[postgis-users] Accessing PostGIS from ArcView
Graeme Leeming gleeming at refractions.net
Tue Jun 11 14:34:08 PDT 2002
Armin,
I was able to get your extension working under ArcView3.2/WinNT after a little
bit of adjustment.  Note that the password option for pgsql2shp.exe should be -P
not -p in your AVPGCon.LoadTheme script (-p is used for specifying the port
number).  Otherwise the load/reload/filtering parameters worked for me.  Good
job; I am looking forward to using this.  Another useful bit of functionality to
think about for the future would be allowing SQL views to be retrieved in a
similar manner to tables.
I like the elephant logo in the dialog box, so I vote to keep it there!
- Graeme
Armin Burger wrote:
> Hi all,
> I have been working on an extension for ArcView 3 to access PostGIS data. At
> the moment the extension offers the functionality to
> * Retrieve PostGIS data as shapefile and load them into ArcView,
>   including data refresh
> * Re-project PostGIS data and create shapefile
> * Identify and editing of attribute information directly on the database
> If you are interested, you can download the extension including source code
> and needed libraries at
> http://digilander.iol.it/arminburger/download/avpgcon.zip
> The database access is without ODBC, using the libpq.dll functionality.
> Future plans are to implement a visualization of PG data as graphics in
> ArcView (instead of temporary shapefiles). The only part missing for that is
> a fast and reliable algorithm to convert PostGIS geometry for different types
> into ArcView Avenue representation. If anyone has already finished such work
> successfully and would like to contribute, I would be glad to include it.
> The extension uses the pgsql2shp.exe to create the shapefiles. That will
> always open a command window what is not very elegant. To avoid this, the
> compilation of a library instead of the executable would be necessary. Can
> anybody tell me how much effort it would be to change the C code in order to
> compile as library?
> Any feedback is very welcome.
> Armin
>  Armin Burger
>  Via della fiera, 7 -  I-39050 Cornaiano BZ -  Italy
> PS: I hope the Refractions people don't mind me using their elefantino logo
> in one dialog, I liked it too much.
> postgis-users mailing list
