[postgis] Importing ESRI-shapefiles, objectid 23?
Dave Blasby dblasby at refractions.net
Fri Aug 24 09:14:51 PDT 2001
> I tried to import an ArcInfo shapefile with the little loader program
> and unfortunately got the message that objectid 23 isn't supported by
> the loader - peeking into the sources I found out that id 23 relates
> to SHPT_ARCM which isn't handled by the loader yet. Is there any
> chance to get full compatability for the loading process - or is there
> any documentation on this missing type which could help me extending
> the loader ? - at the moment only very few types seem to be supported
	PostGIS supports 2d and 3d points - it does not support 4d (x,y,z, and
'm').  What are you using the 'm' value to mean?  Could you use it as an
attribute (ie. in the dbf file) instead?
dave
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
