[mapserver-users] Re: [postgis-users] sql works, but not as l ayer?
Obe, Regina DND\MIS robe.dnd at ci.boston.ma.us
Tue Jun 4 14:36:23 PDT 2002
I think maybe the problem is you have two oids (so it is unclear which is
which) in your select.  Try setting your select statement such that you only
have one oid (the oid from the spatial table).
Something like
(SELECT o.oid, o.the_geom, p.myfield1, p.myfield2, etc. from
objecteigenschappen o left join
pc6punten p on p.pc6=o.eigenschap_3) as foo"
-----Original Message-----
Sent: Tuesday, June 04, 2002 3:57 PM
To: Dave Blasby
Cc: postgis-users at postgis.refractions.net;
mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Re: [postgis-users] sql works, but not as
layer?
I'm sorry, but after tons of trying and recreating tables it still doesn't
work. I've simplyfied the query:
CONNECTION "user=postgres dbname=food host=10.0.0.2"
DATA "the_geom from (SELECT * from objecteigenschappen o left join
FILTER "pc6 like '1797%'"
I still get the postgresql error "ERROR:  Attribute 'oid' not found", but i
have defined a index for oid for both (pc6punten en objecteigenschappen)
tables. Also geometry_columns table is correctly setup.
Does anybody knows what is going wrong?
Best regards,
-twan
> > DATA "the_geom from objecteigenschappen o left join pc6punten p on
> > p.pc6=o.eigenschap_3"
> > FILTER "(the_geom && GeometryFromText('BOX3D(109258 559953,115258
> > 565953)'::box3d,-1) and distance(the_geom,
GeometryFromText('POINT(112258
> > 562953)',-1)) < 3000)"
>You're using the DATA parameter incorrectly - its a bit confusing.
>The generic templates are:
>DATA "<geom column name> from <table name>"
>         or
>DATA "<geom column name> from (<sql statement>) as foo"
>In your case, use:
>hope that works,
>dave
http://www.twansoft.com
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
