[postgis] Re: SDE Java API
Raj Singh rs at syncline.com
Fri Aug 17 10:53:11 PDT 2001
The latest version of SDE (8.1) finally does have a
Java API. I hear it's reasonably functional, but I
haven't used it yet myself.
--- In postgis at y..., Paul Ramsey <pramsey at r...> wrote:
> I wonder if
> there is a Java interface to SDE? If not a JNI connection could be
> used,
> it would just be less pleasant. Doing the transactional stuff for
> file-based data will be fairly tricky, I would guess, particularly
> in a write-heavy environment.
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Do you need to encrypt all your online transactions? Secure corporate intranets? Authenticate your Web sites? Whatever
security your site needs, you'll find the perfect solution here!
http://us.click.yahoo.com/Bre3tC/Q56CAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
