[PostGIS] #5701: topology crashing under PG17
PostGIS trac at osgeo.org
Tue Mar 26 14:25:05 PDT 2024
 Reporter:  robe      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  blocker   |  Milestone:  PostGIS 3.5.0
Component:  topology  |    Version:  master
 Keywords:            |
 This is only failing on debbie so I assume it's PG17 cause that's the
 first one to run for master branch. GHA I assume doesn't have a new enough
 PG17 to catch this.
 Looks like it started failing yesterday.
 01:44:41  failed (psql exited with an error:
 /var/lib/jenkins/workspace/postgis/tmp/3_5_pg17w64/test_201_out)
 01:44:41
 01:44:41 Topology-Geometry 'sqlmm_topology' (id:x) created.
 01:44:41 -- ST_AddIsoNode ------------------------
 01:44:41 psql:sqlmm.sql:16: ERROR:  SQL/MM Spatial exception - null
 argument
 01:44:41 psql:sqlmm.sql:17: ERROR:  SQL/MM Spatial exception - null
 argument
 01:44:41 psql:sqlmm.sql:18: ERROR:  SQL/MM Spatial exception - null
 argument
 01:44:41 1
 01:44:41 2
 01:44:41 3
 01:44:41 4
 01:44:41 5
 01:44:41 6
 01:44:41 psql:sqlmm.sql:29: ERROR:  SQL/MM Spatial exception - coincident
 node
 01:44:41 psql:sqlmm.sql:30: ERROR:  SQL/MM Spatial exception - coincident
 node
 01:44:41 7
 01:44:41 8
 01:44:41 psql:sqlmm.sql:37: ERROR:  SQL/MM Spatial exception - not within
 face
 01:44:41 psql:sqlmm.sql:40: ERROR:  SQL/MM Spatial exception - invalid
 point
 01:44:41 psql:sqlmm.sql:43: ERROR:  SQL/MM Spatial exception - coincident
 node
 01:44:41 psql:sqlmm.sql:44: ERROR:  SQL/MM Spatial exception - coincident
 node
 01:44:41 psql:sqlmm.sql:45: ERROR:  SQL/MM Spatial exception - coincident
 node
 01:44:41 -- ST_AddIsoEdge ------------------------
 01:44:41 psql:sqlmm.sql:56: ERROR:  SQL/MM Spatial exception - null
 argument
 01:44:41 psql:sqlmm.sql:57: ERROR:  SQL/MM Spatial exception - null
 argument
 01:44:41 psql:sqlmm.sql:58: ERROR:  SQL/MM Spatial exception - null
 argument
 01:44:41 psql:sqlmm.sql:59: ERROR:  SQL/MM Spatial exception - null
 argument
 01:44:41 psql:sqlmm.sql:62: ERROR:  SQL/MM Spatial exception - invalid
 curve
 01:44:41 psql:sqlmm.sql:65: ERROR:  SQL/MM Spatial exception - curve not
 simple
 01:44:41 psql:sqlmm.sql:68: ERROR:  SQL/MM Spatial exception - non-
 existent node
 01:44:41 psql:sqlmm.sql:71: ERROR:  SQL/MM Spatial exception - end node
 not geometry end point.
 01:44:41 psql:sqlmm.sql:72: ERROR:  SQL/MM Spatial exception - start node
 not geometry start point.
 01:44:41 psql:sqlmm.sql:75: ERROR:  SQL/MM Spatial exception - geometry
 crosses a node
 01:44:41 1
 01:44:41 2
 01:44:41 psql:sqlmm.sql:82: ERROR:  SQL/MM Spatial exception - not
 isolated node
 01:44:41 psql:sqlmm.sql:83: ERROR:  SQL/MM Spatial exception - not
 isolated node
 01:44:41 psql:sqlmm.sql:86: ERROR:  SQL/MM Spatial exception - not
 isolated node
 01:44:41 -- ST_AddIsoNode(2) ------------------------
 01:44:41 psql:sqlmm.sql:97: ERROR:  SQL/MM Spatial exception - edge
 crosses node.
 01:44:41 -- ST_RemoveIsoEdge ---------------------
 01:44:41 psql:sqlmm.sql:111: server closed the connection unexpectedly
 01:44:41        This probably means the server terminated abnormally
 01:44:41        before or while processing the request.
 01:44:41 psql:sqlmm.sql:111: error: connection to server was lost
 01:44:41
 01:44:41 make: *** [regress/runtest.mk:24: check-regress] Error 2
 01:44:41 Build step 'Execute shell' marked build as failure
 01:44:41 [Gitea] do not publish assets due to build being non-Successfully
 01:44:41 Triggering a new build of PostgreSQL stop
 01:44:41 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5701>
