[PostGIS] #3651: ST_Orientation crashes the backend
PostGIS trac at osgeo.org
Tue Mar 26 14:15:51 PDT 2024
  Reporter:  postgispaul  |      Owner:  robe
      Type:  defect       |     Status:  new
  Priority:  high         |  Milestone:  PostGIS SFCGAL
 Component:  sfcgal       |    Version:  2.3.x
Resolution:               |   Keywords:  windows
Comment (by robe):
 Sadly still issue on windows with
 SFCGAL="SFCGAL 1.5.1, CGAL 5.6.1, BOOST 1.84.0"
                          version
  PostgreSQL 16.2, compiled by Visual C++ build 1937, 64-bit
 or same with mingw backend
 PostgreSQL 16.2 on x86_64-w64-mingw32, compiled by gcc.exe (x86_64-posix-
 seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
 but works fine on demo.postgis.net running
 PostgreSQL 16.1 (Debian 16.1-1.pgdg130+~20231208.0559.g8ca5662) on x86_64
 -pc-linux-gnu, compiled by gcc (Debian 13.2.0-7) 13.2.0, 64-bit
 SFCGAL 1.5.0, CGAL 5.6, BOOST 1.74.0
 I need to try on my newer mingw setup -- which I've still got some libs to
 build before I can switch to.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3651#comment:21>
