[PostGIS] #5704: Some regress tests are available but not enabled
PostGIS trac at osgeo.org
Thu Mar 28 04:49:14 PDT 2024
 Reporter:  strk          |      Owner:  strk
     Type:  defect        |     Status:  new
 Priority:  medium        |  Milestone:  PostGIS 3.2.8
Component:  QA/testsuite  |    Version:  3.2.x
 Keywords:                |
 I've found that the utils/check_tests_enabled.sh script is failing to
 catch tests that are available but not enabled when their path contains
 the path of another enabled test.
 Affected branches from 3.2 to main (3.5dev)
 When fixed, various tests are found to be not enabled.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5704>
