[mapserver-users] Re: [postgis-users] sql works, but not as l ayer?
Twan Kogels twan at twansoft.com
Wed Jun 5 03:31:55 PDT 2002
I tryed your suggestion immediately and the error "Attribute 'oid' not
found" disappeared. I also found
<http://mapserver.gis.umn.edu/wilma/mapserver-users/0110/msg00283.html>
which explains sub-select feature.
Now all errors are disappeared, but now postgis is not returning any
points. For simplicity i now use a simple test query:
DATA "the_geom from (SELECT oid, * from pc6punten) as foo"
When i execute this query in my postgresql client (psql) all points in
tabel pc6punten are returned. But when i try it as layer definition in
mapserver nothing is returned (not even a error).
My layer definition is:
LAYER
   CONNECTIONTYPE postgis
   NAME "poi_layer"
   CONNECTION "user=postgres dbname=food host=10.0.0.2"
   STATUS ON
   TYPE POINT
   CLASSITEM "pc6"
   CLASS
     TEMPLATE "ttt_query.html"
     SYMBOL 2
     SIZE 8
     COLOR 0 0 0
   END
   TOLERANCE 5
END
When i replace the DATA field to:
DATA "the_geom from pc6punten"
all correct points are returned and displayed.
I hope this is the last time, but does anybody know what i'm doing wrong?
Best regards,
-twan
At 17:36 4-6-2002 -0400, you wrote:
>I think maybe the problem is you have two oids (so it is unclear which is
>which) in your select.  Try setting your select statement such that you only
>have one oid (the oid from the spatial table).
>Something like
>(SELECT o.oid, o.the_geom, p.myfield1, p.myfield2, etc. from
>objecteigenschappen o left join
>pc6punten p on p.pc6=o.eigenschap_3) as foo"
>-----Original Message-----
>From: Twan Kogels [mailto:twan at twansoft.com]
>Sent: Tuesday, June 04, 2002 3:57 PM
>To: Dave Blasby
>Cc: postgis-users at postgis.refractions.net;
>mapserver-users at lists.gis.umn.edu
>Subject: Re: [mapserver-users] Re: [postgis-users] sql works, but not as
>layer?
>I'm sorry, but after tons of trying and recreating tables it still doesn't
>work. I've simplyfied the query:
>DATA "the_geom from (SELECT * from objecteigenschappen o left join
>FILTER "pc6 like '1797%'"
>I still get the postgresql error "ERROR:  Attribute 'oid' not found", but i
>have defined a index for oid for both (pc6punten en objecteigenschappen)
>tables. Also geometry_columns table is correctly setup.
>Does anybody knows what is going wrong?
>Best regards,
>-twan
> > > DATA "the_geom from objecteigenschappen o left join pc6punten p on
> > > p.pc6=o.eigenschap_3"
> > > FILTER "(the_geom && GeometryFromText('BOX3D(109258 559953,115258
> > > 565953)'::box3d,-1) and distance(the_geom,
>GeometryFromText('POINT(112258
> > > 562953)',-1)) < 3000)"
> >You're using the DATA parameter incorrectly - its a bit confusing.
> >The generic templates are:
> >DATA "<geom column name> from <table name>"
> >         or
> >DATA "<geom column name> from (<sql statement>) as foo"
> >In your case, use:
> >hope that works,
> >dave
>http://www.twansoft.com
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
