[PostGIS] #5703: ST_Intersects function is returning the wrong results for a simple rectangle that crosses any two quarter longitude lines
PostGIS trac at osgeo.org
Wed Mar 27 16:25:10 PDT 2024
 Reporter:  hangstrap  |      Owner:  pramsey
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 3.4.3
Component:  postgis    |    Version:  3.4.x
 Keywords:             |
 the ST_Intersects function is returning the wrong results for a simple
 rectangle that crosses any two quarter longitude lines (e.g 0, 90, 180,
 -90).
 Running the following query returns the points outside the polygon as well
 as the expected points inside
 select postgis.st_astext( point_) from
         with foo ( point_  ) as ( values
                 ( postgis.ST_GeogFromText( 'POINT (-6 0)')),
                 ( postgis.ST_GeogFromText( 'POINT (-4 0)')),
                 ( postgis.ST_GeogFromText( 'POINT (94 0)')),
                 ( postgis.ST_GeogFromText( 'POINT (96 0)'))
         select * from foo
 ) bar
 where postgis.ST_Intersects( point_, postgis.ST_GeogFromText('POLYGON ((
 -5 -10,  -5 10,  95.0 10, 95.0 -10 , -5 -10))'));
 The select statement should return the points (-4 0) and (94 0), but
 returns all four points.
 This select statement, that does not cross two quarter longitude lines,
 works correctly
 --works only closses 0 line
                 ( postgis.ST_GeogFromText( 'POINT (-51 0)')),
                 ( postgis.ST_GeogFromText( 'POINT (-49 0)')),
                 ( postgis.ST_GeogFromText( 'POINT (49 0)')),
                 ( postgis.ST_GeogFromText( 'POINT (51 0)'))
         select * from foo
 ) bar
 -50 -10,  -50 10,  50 10, 50 -10 , -50 -10))'));
 Tested on
 ''PostgreSQL 12.18 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 8.5.0
 20210514 (Red Hat 8.5.0-20), 64-bit''
 With Postgis
 ''POSTGIS="3.1.11 ca03d62" [EXTENSION] PGSQL="120"
 GEOS="3.12.1-CAPI-1.18.1" PROJ="9.2.1" LIBXML="2.9.7" LIBJSON="0.13.1"
 LIBPROTOBUF="1.3.0" WAGYU="0.5.0 (Internal)"''
 and
 ''POSTGIS="3.4.2 c19ce56" [EXTENSION] PGSQL="120"
 GEOS="3.12.1-CAPI-1.18.1" PROJ="9.2.1 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/var/lib/pgsql/.local/share/proj
 DATABASE_PATH=/usr/proj92/share/proj/proj.db" LIBXML="2.9.7"
 LIBJSON="0.13.1" LIBPROTOBUF="1.3.0" WAGYU="0.5.0 (Internal)" (core procs
 from "3.1.11 ca03d62" need upgrade)''
 The queries do work as expected on  postgres 10, postgis 2.4.8
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5703>
