[postgis] PostGIS and NT
Erik Brenn erb at blom.co.id
Mon Aug 20 02:27:23 PDT 2001
If you want to run PostgreSQL on NT you need to first install the cygwin
unix emulator, and then compile PostgreSQL under this environment, which
usally is pretty much straight-forward. You can get cygwin from
http://www.cygwin.com. Additionally you will need the cygipc library
(http://cygutils.netpedia.net), which provides shared memory and semaphores
for cygwin.
Good luck...
regards,
 Erik Brenn
PT Blom Nusantara
www.blom.co.id
----- Original Message -----
From: "Lyndon Zimmermann" <lyndon.zimmermann at adelaide.edu.au>
To: <postgis at yahoogroups.com>
Sent: Monday, August 20, 2001 16:00
Subject: [postgis] PostGIS and NT
> Greetings,
> I'm interested in investigating PostGIS but don't have a lot of time or
> compilers of worth. I'm running MapServer under NT and a more readily
> editable nodes database than ESRI shapefiles would probably be useful.
> My initial investigation of the PostgreSQL website failed to identify
> any NT binaries so I presume I'm down for the count.
> Am I correct?
> Lyndon Z
> Lyndon Zimmermann
> BE (Mech Adelaide) Grad Dip Bus Admin (UniSA)
> "Bioenergy Atlas for Australia" Co-ordinator
> University of Adelaide Agronomy and Farming Systems
> C/- GISCA, 4th floor, 10 Pulteney St, Adelaide 5005
> Dir (GISCA) +61-8-8303 3975 Switch (GISCA) 8303 3900 Mob 0414 91 4577
> Fax (GISCA) +61-8-8303 3498 email lyndon.zimmermann at adelaide.edu.au
> http://sg211.gisca.adelaide.edu.au/lzimmerm/zimm.htm
> Biomass Energy Atlas Website:
> http://sg211.gisca.adelaide.edu.au/bioenergy_atlas/html/atlas_index.html
> Unless otherwise stated, the content of this message and attachments may
> be forwarded or quoted, with due acknowledgement.  No representation is
> made that this email is free of viruses. Virus scanning is recommended
> and is the responsibility of the recipient.
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Do you need to encrypt all your online transactions? Secure corporate intranets? Authenticate your Web sites? Whatever
security your site needs, you'll find the perfect solution here!
http://us.click.yahoo.com/Bre3tC/Q56CAA/yigFAA/PhFolB/TM
