[postgis] Indexing....ack!
harmonk00 harmonk00 at yahoo.com
Tue Aug 14 00:22:27 PDT 2001
I have a table that contains about 90,000 rows.  Each row has a
geometry column.  Each row has a 2D point as the value in that column.
The table looks something like this:
create table pole (bec_record_id numeric(8), ipid numeric(20),
featuresymgeometries geometry);
SO...I then insert my 90,000 rows and THEN create the following index:
CREATE INDEX POLE_NDX_1 ON cable USING GIST ( featuresymgeometries
GIST_GEOMETRY_OPS ) WITH ( ISLOSSY );
Then, I try the following select against the table:
explain select count(*) from  Pole where  Pole.featuresymgeometries
&& 'BOX3D(-69.9392089498987 18.47719733442078,-69.9368322996733
18.478711603947218)'::box3d
and I get this:
Aggregate  (cost=8699.73..8699.73 rows=1 width=0)
  ->  Seq Scan on pole  (cost=0.00..8677.16 rows=9025 width=0)
It did a full table scan...not good.
So then I turn the sequential scan stuff off:
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
