@ -5463,9 +5467,13 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
     if ( nn ) _lwt_release_nodes(node, nn);
+    LWDEBUGG(2, lwline_as_lwgeom(edge), "Snapped after drifted endpoints snap");
     /* make valid, after snap (to handle collapses) */
     tmp = lwgeom_make_valid(lwline_as_lwgeom(edge));
+    LWDEBUGG(2, tmp, "Made-valid after snap to drifted endpoints");
     col = lwgeom_as_lwcollection(tmp);
     if ( col )
@@ -5504,6 +5512,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
         return 0;
   /* check if the so-snapped edge _now_ exists */
Summary of changes:
 liblwgeom/topo/lwgeom_topo.c | 11 ++++++++++-
 1 file changed, 10 insertions(+), 1 deletion(-)
hooks/post-receive
