[postgis] Re: ESRI client
valentine valentine at sdc.ucsb.edu
Mon Aug 27 08:41:18 PDT 2001
> For the moment, we'll have to be happy with hacks around
ESRI-imposed
> limitations, and hopefully will see some nice non-ESRI
clients start to
> spring up. We've heard several folks on the list express an
interest in
> these kinds of things in the past, so who knows what the
future holds.
The latest versions of SDE are actually built on the features
the DB provides (at least for DB2, Informix, and Oracle). This
means you need to just tel esri you want them to support PG
as a backend DB. File your feature request, and wait a couple
of years.
I might sugest a couple of hacks that would get around:
1) ArcIMS ArcAXL compatability. Support someone to write
middleware to emulate an ArcIMS datasource.
2) Write MapObects code to extract from PG DB, and expose
data as mapobject IMS server.
3) Use VB for apps/c interface to make the PG look like a data
layer.
4) WMS service layers, and non-esri clients.
Basically, all the steps involve programming. If you want out of
the box work with the esri investment, you are out of luck. You
need to go kiss jacks rear. Esri has not made it easy to
outside datasoruces. Just make it known to ESRI, that you are
not happy about it. They don't turn on a dime, but there are
people inside who do see the open point of view.
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Do you need to encrypt all your online transactions? Secure corporate intranets? Authenticate your Web sites? Whatever
security your site needs, you'll find the perfect solution here!
http://us.click.yahoo.com/Bre3tC/Q56CAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
