[postgis] Indexing....ack!
harmonk00 harmonk00 at yahoo.com
Tue Aug 14 00:33:47 PDT 2001
Before I start complaining, let me lead in with this:  The postgis
extensions that you've done are very impressive!   Good job!
Okay, now I complain:
I have a table with about 90,000 rows in it.  The table has a
geometry column that always contains a 2D POINT.  I created a GIST
index on this column.
I do a query against the table to select the records inside a certain
area, and it will NOT use the index, even though if I force it to, by
turning off the table scans, the query executes MUCH faster!  Is
there anything that can be done about this?  I would greatly
appreciate any help.
Here is my table:
create table pole (bec_record_id numeric(8), ipid numeric(20),
featuresymgeometries geometry);
Here is my index:
CREATE INDEX POLE_NDX_1 ON Pole USING GIST ( featuresymgeometries
GIST_GEOMETRY_OPS ) WITH ( ISLOSSY );
Here is my select:
explain select count(*) from  Pole where  Pole.featuresymgeometries
&& 'BOX3D(-69.9392089498987 18.47719733442078,-69.9368322996733
18.478711603947218)'::box3d   and on_image is null
Results with seqscan enabled:
Aggregate  (cost=8699.73..8699.73 rows=1 width=0)
  ->  Seq Scan on pole  (cost=0.00..8677.16 rows=9025 width=0)
Results with seqscan off:
set enable_seqscan=off;
Aggregate  (cost=22441.74..22441.74 rows=1 width=0)
  ->  Index Scan using pole_ndx_1 on pole  (cost=0.00..22419.18
rows=9025 width=0)
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
