[postgis-users] dataset for postgis
Hao Ding hdi12 at it.canterbury.ac.nz
Thu Jul 4 15:21:51 PDT 2002
I tried creating a sql file from Itasca demo shapefile, but got
"Segmentation fault" error. Are there some faults in the command?
cosc273:data$ shp2pgsql airports airports gisdb > airports.sql
Segmentation fault
Thanks,
Hao
Tyler Mitchell wrote:
> hi Hao,
> Do you have the Itasca demo data for Mapserver?  You can use the postgis tool
> called 'shp2pgsql' (I can give you more info if needed) to create a SQL file
> and then you can load the sql commands into postgis.
> I don't have time right now but I'll gladly help walk you through it.  I even
> have a set of SQL files for the demo data available if you want them.  Just
> let me know.
> Tyler
> On Monday 01 July 2002 09:44 pm, you wrote:
>>Hi all,
>>Now I am implementing a OGC WMS client application.  I have installed
>>MapServer as WMS server and postgis as back-end datasource.  Where can I
>>find some spatial dataset that can be stored in the postgis and used by
>>MapServer? If I get some dataset, how to put them into postgis and make
>>them work with MapServer?
>>These questions could be simple for someone, but I am a new user of
>>MapServer and postgis, and the documents don't provide me all information I
>>am hunting. Thanks very much for any help?
>>Regards,
>>Hao
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
